Question about Frigidaire FEF366 Electric Kitchen Range
The lower element burned in my oven. I replaced the element, but the oven will not work.
  • 139 Answers
Unplug range ..remove the back cover plate check all wires all connections ..their must be a burnt /broken /dissconnected wire ..check where the wires connect to the bake an broil element ..and the bake broil switch..if all looks good .then the bake broil switch burnt out when element blew out..plus is the breaker tripped in the box ..it prob. tripped when the element blew out..let me know..good luck
Posted on Aug 28, 2010
Lower oven heating element burned out on my **********0 kenmore range i replaced it but oven still won't work any idea's?
If the element you installed is good , then you do not have your voltage to the element. Thea is because there is an interrupted circuit, maybe an internal iven fuse or your oven breaker in the breaker box in the house
Mar 03, 2016 | Kenmore Dryers
My FiveStar TPN335-GW range oven won't turn on
Did you try both BAKE and BROIL?
If neither work, then it is highly unlikely that both elements burned out at the same time.
If it works on BROIL (upper element) then you should suspect that the lower (BAKE )element is burned out and needs to be replaced.
If you have someone qualified in house to test the continuity, then i would do that othewise call a repairman and suggest it may be the element.
Aug 22, 2015 | Ovens
I have GE model#JKP45WOP2WG double oven wall unit. Lower oven isn't heating up properly. Bottom of lower oven doesn't seem as hot as the top of the oven... replaced oven sensor, not
Most double wall ovens are technically two separate oven boxes. The lower oven box has its bake, boil elements, high limit thermostat and ofcourse its own oven sensor. If the lower oven box boil is working good and less heat on bake feature may suggest that the bake element is burned out and only getting preheated with boil element. Just a suggestion here
Dec 05, 2014 | GE Ovens
Whirlpool gold double oven model #gbd307pdb. upper oven lower heating element burned out. replace lower element. it does not get hot. upper element heats up. control board works. is this the thermos
You will have to see if there is power to the element. It is possible that the relay contacts burned when the element burned out. There is a fusable link but this would shut down both the top and bottom elements. If the relay is burned out the control board will need replacing or rebuilding.
Oct 28, 2014 | Ovens
The heating element in the lower part of the oven burned. I was almost like a welding rod, it kept burning even when we had the oven off. I turned the power off at the fuse box before it finally stopped....
This sounds more like the electric control dial thermostat, keeping power on at the element, both element and control dial will need replacing
Jul 11, 2011 | Maytag Ovens
Bake element
It may have also Blown the Fuse, to the element, in the stove itself.
Feb 12, 2010 | Dacor ECD230 Epicure Electric Double Oven
Lower oven element started to burn. Using both ovens when this happened. Shut off lower oven but element continued to burn. had to pull main breaker to get it to stop
This is a common problem that happens when the elements start to burn out. We have elements in stcok that we can send to you to replace.
Just contact us at:
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
from 7 AM until 7 PM CST and we will get the correct part out to you asap,
We look forward to getting you cooking again soon!
Thanks, Ella
Jan 17, 2010 | Maytag MER6772 Gemini Electric Kitchen...
Lower oven element doesnt work
You can usually tell when the element itself burns out. It might have small holes or bubbles on the coil. Replace the element, if found defective.
It will , also, show no continuity when measured with a meter as well.
Jul 12, 2009 | GE Ovens
Kenmore oven lower element sporadically heating.
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
Is it easy to replace the lower element on a jtp 15 GE oven? While the wife was baking last week, the lowere element burned out. Was wondering if I could replace it myself
Easy replacement. Make sure to unplug power or shut off breaker. remove 1/4" hex screw on back of element. Pull off female terminals or some have screws. Install new element the same way.
Mar 23, 2009 | GE JTP15 Electric Single Oven
Frigidaire FEF366 Electric Kitchen Range Logo
300 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
