Question about Ricoh Aficio 1015 All-In-One Laser Printer
Paper feed Ricoh Aficio 1015 - Ricoh Aficio 1015 All-In-One Laser Printer
  • 903 Answers
Is the copier not feeding? There are many problems that could be causing this.
- The feed roller could be dirty or worn. The feed roller sits on the upper right side of the paper tray -- it's a thick gray roller. Clean this roller with a lint-free rag and some alcohol.
- The paper fences might not be tight. There are two paper fences (one toward you and one on the far side of the paper, away from you). Make sure these fences are tight enough so that the paper does not move around in the tray, but not too tight to keep the paper from being fed out of the tray. Also make sure the green guide on the left side of the paper is snug but not too tight.
- The paper could be damp, curly, or full of static. Damp paper is a big problem, especially in the summer. Try filling the tray with a fresh **** of paper and see if it feeds through better. Also make sure none of the pages in the tray are bent or folded under.
Did any of these suggestions help?
Posted on Aug 30, 2010
Ricoh Aficio 1015. Why is it not resetting?
Code 543 - Description: Fusing overheat error.
A fusing temperature of over 230°C is detected for 1 second by the fusing thermistor. - Causes: • Fusing thermistor defective • Power supply board defective
May 28, 2015 | Ricoh Aficio 1015 All-In-One Laser Printer
Ricoh Aficio 1515
is thera paper jam sensor wigle paper in and out unplug unit from wall 2 min ten back in hit sensor with paper hit reset on unit
Jan 22, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
What could the Grinding noise be that is coming from Ricoh Aficio MP C2550 for each page copied/printed?
Check for:
-broken plastic gear on right side of copier
-paper or foreign object in paper path
-paper or foreign object near fuser
Oct 15, 2014 | Ricoh Aficio Mp C2550 Copier With Feed,...
How to change feed roller on RICOH Aficio SP C242DN ?
1. remove all the cartridges.
2. remove the waste toner bottle.
3. rear cover
4. left cover
5. paper feed clutch
6. close the top cover and front door.
7. pull out the tray.
8. stand machine with the rear side facing the table.
9. slide the paper feed shaft to the left side.
10. remove the paper feed roller.
Jul 09, 2014 | Ricoh Corp Aficio SP C231N Laser Printer
Service code "SC541" on A Ricoh Aficio 1015/18
that mean themistor is corrupted chang it first try to clean it if it does't work change it his position on fuser unit
Jan 11, 2011 | Ricoh Aficio 450 Copier
We have lost our user manuals for the Ricoh Aficio 1015. I need to know how to enter new numbers for the fax directory. Can you remind me how to do so?
I can't remember off the top of my head -- it's in User Tools, either under System Settings and then Address Book, or under Fax Settings. But you can download the manual here, and it will tell you:
http://ricoh-usa.com/downloads/manuals.asp?tsn=Ricoh-USA
May 17, 2010 | Ricoh Aficio 1015 All-In-One Laser Printer
Ricoh Aficio 3025. The first tray is stuck halfway out, it looks like something came loose please help me!
you have to check the paper feed clucth or the tegestration clucth or you have to chean the paper feed roller
Jun 16, 2009 | Ricoh Aficio 3025 All-In-One Laser Printer
Ricoh Aficio 1015 All-In-One Laser Printer Logo
202 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
