Pentair Master Temp Heater is not heating and reading 126
    Visited the website for 60 consecutive days.
  • 121 Answers
Is it reading 126 all the time or only when you first start it up? will the fan run?
Posted on May 03, 2017
    New Friend:
Definitely bad thermistor Pentair reps have seen this happen a lot. Lick finger and touch the two contacts where the thermistor plugs in it should fire up if it's a bad thermistor. If you do an ohm reading you'll find that the ohms do not correlate with the temperature that's displayed. I just trouble shot one and I'm getting 51.2 ohms which equates to 10 - 20 degrees Fahrenheit which is obviously not what is being displayed because it's 126 which is a common number that's displayed when a thermistor is not reading properly
Posted on Apr 21, 2017
  • 128 Answers
SOURCE: Pentair Minimax Nt heater wont turn on and heat,
Bad thermistor. The yellow wire that plugs into the control board. Lick finger and touch prongs. Heater should come on
Posted on Aug 30, 2009
  • 10 Answers
SOURCE: Pump problems?
Their can be a number of things.. Is the pump priming. Hopefully it did prime. what usually happens after running for awhile, with no cool water coming in. The water inside the pump basket starts to heat up, then the tubing turns to brownish on the input side of pump and exhaust side. (you could have air leaking in throught the input side, which could result in the pump never priming) Or if it is priming and no pressure (can mean your empellar is clogged up)
Posted on Mar 11, 2009
SOURCE: Pentair Minimax Nt heater wont turn on and heat, "err" message
temp sensor get the new one with yellow wires.should do the trick.
Posted on Jun 05, 2009
SOURCE: Pentair pool heater reads HI
thermister needs to be replaced. follow small yellow wires off control board to front header and thats where the thermister goes
Posted on Jun 22, 2009
  • 15 Answers
SOURCE: Pentair Minimax NT 400 heater. fan keeps coming
Sounds like the controller is the problem. This is the circuit board that has the display and controls on it. You can swing that panel open and try tapping on the white plastic cover the controller is under that. This might get the fan relay to release but you will have to replace the controller it will stick again
Posted on Jun 23, 2009
When turning on power display reads 128 then error code r 13, after this it say's spa on but the temp reads 126 and the water temp is only about 68 so the heater never comes on.
This is not an error code. 128 r13 is the normal programming or software version for your model. you need to press the spa on button again, make sure the temp set point is higher then the actual water temperature
Mar 07, 2016 | Pentair Master Temp 400K BTU Natural Gas...
Pentair heater will not light
This could be a temperature sensor issue, however you should open the panel and look at the ignition control module, there is a red light that will flash and based on the number of flashes it may tell you more information. Open the panel the. Try to fire the heater and watch the light and see which flashing sequence it gives you, post back with that information and we may be able to figure it out
Dec 06, 2013 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
Temp reading 126 degrees
replace temp sensor or check manual bypass
Aug 21, 2013 | Pentair Mastertemp Heater
Brand spankin' new Master temp 400 NG,won't heat past 77° spa is set at 101°,pool at 88°, does heater pool/spa temps have to be manually set to max(104 i assume) for intellie touch to...
if the intellitouch is properly wired to the heater, it should all be automatic and you should be able to control it all from the remote.
there should be three wires connected to the circuit board behind the manual control on the heater (labeled "POOL", "SPA", "Common"). Those are the wires that the intellitouch uses to communicate with the heater.
You can download manuals from the Pentair website.
Aug 24, 2010 | Pentair MASTER TEMP HEATER 400 000 BTU NG...
1,599 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
