Question about HP Pavilion F1503 15" LCD Flat Panel Monitor
I cant find the microphone on my f1503? does it even have a microphone? How about a webcam?
Webcam not detected on skype
Hi Shane,
Thank you for contacting fixya.
Try to install latest webcam driver downloaded directly from laptop manufacturers website. it will help you to get your webcam on skype.
Feb 09, 2014 | A4tech PK-635 Webcam
Connect camera to skpye
click start control panel view devices and printers you should see your webcam from there
if you are have trouble with your webcam
click start right click on my computer select properties then device manager scroll down image devices you could see a yellow question exclamation mark? ! or a red X
right click to reinstall drivers or update driver W7
click start control panel administrive tools computer management device manager scroll down image devices you could see a yellow question mark?
Some webcams and programs require additional software, although that should be installed with the webcam if things are right.
But is does not harm to check if your Java, Flash and Quicktime software are installed and up to date.
But certainly check your DirectX software, since all video applications, including webcams, use DirectX for video processing.
Try downloading the latest DirectX version and install it (Windows XP: DirectX 9.0c - Windows Vista: DirectX 10).
http://windows.microsoft.com/en-US/windows7/Which-version-of-DirectX-is-on-your-computer
also during a video call at the top of your screen you will see an option to for a video call using yahoo messenger this might vary if you are using another messenger service
open skype go to tools from the drop down list select options scroll to audio settings
you can make a free test call before you try to make a call
make sure the microphone is using the same as your computers audio
you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment
click start control panel sounds and audio devices audio and also voice it's the same make sure that you have the right default microphone selected you should be able scroll to video settings to make sure you have the right settings
Open skype go to tools options scroll to audio settings or video settings on the right you will see webcam setting you can change the settings from there click apply after changing any settings also you can see the webcam there you can even take a snapsot also make sure your settings are correct for a video call
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick also
select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or
select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this helps
Oct 29, 2012 | Sony VAIO PCG-7181L, PCG-7182L, PCG-7183L,...
I cant make a videocall with skype using my genius webcam
click start control panel administrive tools ,computer management ,device manager scroll down image devices you could see a yellow question mark?
update driver
you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment also
Aug 06, 2011 | Computers & Internet
Hi i have an a4tech pk-336e but i cant get the microphone working., or does it have a microphone?
Hi there!
This web cam comes with a built in microphone.
You can check the wire connection and see if there is any problem. If it is OK, then try re-installing the software both for the webcam and microphone.
Apr 11, 2011 | A4tech PK-635 Webcam
Does C250 have HD. I am unable to hear another skype caller, can see her picture; she is unable to hear me. Can C250 be operated without video
Open skype go to tools options scroll to audio settings or video settings you can see the webcam there you can even take a snapsot also make sure your settings are correct for a video call
Jan 31, 2011 | Logitech C250 Webcam
Does this moniter have a microphone? have a webcam to set up.
No, your monitor does NOT have a Mic, built in. You will have to use an external one, either in the RED Jack at the rear or front of PC, or a USB, one. (recommended)
Sep 04, 2010 | HP Pavilion F1503 15" LCD Flat Panel...
Webcam when connected they can see me but cant hear me
When you bought it, did you check to make sure it has a microphone built in? Also, do you have the microphone volume turned up loud enough?
If your webcam has not got a built-in microphone then you need to purchase a separate microphone or you could go back to the shop and swap it for one that has one :)
Jul 20, 2009 | Microsoft Life Cam Vx-5000 Webcam
Microsoft VX-5000 Webcam
Thru the program your using for the microphone, see if there is a way to change the volume thru there just to make sure the program isn't messing up the microphone.
If you still can't get it to work then we know the microphone portion of the webcam is definitely defective but at least in this way we will havve verified it properly.
May 23, 2009 | Microsoft Life Cam Vx-5000 Webcam
Icannot get webcam microphone to work.how do i hook up microphone
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Mar 14, 2009 | Logitech Quickcam Chat Webcam
My technika web cam
Spin the black circle at the front until it focuses. try both directions
Jun 12, 2008 | Veo Stingray
HP Pavilion F1503 15" LCD Flat Panel Monitor Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
