Question about Yamaha DVX-C310SL System
Distorted picture, after changing "TV TYPE"
Out of curiosity I switched the "TV TYPE" to PAL- notice stated that it will auto-recover in 15 seconds, well, since yesterday and after following the troubleshooting instructions - which are not much help- in addition to unplugging the console for 30 minutes, I still have a vertical roll for picture under DVD/CD selection. Everything else works well as far as audio. Another thing I notice, under DVD setup menu the "preference page" is empty.
I hope you can help, I just got this system last week....
thanks!
  • Nuala48 May 07, 2008
    Thank you for taking of your time to respond, I tried your suggestions but did not work however I came across the instructions below in the manual and that did the trick. I am not very impressed with this manual. I know this is not a top of the line Yamaha system, but it is not very friendly...
    Genius:
  • 1,224 Answers
Well here goes
its going to take a little finness but i think i can help
i got the owners manual infront of me
find dvd/cd press it. then setup button on remote go to the osd menu you probably wont see it cause its a little fuzzy
but were going to try and walk threw blind, video menu is the first one on menu so its going to be one down
that tv type
one over to right arrow keys
one down to ntsf setting then hit ok (enter)
this way is a blind walk threw but will get it done if have patiences
the other way you mentioned is that your missing preferneces
will see and check
the other is [preferences page]- [default]- [reset] Press enter (ok) to reset the paremeters to initial factory settings
this can be found on page 38 en of the manual i will also post the link so you know what i am looking at hope these too things work i know you cant see your screen but a blind walk threw is better than not having the preferences not being there for you
http://www.generalmanual.com/pdf/yamaha/DVX-C310_manual.pdf
Posted on May 07, 2008
Change ntsc to pal
The manual seems to indicate that the TV will automatically detect what signal type is present, so PAL should be recognized. There is, however the possibility that the "Color System" setting under the system menu may not be set to "AUTO", but NTSC. This would cause a conflict when detecting PAL input and affect picture. Check the "Color System" and either select PAL or AUTO and see if that helps.
Sep 18, 2014 | Televison & Video
Noisy sound and picture distortion while switching on TV,after a few seconds everything will be ok
Check by auto tuning the set, if no change than get replaced the tuner unit inside the TV to get this problem solved.
Feb 08, 2011 | JVC AV-29LX 29" TV
The color on our Sony tv is now distorted. The
if this is an older tv and your state might have changed to digital programming then i would suggest trying to look at the back of the set and see if you have anything to fix this problem or you might want to CHECK AND SEE IF YOU HAVE VIDEO ON or CABLE on or TV on. Sometimes if you have Antenna switch to cable then your channels would be red and picture distorted. change the antenna to air for tv. or from tv to cable.
Feb 24, 2010 | Televison & Video
My dvd player is outputing a black and white picture both on its own screen and when connected to a tv.
this has to do with picture compatibility between the TV and the DVD player.
To resolve this, check picture settings from your TV and change it to PAL or AUTO.
From DVD, change to NTSC or PAL. This could be gotten directly from the DVD remote.
All the best.
Jan 06, 2010 | Televison & Video
Rf signal pal to ntsc
there should be an option in your picture settings menu
Jul 23, 2009 | Polaroid FLM-1514B LCD TV
My yamaha dv-s5650 is only playing in black & white!
That's a problem with the video IC it might shorted. You need to send your TV now to the nearest electronic repair center and have it fix there.
Jun 29, 2009 | Televison & Video
Change from PAL to NTSC
To begin, the first and second problems are completely unrelated.
If you bought a PAL TV and are playing an NTSC source, the result will be an invalid format. The two sources are not compatible. However, there are converters available, see: http://www.converters.tv/signals/ntsc_to_pal.html (just as an example).
To the second user. My first guess is that you need to select the proper input on your TV. Look for the "input" button on your TV remote and toggle through each input until you see a picture. The problem may be more complicated than that, but, to troubleshoot, I need to know: what TV you have, how many devices and what devices are hooked to the TV.
Mar 28, 2009 | Koss KS3102 System
DISTORTED AUDIO OF AIWA TV-AS217NH
no audio / please send me the frequency for ahmedabad city
Dec 13, 2008 | Aiwa TV-S2011 20"
PAL TV in US
Best call Pioneer there may be a set up in the factory menu to change the sytems from PAL to NTSC
Nov 14, 2008 | Televison & Video
Changing the VHF/UHF input to the AUX input
My beko tv can to tune to the pal BG to give me the sound. it only gives me picture, when i try to tune it to get the sound i only get the pal I insteard of the pal BG. the tv came from the UK. can sombody give me some code to change from pal I to pal BG? thanx.
Oliver. oliverabaiden@yahoo.co.uk
Aug 31, 2008 | Radio Shack (15-2147) Remote Control
Yamaha DVX-C310SL System Logo
94 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
