Question about Janome MyExcel 3123
I have a Janome ML 3023 and I want to make a top out of a stretch knit fabric but I'm not sure what my settings should be. Or if number 14 is the best stitch for the seams. I also want to do top stitching so is that just the straight stitch?
  • 106 Answers
SOURCE: Can't get a neat straight and stretch stitch underneath
Sounds like a bottom tension problem, to be sure I would have to have a look, I would suggest you have it looked at. Not sure about the materials you are sewing and have serious doubts as to whether the machine you are using is up for the job and will give you a satisfactory finish. It is possible a "walking foot" machine is what you need.
Posted on Mar 26, 2008
bargainbox
  • 1388 Answers
SOURCE: My Janome my excel 23x
Ensure that all is clean and free of lint jams....now for tension troubleshooting .......
This solution is for tension problems...if you cannot form any sort of stitch, the issue is quite different, so please let me know if you need a different problem solved.....
It is quite long, but just work through each section in order.
The "knotting up" can reveal a lot. If you have loose threads on one side or the other, the tension on the opposite side will be the culprit.
QUICK SUMMARY FIRST:
Ensure sharp new needle,
Thread guides and Bobbin are Clean & Clear of lint
Set Top Tension to 4 ....then....
Balance Bobbin to suit.
TOP THREAD TENSION:
If the looping threads are on the underside as you sew, it is the top tension. Top tension ought to be between 4 & 6 (this variation to allow for the different weights of fabric in your
projects).
IS YOUR NEEDLE SHARP ?
If you are using a needle that has seen quite a deal of work, or you suspect it may be blunt, change it for a new one !
TOP TENSION & GUIDES:
Make sure that when you thread the machine the presser foot is up so the thread goes between the discs and not to one side, top tension between 4 and 6, and that you have threaded through all the guides, including the last one, usually on the needle arm, just above the needle clamp.
It may be there is lint trapped between the discs, this will keep them slightly apart and reduce the actual tension, sometimes dramatically.
If tensions appear correct, and the thread is definitely in the channel between the discs, but still too loose and looping, try raising presser foot and remove your thread.
Now, with a 2" (50mm) wide strip piece of fabric 8 - 10" (20 - 25cm) moistened with methylated or denatured spirit, gently insert the fabric strip and clean between the discs with
a see saw / to and fro action.
In the worst cases, gentle use of a needle to pick & remove the jam may be necessary, but be very gentle and make sure the tension is set at Zero and the presser foot is raised, (to
disengage tension plates).... do not gouge or score the plates, they need a polished surface to work correctly.
BOBBIN TENSION:
Far less common, but if the loose threads are on the top, it is bobbin tension that is loose, it too may have lint in the spring and be giving a "false" tension.
I would not recommend fiddling with bobbin tension without good reason, it may end up with missing small screws and spring pieces, however, you can take the needle plate off to clean
the hook race area (where bobbin case sits)
...this is just good housekeeping, my wife does this every time she replaces the bobbin....
just take it out and clean the bobbin case and the fixed metal hook race with a small brush to remove lint. If there is a significant amount of lint, use a vacuum and small brush to get the worst.
Then wipe all this area with a cloth or cotton bud (Q tip) moistened (not soaked) with methylated spirit, especially if there appears to be fine dirty deposits....oil and lint combine to conspire against you.
If it seems likely that you ......really ....do .....actually .....need .....to adjust the bobbin case, first check there is no lint trapped in the metal spring where the thread is tensioned.
TOP LOADER:
Drop-in Bobbin case will look similar to this image with the tension screw in the middle of the metalwork....
4c76dc1.jpg ...the other screw at one end is holding it all together, so beware....it is not a tragedy to undo the whole lot and clean it, but very gingerly and lay the bits out in sequence and orientation, or you risk tearing your hair out !
FRONT LOADER:
....this is a bobbin case from a front loading machine and works in a very similar fashion to the top loader with drop in bobbin, again, if you dismantle it, take care so you can put it all
back properly.
165ca5c.jpg FINISHING UP
GETTING THE BALANCE RIGHT:
When you are certain there's no trapped lint in top tension or bobbin, set the top tension to 4 and the bobbin tension to a point where you just begin to feel resistance.
Try using good quality thread of contrasting colours so you can more easily spot the changes.
Set your zigzag to one width less than maximum (eg. 5 of 6 ...or... 4 of 5 etc) and sew a sample for a few inches and check the result.... adjust the bobbin tension screw very little at
a time, perhaps 1/16 of a turn.
You may find you are playing with this balance for some little while and if you are putting the needleplate on and off each time begin to think it cannot be correct to do this.....BUT....it is,
and eventually, you do get a "feel" for the correct tension and then it happens quite quickly.....as a user you won't be doing it very often unless there is lint built up (or are there small hands at work around the house !?!?!)
OTHER ISSUES:
If you live near the ocean as we do, salt air can play havoc with metalwork inside and out, so to help minimise this, keep a few small packets of dessicant (silica gel) in your machine
case....no case ? then make some sort of cover !
Same applies in any damp or humid environment, keep your machine dry and dust free.
Budget for a proper full service every couple of years (more often if heavily used) and if you don't use your machine for a few years, be aware that old oil will dry out and combining with
dust and form a "clag" like glue (another reason for some sort of cover, even a teatowel !)
FINALLY, A WORD ON THREAD:
If it is worth spending the time, energy and money on making something that you would like to give lasting enjoyment......use quality thread, .......it may seem to cost a little more at the
time, but the results, ease of use and added longevity will be worth the extra, and as a bonus, your tension troubles may be fewer and further between, because there is a more consistent diameter with good thread, and less compensating to be done by your tension plates and less thread breaks !
If you want any more help with this, just post back here, or, drop a line through the "Contact Us" page at www.bargainbox.com.au
Posted on Apr 25, 2008
  • 980 Answers
SOURCE: I am working of stretch knit fabric and my
You must use an anti static needle or stretch stitch needle.
Posted on Jul 01, 2009
SOURCE: How do I overlock stretch fabrics so the stitches
I suggest also setting the stitch length to about 2 (very close together). When the stitch is shorter, it seems to be able to give a little more. I also use woolly nylon, but I still had the problem (especially when hemming). This is how I solved my problem....
Posted on Feb 28, 2010
  • 980 Answers
SOURCE: MC4400 skips on the zig zag stitch when sewing
You must buse an anti static needle otherwise yoiu will miss stitches.
Posted on Jul 14, 2010
I have an Elna Junior Club sewing machine and I am sewing Lycra and using the number 14 stretch stich. It just loops and bunches up underneath even though I have set everything as instructed.
Did you pre-wash the fabric? Sometimes the finish applied at the factory causes problems. Also, be sure to use a ball point needle on knit fabric. Sometimes, using a walking foot, teflon foot, or roller foot will help the fabric move smoother through the machine. It could be that your machine is experiencing a problem with the back-n-forth movement of the stretch stitch. Otherwise, here are more guidelines to review:
30 Best Tips for Sewing Knits with Serger Sewing Machine Serger Pepper
Sewing Spandex Tips
Feb 02, 2017 | Elna Sewing Machines
Looking for free manual for Kenmore 12511. or instructions on how to a just machine to sew stretchy material
Sears carries a lot of Kenmore manuals, however, there is usually a fee. Have never seen one for no cost.
BTW--be sure to use jersey or stretch stitch needles (ball point) for knit fabrics. You probably should use either a zig-zag or stretch stitch so the threads don't "pop" when the fabric overstretches the thread.
https://www.seamwork.com/issues/2015/06/knits-without-a-serger
search the internet for "sewing stretch fabric" or "sewing knits"
Apr 15, 2016 | Kenmore Sewing Machines
When I sew knits, the stitching is never tight enough. I have a Singer 7258. It is very loose and looks bad. What settings should i use when sewing knits?
here is a link for a free manual for the machine, it should have the information you need in it,, always use a scrap piece of fabric your sewing to adjust the tension, when adjusting the top thread tension do it one number or letter at a time and then sew on the scrap fabric, until you get the desired stitch you want.
http://www.singerco.com/uploads/download/617_7258-instruction-manual.pdf
Needle types
There are three main types of needles that are used for the majority of sewing, as well as many specialty needles.
Universal needles have a slightly rounded tip, and this general purpose needle should be used on wovens as well as some sturdy knits.
Jersey needles have a medium ballpoint tip designed especially for knit fabrics because it slips between the knit fibers and does not break or damage them while sewing.
Stretch needles, often confused with Jersey needles, are also a medium ballpoint tip, but these have a special eye and scarf that are designed for extremely stretchy fabrics and elastic. Swimwear is an ideal application for this type of needle.
Jun 18, 2015 | Sewing Machines
Singer 534 skipping stitches
Most sewing machines will sew well on sturdy woven fabrics without being perfectly adjusted. However, because knit fabrics have more stretch, and have a tendency to pull the needle in one direction or another, a sewing machine has to be very well adjusted to sew on them well. You needle clearance or timing could be slightly off, and would cause the machine to skip on knits. Unless you have a reasonable amount of experience with adjusting sewing machines, it would probably be best to take your machine to a repair shop to get it adjusted. Make sure you tell them what kind of thread and material you are working with. Take some samples if you can.
Mar 19, 2014 | Janome Sewing Machines
Troubleshooting guide
if it is skipping stiches check to see if you are using the right needle for the fabric sometime on knits or fabrics with stretch in them you need a needle for that type fabric also check the tension
Dec 10, 2013 | Janome Sewing Machines
Knit stitch problem
I know this is easy to say, but make sure your machine is threaded properly. And try sewing a piece of knit fabric without the knit stitch. You can still sew seams etc this way if you very slightly stretch the fabric as you sew.
Sep 07, 2017 | Singer Curvy 8770 Electronic Sewing...
Janome machine probs
try a ballpoint or a stretch stitch needle, that what I use when sewing
knit, t-shirt. it doesn't break the fiber in the fabric.
Jun 05, 2012 | Sewing Machines
What would be a "stretch" stitch setting?
For a stretch stitch use a narrow zig zag stitch. Use a ball point needle with knit fabrics.
May 30, 2017 | Sewing Machines
When sewing elastic type material it keeps knoting
you may need to use a certain type of thread for jersey knits and stretch fabrics also your machine should have a setting for stretch stitches to allow for smoother sewing
Dec 11, 2009 | Janome Memory Craft 5700
Sewing Machines Logo
60 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
