Useing for first time how to get started - Computers & Internet
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 10 Answers
What operating system? And, what appears when you start the computer?
Posted on Aug 28, 2010
2000 sebring 2.5 enging cranks doesent start right away some time it does all the time
Buy and use some maf sensor cleaner and some throttle body cleaner there both probably dirty and your computer is getting bad readings for start up
Dec 31, 2015 | 2000 Chrysler Sebring
I have a 2001 chevy cavalier will not start
See here:
have 2004 Chevy Cavalier have replace the ignition module like seven times...
Aug 10, 2017 | 2001 Chevrolet Cavalier
Car starts without using remote
Timed start. The timed start mode is activated by pressing the lock and unlock button simutaneously. The timed start mode is canceled by starting the car with the key or pressing the brake pedal while the remote starter is activated.
Jul 29, 2012 | AM7 Vehicle Security System with Remote...
How do I change the time
Best place to start is the manual:
http://waterheatertimer.org/pdf/Raindrip-R673CT.pdf
The manual shows Technical assistance 888-825-4716
Are you wanting to change current time? If not, then read manual, and then add a comment with detailed question and where you are in the steps.
To set current time, or change current time, Press TIME button.
Hour digits will flash.
Use the triangle buttons to scroll up or down and select current hour.
Timer uses 24 hour clock so 11pm is hour 23/ and 9pm is hour 21/ and 1 pm is hour 13.
Press SET to enter hour.
Minute digits will start flashing. Use triangle buttons to select. Then press SET.
Days will start flashing. Use triangle buttons to select. Then press SET.
Sep 23, 2011 | Raindrip R673CT Digital Water Timer
HOW TO CHANGE THE TIME ON MY DIGITAL WATCH IT HAS 4 BUTTONS ON THE TOP LEFT IS "LIGHT" ON THE LEFT "MODE" ON THE TOP RIGHT "START" AND ON THE RIGHT IS "RESET" THE...
Press "mode" until the hour is flashing,
Now press "start" to change the hour. When hour is correct, press "reset" and minutes should start flashing.
Press "start" to change minutes" then press "mode" again.
Oct 29, 2010 | Watches
Hello! How to program automatic reception of a fax after 4 calls (at the weekends, when at office anybody isn't present. Thank you. Best regards, Veronika
hi; Receiving Both Documents and Telephone Calls Automatically: Fax/Tel Mode If you set Fax/Tel mode, you can control precisely how the fax handles incoming calls by adjusting the following settings: ??? Adjust the time the fax takes to check whether a call is from a fax machine or a telephone (<RING START TIME> setting). ??? Adjust the length of time the fax rings when the call is a voice call (<TEL RING TIME> setting). ??? Set whether the fax switches to receive mode after the ring time set in <TEL RING TIME> has elapsed (<DEFAULT ACTION> setting). 1 Press [Menu]. 2 Use [{] or [}] to select <DATA REGSTRATION>, then press [Start/Copy]. The LCD displays <USER SETTINGS>. 3 Use [{] or [}] to select <RX SETTINGS>, then press [Start/Copy]. The LCD displays <ECM RX>. 4 Use [{] or [}] to select <FAX/TEL AUTO SW>, then press [Start/Copy]. The LCD displays <RING START TIME>. 5 Press [Start/Copy]. 6 Use the numeric buttons, or [{] or [}] to enter the time the fax waits before ringing when it receives a call, then press [Start/Copy] twice. 7 Use the numeric buttons, or [{] or [}] to enter the time the fax rings while waiting for someone to pick up the Handset, then press [Start/Copy] twice. The LCD displays <RECEIVE>. Note ??? If paper jams, see "Troubleshooting" on page 53. ??? If the Ink Lamp lights up faxes will be received to memory. 8SEC. 22SEC. Use [{] or [}] to select <RECEIVE> or <DISCONNECT>, then press [Start/Copy]. This setting tells the fax what to do if the Handset is not picked up within the specified ring time set in step 6. 9 Press [Stop]. Setting ends and the fax returns to standby mode.
Oct 14, 2010 | Canon FAX-JX200
Start \ timing
how do i check the timing.If it used to start...then very unlikely that timing slipped. Take it you have a good spark! to electrically/dynamically check timing you can use a strobe gun. Or take off flywheel and check position of the stator plate.,
Nov 10, 2008 | 2000 KTM Exc-Racing E 520
Start \ timing
Nov 10, 2008 | 2003 KTM EXC 525 Racing
Start \ timing
Nov 10, 2008 | 2002 KTM EXC 380
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
