Question about Hanna pHep pH Meter with Solutions
I balance it to 7 with solution. Then check my water and it says its 7.22 but when i check with the good ol drops its about 6.5 or 6.6 and sometime it is even way off more. and have to adjust it everytime even 5 minutes later. I put it back in the solution after im done testing and its off by .05 to .08 or more sometime
  • 8,404 Answers
Is this a automatic pH meter?
The only reliable way to measure your pH is by using a test kit. The automatic devices must be adjusted and set at least as often as the manufacturer recommends.
Your pH should be between 7.2 and 7.6. Your Alk should be at 100 (between 80 and 120) Get the Alk right before you try to get the pH at 7.2 or 7.4. These changes you are making should be measured over a number of days not a number of minutes, by the way. Alk 'buffers' pH and prevents pH 'bounce'.
Does your filter system run 24/7? Point of interest, most commercial pools should have a 8 hour turn over rate and run 24 hours a day for best results. Spa's should turn over on a 2 hour basis.
I don't know where you are writing from, the acceptible pH in the USA, generally, is 7.0 to 7.8. 7.0, while not really bad, is more acid than most swimmers can enjoy.
Other considerations: Your calcium should be around 250/300 ppm. Outside pool? Cyanuric Acid should be around 70 - 80 ppm. CL should be around 4 ppm. If you are using Bromine, the Br number is 2 X the CL number. By the way, Bromine is about 2 X more expensive than CL. Might you be using salt and making your CL? Salt should be 3200 to 3400 ppm and you should monitor your CL and adjust daily to get your 2 to 4 PPM cl. You MUST protect this CL with Cyanuric Acid.
I hope you find this information helpful. The courtesy of a positive vote will be appreciated.
Thank you for your interest n FixYa.com
Posted on Aug 29, 2010
03 jeep liberty 3.7 intermittent random multiple missfires with codes. Po3xx. All over the board with no particular pattern.
with scan tool values go as such... when running good left and right bank inj 3.8 ms when braking up l@38 r@0..
May 30, 2017 | Jeep Cars & Trucks
Quadratic functions
Substitute 2 for x, 3 for f(2). This gives you an equation with a as an unknown
3=a*(2^2)-6(2)-7
3=4a-12-7
4a=3+12+7=22 or a=22/4=11/2
Check
11/2*4-12-7=3 Checks OK
Oct 20, 2013 | Office Equipment & Supplies
I am attempting to repair my uploader whirlpool washer, I have removed the drum, however I hear lot of water inside the drum still, what should I do? is it normal?
Yes that is normal. That is your balance ring. It's an ingenious device that acts as a counterweight to keep the tub balanced. All is good.
Jan 12, 2013 | Whirlpool Washing Machines
What is the benefit of exercising with an exercise ball?
Exercise balls are air-filled and comfortable to use during fitness workouts. They are lightweight and durable. Some of the colorful exercise balls can support up to 600 pounds. It is not uncommon for the exercise ball to be referred to as a Swiss ball, stability ball, gym ball, or a yoga ball.
a. Improve Your Flexibility
b. Improve Your Balance
c. Strengthen the Core Muscles
d. Improve Your Flexibility
turning-your-home-into-a-gym-with-a-swiss-ball_top-image-zr2c4tcbdyndnypnhlbyyv23-3-0.jpg
Aug 06, 2012 | Exercise & Fitness
How to solve a moon shaped 3d crystal puzzle
23 20 21 3 post 14 18 10 15 17 7 8 1 16 12 11 9 6 5 2 19 4 22 13 then 13 22 4 19 2 5 6 9 11 12 16 1 8 7 17 15 10 18 14 3 21 20 23. Good luck (especially telling 6 and 9 apart)
Jul 07, 2012 | Puzzle Toys
My eson xs 200 printer problem is not print black ink ol catush is new
perhaps this is can be help you....
1. try to cleaning head
2. remove the black cartridge only, (if it doesn,t changed after you cleaned head)
3. provide some warm/hot water on a bowl or plate.
4. enter the HEAD of black cartridge in to hot water. soak with depth about 2mm up to 5mm. while you see the ink is come out....
5. after the black ink has come out. pat dry with a paper towels/tissue.
6. replace the cartridge in to printer.
7. cleaning head again and print test page
good luck
Jun 19, 2011 | Office Equipment & Supplies
Its for genius like you: If 6 and 2 = 22 4 and 3 = 1 8 and 2 = 46 Then what is the answer of: 7 and 2 = ? reply fast.
The answer is 33.
The formula is this: (x*x)-(x*y)-y
Formula application:
=(6*6)-(6*2)-2
=(36)-(12)-2
=(24)-2
= 22
= (7*7)-(7*2)-2
=(49)-(14)-2
=(35)-2
= 33
Hope this helps.
May 04, 2011 | Computers & Internet
Its for genius like you: If 6 and 2 = 22 4 and 3 = 1 8 and 2 = 46 Then what is the answer of: 7 and 2 = ? Reply in 5 minutes.
Feb 15, 2011 | Computers & Internet
If 6 and 2 = 22 4 and 3 = 1 8 and 2 = 46 Then what is the answer of 7 and 2 = ?
1. 6x6-((6*2)+2) = 22
2. 4x4-((4*3)+3) = 1
3. 8x8-((8*2)+2) = 46
similarly
4. 7*7-((7*2)+2) = 33
Dec 23, 2010 | Puzzle Jumbo Puzzle - Deco - Lakeside...
How do I perform multiple subtractions?
1. Enter your beginning balance
2. Press the minus (-) key
3. Enter the amount of a check
4. Press the equal (=) key. Balance will be displayed.
5. Press the minus (-) key
6. Enter the amount of a check
7. Press the equal (=) key. Balance will be displayed
Repeat steps 5 through 7 as necessary.
To enter a deposit:
5. Press the plus (+) key
6. Enter the amount of the deposit
7. Press the (=) key. Balance will be displayed
Don't press any other keys (i.e., Clear) until you have completed all checks and deposits.
Jan 28, 2010 | Canon P170-DH Calculator
Hanna pHep pH Meter with Solutions Logo
190 people viewed this question
Top Hanna Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Hanna Pool and Spa Expert? Answer questions, earn points and help others
