Question about Fisher and Paykel Washing Machines
When i turn the machine on the lights come on then go of again and sometimes don't come on at all
  • Fred Camp Aug 28, 2010
    tried that . the lights came on for two seconds then went out again
    i realise this is the problem, where can i purchase a nother panel in sydney
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described the issue seems to be with the control panel that has gone bad however, before replacing it you can take a hair dryer and blow air if there is some moisture this will blow it off. If still its not resolved then you’ll have to replace the control panel. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 28, 2010
  • Rylee Smith
    Rylee Smith Aug 28, 2010
    OK, if you have already checked loose connections then the issue is with the control panel that is bad and should be replaced.
  • Rylee Smith
    You can either contact Fisher and Paykel customer service or purchase parts from this link. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
How to clear a epc light from golf 5 fsi engine
If U don`t have VAGcom to read and erase the errors try first the brake switch if its ok (sometimes the brake lights remain turned on even if the brake pedal is released and this cause the epc light on).
If you see a engine speed decrease when epc turns on the error could be from admision *(air intake) pressure sensor . You can disconnect your battery minus*(ground) for 10 or more minutes to turn off the epc light but if you don`t resolve the problem epc will turn on again when U start the engine. My advice is to find a Diagnose cable and read the error to know exactly what is the problem
Jan 18, 2018 | Volkswagen Golf Cars & Trucks
Turn signal failure
The bulbs all have to be good for the flasher to work. The flasher is under the dash, driver side. When you turn on a blinker, do you hear it clicking under the dash. If the turn light is on , on the dash , but not flashing, then a bulb is probably bad on that side. Leave the blinker on and walk around the vehicle to check the lights. Flip the blinker to the other side and walk around the vehicle again checking lights. If all the lights are lit, but not blinking, then the flasher is most likely bad.
Dec 05, 2013 | 2000 Chevrolet Venture
Lights flashing during cycle
This should take 30 minutes: Remove the panel that is located below the front door, there are 3 small screws located at the bottom that hold this... you will see the water pump, which has a access screw plug. Unscrew this, its like a filter, you may see stuff, like coins, socks, etc, remove and clean out, then put everything back... this should fix the issue.
Before you re-fit the filter check to see that the blades of the pump further inside are turning well - no blocks. If the prob still persists you must examine pump.
http://www.youtube.com/watch?NR=1&v=4IBvHbQ_3pA&feature=endscreen
If helped click helped.
Apr 27, 2013 | Kenmore HE2t 3.7 cu. ft. Front Load Washer
Computer will not turn on. when power button is pushed, battery and power cord lights flash on and off. Plugging in does not help. How can I make my computer work again?
Try doing this:
1. Remove the battery and unplug the computer.
2. While there is no power connected, press and hold the power button for 30 seconds
3. Plug the computer back in, but don't insert the battery yet
4. See if it will turn on now, and if it does, insert the battery again.
Sometimes this works to drain some residual power that is still inside the machine. I've done this on a couple of machines and it has resulted in them starting up fine. If this doesn't work, you may have a more serious problem and need to have it looked at by a technician.
Aug 25, 2011 | Lenovo ThinkPad T61 Notebook
I am trying to descale my solis palazzo, I did as instructed, opened the nozzle to let water out, light is flashing but nothing is happening, waited 45 minutes, the only button lit up is the one with the...
Hi Descaling the Palazzo: The Palazzo is programmed to descale the boilers on its own, when set in the correct mode. You program the machine to descale it's self, do the following. With the machine turned on, push and hold the left 2 buttons (clean and pre-ground). This should light the top right red indicator light. Mix your descaling crystals in 32 to 48 oz in your water tank. Stir until they are completely dissolved in the water. Next, have a container that can handle about 2 quarts of water under the steam wand, or have the machine positioned next to a sink. Next open the steam knob on the right side of the machine. You should hear the pump turn on and pump about 2 to 3 oz's. of water through the wand into the container. The pump should turn off and there will be a wait of about 2 minutes. The pump should turn on again and more water will come out. It will do this until it has completely drained the water tank. Do not interrupt this cycle until the machine has stopped on its own. When it does stop, all lights on the bottom will flash. Rinse out the water tank and refill with fresh water. Place the water tank on the machine again, and then close, and then open the steam knob again and let the water just flow through the boilers until it is emptied by the machine. Don't turn off anything until the machine stops on its own. This will clear the descale light. Refill the water tank again with fresh water and push the water button on the right. It will light(very dim), then open the steam knob again/ The red light will go out and it will start to heat and your ready to go.
Jul 05, 2011 | Solis Palazzo Espresso Machine
I have a Ford Explorer '07 4.0. Engine light turned on sometime back in January and it went off on its own. Now its May & Engine light once again turned on. Any solution?
First have the code checked. Parts store can do it. If you don't post a symptom, We can't diagnose. The light can come on for 100's of reasons. some as simple as the gas cap is loose. Let me know. I will help. Randy
May 20, 2011 | 2007 Ford Explorer Eddie Bauer
I have lost my instruction manual and the last triangle light is on what does it mean and how do i fix
Descaling the Palazzo: The Palazzo is programmed to descale the boilers on its own, when set in the correct mode. You program the machine to descale it’s self, do the following. With the machine turned on, push and hold the left 2 buttons (clean and pre-ground). This should light the top right red indicator light. Mix your descaling crystals in a glass of warm water then add to 32 to 48 oz in your water tank. Next, have a container that can handle about 2 quarts of water under the steam wand, or have the machine positioned next to a sink. Next open the steam knob on the right side of the machine. You should hear the pump turn on and pump about 2 to 3 oz’s. of water through the wand into the container. The pump should turn off and there will be a wait of about 2 minutes. The pump should turn on again and more water will come out. It will do this until it has completely drained the water tank. Do not interrupt this cycle until the machine has stopped on its own. When it does stop, all lights on the bottom will flash. Rinse out the water tank and refill with fresh water. Place the water tank on the machine again, and then close, and then open the steam knob again and let the water just flow through the boilers until it is emptied by the machine. Don’t turn off anything until the machine stops on its own. This will clear the descale light. Refill the water tank again with fresh water, open the knob on the right again to prime and when the red light goes out, your ready to go.
Sep 08, 2010 | Solis Palazzo Espresso Machine
How do I get the water heater to turn back on after the descaling.
The Palazzo is programmed to descale the boilers on its own, when set in the correct mode. You program the machine to descale it’s self, do the following. With the machine turned on, push and hold the left 2 buttons (clean and pre-ground). This should light the top right red indicator light. Mix your descaling crystals in 32 to 48 oz in your water tank. Stir until they are completely dissolved in the water. Next, have a container that can handle about 2 quarts of water under the steam wand, or have the machine positioned next to a sink. Next open the steam knob on the right side of the machine. You should hear the pump turn on and pump about 2 to 3 oz’s. of water through the wand into the container. The pump should turn off and there will be a wait of about 2 minutes. The pump should turn on again and more water will come out. It will do this until it has completely drained the water tank. Do not interrupt this cycle until the machine has stopped on its own. When it does stop, all lights on the bottom will flash. Rinse out the water tank and refill with fresh water. Place the water tank on the machine again, and then close, and then open the steam knob again and let the water just flow through the boilers until it is emptied by the machine. Don’t turn off anything until the machine stops on its own. This will clear the descale light. You will have a steady red light and the green light will be blinking. Refill the water tank again with fresh water, close then open the steam knob, this will clear the red light and your ready to go.
Nov 07, 2009 | Solis Palazzo Espresso Machine
Water tank light is flashing with main heating light
HI
I don't think your machine is finished descaling. Follow these steps.
With the machine turned on, push and hold the left 2 buttons (clean and pre-ground). This should light the top right red indicator light. Mix your descaling crystals in 32 to 48 oz in your water tank. Stir until they are completely dissolved in the water. Next have a container that can handle about 2 quarts of water under the steam wand, or have the machine positioned next to a sink. Next open the steam knob on the right side of the machine. You should hear the pump turn on and pump about 2 to 3 oz’s. of water through the wand into the container. The pump should turn off and there will be a wait of about 2 minutes. The pump should turn on again and more water will come out. It will do this until it has completely drained the water tank. Do not interrupt this cycle until the machine has stopped on its own. When it does stop, all lights on the bottom will flash. Rinse out the water tank and refill with fresh water. Place the water tank on the machine again, and then close, and then open the steam knob again and let the water just flow through the boilers until it is emptied by the machine. Don’t turn off anything until the machine stops on its own. This will clear the descale light. Refill the water tank again with fresh water and your ready to go.
Apr 13, 2009 | Solis Palazzo Espresso Machine
Washing Machines Logo
13 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
