Finding out how many watts my amplifier is
I'm trying to figure out how many watts my amplifier is. The serial number i have is 0547001147
  • 1,512 Answers
Hi bspdrmnky
What make and model is it.....do you have any information other than the serial number??
robotek
Posted on May 07, 2008
Where is V193037
Guitar Info This guitar is from the U.S. Vintage Series
made at the Corona Plant (Fender), USA
in the Year(s): Cannot be determined from serial number,
however you can consult this chart showing the
corelation between serial numbers and dates found on the neck
Fender MIA RI Serial Number vs. Neck Date
Fender: Corona Corona factory was opened in 1985, Corona California, with major guitar production starting in 1987. With the addition of a custom shop in 1987 the plant currently employs about 700 workers. Apart from general and Custom Shop Fender instruments and amplifiers, it also encompasses Guild acoustic & electric guitars.
May 12, 2014 | Fender Starcaster Strat Electric Guitar -...
Interior parts are burnt and I need an interior map with labelled parts numbers
google the serial number on the pioneer or take it to a radio shack or stereo shop that deals with amps
Oct 31, 2013 | Pioneer GM-6400F 4-channel Car Amplifier -...
What years were the Rheem 81v40d produced?
You can find age of water heater from serial number located on label on side of tank.
Label also shows tank size, and tank wattage and element wattage
http://waterheatertimer.org/Figure-Volts-Amps-Watts-for-water-heater.html
http://waterheatertimer.org/Water-at-bottom-of-water-heater.html
Serial number decoder:
http://waterheatertimer.org/pdf/WaterHeaterSerialNumberDecoder.pdf
For example Rheem serial number 0790...
First 2 digits are month 07 July
Next two digits are year 1990
Rheem site does not show 81v40d
http://www.rheem.com/products/tank_water_heaters/electric_water_heaters/
Dec 26, 2010 | Rheem 65 GAL ELEC Water Heater 6YR Self...
I NEEDYOU NOW THE VALUE FOR RESITOR R338
The HIGHEST instance number I can find on the schematic is R337... I cannot find R338.
Could you be reading R336 instead? It is a 100 ohm, 1/4 Watt.
If this is not the one, please advise other components it connects to and I will try to figure it out.
Sep 27, 2010 | Peavey Pv 2600 Power Amplifier
Where is the serial number on my marshall amp mg15fx
Behind the amp, right around where the power-supply is. Usually the right hand side at back of amp. Serial numbers are labeled as: S/N########
Mar 14, 2010 | Marshall Mg15dfx 15-Watt Combo Guitar...
I have an old what looks too be a student model guitar, and it doesnt have a name, And that is what i want too know, the serial number is FG3 835-1238
If you mean old as in 60's old then its likey that it's a Teisco. Teisco was a Japanese company that made student guitars under countless brand names. You can find them all over the place in all kinds of funky shapes, colors, etc...
Go on eBay and look up Teisco and see if you can find one similar to yours.
Mar 13, 2010 | Washburn Amplifiers: 25 WATT Guitar...
Finding the best amplifier
Hello sharky75,
That 1600 watt peak power figure for your subwoofer can't tell you what amp you need. You need to know the maximum RMS power the sub can handle. And you need to know the impedance (ohms) of the voice coil(s). JBL GT5 series subs have an RMS rating of 275 watts. The GTO series handles 300 watts. The Power series handles 400 watts. The GTi series handles 700 watts. Some are single voice coil, so the impedance is fixed. Others are dual voice coil allowing you to wire them for different impedance loads.
For maximum performance your amp should be able to provide at or near the same number of watts RMS into the lowest impedance at which the sub can be configured. For example, if your sub is the Power Series Model number P1224, it has dual 4ohm voice coils and can be wired to present either a 2ohm load (parallel) or an 8ohm load (series). You want to wire the voice coils in parallel for the 2ohm load and select an amp that outputs up to 400 watts RMS into 2ohms. The Orion Cobalt CO8001 is just such an amp. If you have one of the GTi Series subs, a better amp would be the JVC Arsenal KS-AR75 which outputs 700 watts into 2ohms.
Hope this helps.
Jul 31, 2009 | JBL Power P1022 Subwoofer - 10" Dual 2...
Legacy 1800 watt amplifier
HI ...NO, YOU CANT JUST CHANGE THE TRANSISTORS..YOU ARE RIGHT THERE IS MORE TO IT THAN THAT.......
Feb 06, 2009 | Legacy 2 Channel 1600 Watt Bridgeable...
I found this amp and I can't seem to figure out what the wattage is?
You are probably aware on how to use these output figures, but I'll write a quick explanation on the specifications for future readers anyways :)
The concpet CC-452 amplifier has the following power output specifications:
Calculated at 14.5 volts DC;
At 4 ohms per channel - 45 watts x 2 (RMS)
At 2 ohms per channel - 70 watts x 2 (RMS)
At 4 ohms bridged - 150 watts x 1 (RMS)
This means that your amplifier would provide 45 watts of power each for your front speakers, which are normally a 4 ohm load per side (45 watts for left, 45 watts for right), that's unless they are one of those exotic higher end brands (eg: Boston Z6s which are 3 ohms). Rarely, you will find speakers that are rated at 2 ohms per side, but in this instance the amplifier will provide 70 watts of power into each speaker. On your speaker specifications, you will find a value termed "nominal impedance" which will give you the ohm rating of the speakers being used..
On the other hand, if you "bridge" both channels into a single channel (using a diagram often marked on the speaker terminals of the amp), you could then provide 150 watts into a subwoofer (providing it was a 4 ohm woofer).
It's not recommended to use this amp bridged under 4 ohms..
Some subwoofers may be lower than 4 ohms, and you will not be able to use this amplifier for these types of speakers without risking amplifier failure. Also, some subwoofers may have 2 seperate voice coils, and you will have to use both channels of the amplifier seperately (not bridged) in order to correctly connect this type of speaker for use.
Oct 28, 2008 | Concept CC-452 Car Audio Amplifier
1,531 people viewed this question
 Grubhead
Grubhead
