Question about Royal Office Equipment & Supplies
When I turn the shredder on, there's a high-pitched whirring sound that's almost unbearable. There is no "pull" into the machine, and it turns itself off after a few seconds. Any idea what's up?
    Genius:
  • 1,218 Answers
The high pitched sound may just be the motor running without driving any gears......you will have to take the top cover off (after you have unplugged the machine)...check and see if you have broken any of the plastic gears/teeth...phone Royal at 1-800-524-0799 for parts help.......BIG SECRET....don't put so many sheets in at a time.!!!!
Posted on Aug 28, 2010
When i turn the tv on, the lamp light flashes and my tv makes a high pitched whirring sound. does the lamp simply need to be replaced?
Thaat is probably right. Pull the lamp assembly out and check for physical confirmation of a bad lamp. Remember though that even if it looks good it may still be bad. Another possibility is a color wheel problem but try the lamp first.
Apr 06, 2011 | Samsung Televison & Video
My shredder won't take paper and makes a high whirring noise when in forward and reverse.
Sounds like the motor is spinning but not turning any gears or cutting shafts.... unplug, take the top cover off to see what is broken then give Royal a call at 1-800-524-0799 for parts.
Aug 01, 2010 | Royal 85MX Shredder
My 2000 Explorer makes a whirring sound when you accelerate - can this noise be due to a bent tierod? The previous owner had an accident involving the front end and was told that the tierod was haywire?
Typcially tie rods will only make a clunking noise or a squeak. The whirring sound if would suspect to be a wheel bearing. When you drive, slowly turn from left to right, if the pitch changes than its the bearing.
Mar 28, 2010 | 2000 Ford Explorer
Will not turn on, red light flashing next to the menu button
if the fans don't turn on, they may be bad and needs replacing or rewired. if the fans turn on but not the lamp, the colorwheel may be bad (listen for a high-pitched whir when you switch it on. if no whir, replace the colorwheel). if the colorwheel is ok, replace the lamp.
Mar 07, 2010 | InFocus ScreenPlay 4805 Multimedia...
Cannot turn engine over to start. Ariens 924 snow blower
pull spark plugs and see if it will pull over if not fuel may have filled the crank case drain & refill to proper level (starter is stuck in lube shaft & movethe gear up & down by hand to free up)
Feb 13, 2010 | Sport & Outdoor - Others
High pitched whirring noise in motor/fan?
the bearings in the motor are going bad. you probably need a new fan motor.
Nov 06, 2009 | Hotpoint HSM25GFRSA
Shredder not working, high pitched whine sound
Usually when you hear this it id from your motor locking up and trying to turn. DO NOT continue to run until you disassemble and check for problems. If it is jammed and you keep running you risk breaking your drive gears (if not already broken).
Oct 14, 2009 | Office Equipment & Supplies
The washing machine makes a high-pitched squeking
No, not if the noise is only when rinsing, if it makes the noise when spinning generally then possibly but if only noisy when rinsing sounds like a filter blockage on the waste pipe. clean out the filter behind the flap on the bottom of the front panel
Aug 21, 2009 | Maytag Bravos MTW6600T Top Load Washer
Intermittent non-starting caused by high pitched whirring when key turned in ignition
Hello;
The problem you are experiencing is one of two possiblilties. First, the bendix is weak in the starter. Best course of action is to replace the starter. When you pull the starter out, use a pry bar or screwdriver to rotate the flywheel an inspect the meshing teeth of the flywheel. If there is a section that has worn teeth then the flywheel needs to be replaced.
Thanks;
Rich
RPM Northwest
May 29, 2009 | 1987 Toyota Camry
144 people viewed this question
Top Royal Office Equipment & Supplies Experts
James Cagle
James Cagle
Michael Vincent Cruz
Are you a Royal Office Equipment and Supply Expert? Answer questions, earn points and help others
