Hi, The hard disk on my pioneer 633h-s does not appear. When the HDD button is pushed, it says disc not present. I cannot access it on memory. Does this mean the disc is damaged?
  • 1,512 Answers
Hi 031641
It sounds like you have a hard disk failure.... I found this info
.....The consensus does seem to be it indicates HDD corruption and your recordings will probably not be salvageable. (Supposedly it was recently discovered that some variant of Unix-Linux is able to pull files off Pioneer drives, but I have not yet seen a detailed report on how to do this- it may turn out to be urban legend.)
If all else fails and you are willing to risk losing the drive contents, you could try removing it, connecting it to a PC running Knoppix, and deleting/replacing the TV Guide-Timer system programming (this gets corrupted fairly easily during power spikes). Go to the "Pioneerfaq" website for details how to do this and assistance obtaining the service disc and remote emulator. You may need help from someone who knows Linux/Unix commands: the instructions are basic and do not include information on how to delete the corrupt software from an existing drive, only how to install it on a fresh drive. I think its worth a shot to reverse-engineer a delete-reinstall: if I came across a unit with this boot-wait problem I would definitely try it. If the Knoppix command line is edited correctly, it should be possible to delete the damaged TVGOS-Timer software from the boot partition and re-install a new copy WITHOUT touching the partition that has your recordings on it. Then you might be able to reinstall it in your 533 and get it to work long enough to copy the contents to DVDs.
Chances are the drive is completely hosed, tho. I have had both earlier Pioneer models, 510 and 520, pass thru my hands with similar symptoms. Those units do not have any Pioneer software on the HDD that would get corrupted: the drives simply tank. Once replaced with new drives, both recorders worked perfectly for their owners and are still going strong a year later. DVD recorders are not full-scale PCs with semi-automated maintenance routines: their operating systems are very crude and all it takes is a couple of bad sectors to appear on the drive for the recorder to totally trash it. Doesn't happen often, but it does happen.....
You can see more about Pioneer HDD failures at this forum. Hope it helps you. If all else fails, then its off to Pioneer
e-mail or call at (800) 421-1404.... :)
robotek
Posted on May 06, 2008
How do you go about to format a toshiba l650 and reinstall windows 7
Hi! If you have the Windows 7 disc just insert it restart the computer. It will boot directly from the disc. Then follow the step by step instructions here.
If you don't have the Windows 7 disc, you have two ways to reformat your Toshiba computer.
Using Toshiba HDD Recovery Utility from the recovery partition
In case of a hard disk drive failure, you may be able to restore the drive to the factory default state using the on-disk Toshiba HDD Recovery Utility (in a special partition on the hard disk drive).
You can select restoring the entire hard disk drive to the factory default state, or restoring only the C: drive -- without affecting other partitions (for example, a D: drive) -- or changing the size allocated to your C: drive, and then restore it.
To recover your hard disk drive from a system failure using the utilities stored on your computers HDD, follow these steps:
  1. If the computer is running, shut it down -- by clicking Start, Shut Down, and again Shut Down.
  2. Press and hold the 0 (zero) key on your keyboard and then press the computers power switch. When the computer turns on, the Toshiba HDD Recovery Utility screen will appear, presenting three options:
Sample TOSHIBA HDD Recovery Utility screen
Restore Original Factory Image (Recommended)
CAUTION:
Restoring a hard disk drive to its factory default state deletes all partitions on the hard disk drive and all data stored on those partitions. All of your files and information will be lost! Be sure to back up all important files first.
  1. Press 1 to restore your hard disk drive to its original factory default state. A confirmation message will appear, indicating that all data will be overwritten and lost during the restore process. Be sure to back up all important files before proceeding.
  2. Click Yes to begin the recovery. A message will appear once the operation is finished, indicating the HDD has been restored.
  3. Press any key to restart the computer.
* The options 2 & 3 are for advanced users.
Hard Disk Drive Recovery using Recovery CDs or DVDs
You may also wish to to run the Toshiba HDD Recovery Utility from Recovery CDs or DVDs that you have created.
Insert the first Recovery CD or DVD into your CD/DVD drive, and turn on the computer. Once the computer is running, the TOSHIBA HDD Recovery Utility screen will appear, presenting the same three options above. Again Press 1 to
restore your hard disk drive to its original factory default state. Click Yes to begin the recovery. Press any key to restart the computer.
Installing Drivers and Applications
The TOSHIBA Application Installer allows you to reinstall the drivers and applications that were originally bundled with your computer.
To reinstall drivers and applications:
  1. Double-click the "Toshiba Application Installer" icon on the Windows desktop. This utility may also be launched by clicking Start -->All Programs --> Hard Disk Recovery Utilities.
  2. Click "Next".
  3. Click the item(s) you wish to install. To select multiple items, hold down the Ctrl key as you click your selections.
  4. Click "Install".
  5. Follow the on-screen prompts to complete the installation process.
Hope this helps.
Jun 19, 2011 | Toshiba Computers & Internet
Pioneer HDD DVR DVR630H - in Australia
When fitting a replacement hdd the hdd must be paired with the DVR using the Service Remote Controller used only at Pioneer Service Centres.
Mar 17, 2017 | Pioneer DVR630H DVD Recorder
DVR633H timer recording screen inaccessible
I had the same problem. Contacted Pioneer tech support, they had me send the machine in even though it was out of warranty; apparently a hard drive problem that they were researching. They sent it back with HDD replaced, worked again.
Sep 08, 2008 | Pioneer DVR-633H-S
Pioneer Dvr-633h-s
This idea may work when a multitude of devices become erratic in function, display info on the screen that is incorrect or just won't work at all.
Lightning strikes near by (even with the device connected to an isolation strip) power interruptions and excessive heat can cause electronic equipment to mal function.
Do the following:
Make certain that the device has ADEQUATE VENTILATION!
Remove all dust from the grill in the back of the unit in the fan location.
Un plug the device for at least 24 hours and permit any stored current to drain from the unit.
Then restore current to the device.
If the problem persists, plug and unplug the unit several times, observing the change in the screen, until the info there changes to the proper display.
If this does not work, you need a tech assist.
Angelo.
Jun 28, 2008 | Pioneer DVR-633H-S
How do i access the Hard Drive out of a Wharfedale DVDR24HD160F 160GB HDD DVD Recorder
hmm...similar problem here. i've taken the hdd out and plugged it in to the ide port inside my pc. The problem is it's the wrong file system. Your pc will not see it. It is however just a normal hdd so you can re-partition it and give it a new file systm ie ntfs but you lose all the data :(. that's as far as i've got, hope it helps someone.
Apr 06, 2008 | Wharfedale Televison & Video
Pioneer DVR-633H-S hard drive problem
do the Reset to factotry settings,hold two buttons same time {STOPand STANDBY}on front off your unit and unplaged the power from the wall same time.wait like 5minutes,and pluged back the power,this my work,did work for me.
Dec 10, 2007 | Pioneer DVR-633H-S
Repairing disc message won't go & DVD disc won't eject
By pressing the Power button for >10 seconds you can force the unit to turn off. Immediately as the unit does, press the disk eject button and the defective DVD can be removed. Don't put it back in, or the problem may repeat!
Nov 17, 2007 | Pioneer DVR-530H-S DVD Player/HDD Recorder
Cannot record DVD-R's
I could not record DVD-R's on my 633H.
Calling Pioneer I was told that I had to use DVD-R's rated no more than 4X.
I ordered 4X DVD blanks and have not had a problem since.
However, when I told the service man at the hi-end store where I bought the unit what Pioneer had said and that it fixed my problem, he said it was baloney and to bring it in and he'd have them fix it - that it should handle DVD's supporting higher write speeds.
I didn't take it in as the 4X blanks are cheaper and I don't want anyone mucking around in my machine when it is working OK..
Oct 30, 2007 | Pioneer DVR-633H-S
Hard Disk error
power up your dvd then you you disconnect from the power cord.wait a few mins like 5 mins then you plug it in back and power it up if that does not corect your problem.the strip that leads to your dvd lens needs to be changed.or the micro chip that controls the hd needs to be changed.however take it to a tech.
Feb 19, 2007 | Pioneer DVR630H DVD Recorder
Televison & Video Logo
185 people viewed this question
Top Televison & Video Experts
Electro Med Services...
