Question about GE Spacemaker JVM1640SJ Microwave Oven
MY MICROWAVE READS F-3 AND IT PEEPS AND WON'T SHUT OFF. THE FAN KEEPS RUNING AND I CAN'T SHUT THE MICROWAVE OFF AND IT KEES BEEPING. CAN YOU HELP ME
  • DSue May 20, 2008
    The fan on my 6 year old GE profile JVM1860 microwave turned on by itself an then the touch panel went dead. I unplugged the microwave and then replugged it. The "set clock" went on and then the F3 Message, and a beep sounds every minute now.
  • GE Master
  • 9,098 Answers
On a GE microwave F3 means you have a failed keypad.
We replace these for customers nationwide with our guaranteed $39.95 service.
If you might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved. It's here.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 24, 2008
  • 1,512 Answers
F3 error means that the oven tempeture sensor is open circuit. You will need to replace it.
I have already forewarned you about the voltages inside microwaves. BE SURE TO DISCONNECT THE POWER!!
Hoping you could give me a FixYa for that one :)
regards
robotek
Posted on May 07, 2008
  • Graeme Ross
    Graeme Ross May 07, 2008
    Disregard the temp sensor solution here. I now know from you additional post.... that you have a GE unit. see this post for the correct diagnosis :)
Kenmore microwave fan won't shut off
The fan is required when the microwave is running, cools the magnetron. The problem may be in one of the interlock door switches, it is to complicated to go through the steps and the testing requirements, plus the alignment is critical.
Mar 22, 2012 | Microwave Ovens
I don't know why my microwaves keep beeping and starts the Exhaust Fan automatically every 5 mins. The display says F-3. Please help me with the problem I'll appreciate.
F-3 is usually for the temperature sensor being faulty. What you need most likely is to replace the temperature sensor. This would explain why your microwave oven exhaust fan keeps going off, because your temperature sensor is telling it that it is overheating even though it isn't.
Jul 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My ewave microwave oven fan keeps running will not shut off unless power is unplugged
Sorry to read about your problem, I hope this helps you out.
you have a defective fan relay switch
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 23, 2010 | Microwave Ovens
Our Microwave keeps running and won't stop. It is
The fan you hear is probably the magnetron cooling fan and that, and the light, are probably both controlled by the electronics board that controls everything else. You might inquire online at Maytag or the Sears parts department to determine the cost of a replacement board but I suspect it will either not be available at all or cost 3/4 of a new microwave.
Jan 23, 2010 | Maytag MMV4205 Microwave Oven
Plz help!! microwave oven not working!!!!
You need to check the door interlock switches. If the door is shut the light should be out unless the machine is runing.
Nov 12, 2009 | Microwave Ovens
FAN WONT SHUT OFF
My Kenmore microwave oven fan has been turning on and off, almost every hour. Sometimes 3 or 4 times in one hour. It's very random. Model No. 721-80593401 Serial No.503TA03208
Please help!!!
May 31, 2009 | Kenmore 62642 / 62644 / 62649 Microwave...
Samsung MU3250W Shut down
It could have been steam or humidity.
If this is an over the range model, be sure you always use the hood vent exhaust fan when you're cooking on the stove top.
Whether it's a counter top or over the range top, always be aware that the cooling fan is running when it's cooking.
When in doubt feel for air flow through the vents.
Good luck.
Oct 19, 2008 | Samsung MU3250W Microwave Oven
I CAN'T SHUT OFF MICROWAVE IT SHOWS F-3 AND IT KEEPS BEEPING AND I CAN'T SHUT OFF FAN OR MICROWAVE
Hi DIBARTRK
First, try resetting the unit by completely diconnecting from the power for 10 mins. Then reconnect. If it still does the same thing, then it has develpoped a fault and will need to be looked at by a Service Guy.
Microwaves have very dangerous voltages inside, and I do not reccomend that you attempt to fix it yourself. What brand is it and where in the world are you... let meknow and I can find a repair center near to you. :)
robotek
May 06, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
159 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
