Question about Canon PowerShot S1 IS Digital Camera
Canon A75 Battery door
Canon A-75 directions to remove and replace battery door
I have a canon S1 IS camera with a broken battery door. I have ordered and received the new battery door, but am at a complete loss as to how to take out the old one and install the new one. If anyone has some pointers, or better yet step-by-step instructions with pictures (never hurts to ask!) I would greatly apprciate it.
  • Canon Master
  • 4,738 Answers
Never did it on an S1, but on other models it required removing the back face of the camera to access the battery doory hinge pin.
Examine your camera, and if this sounds feasible, remove all screws along the perimeter of the camera (keeping track of their sizes and where they came from, write it down with a crude drawing of their locations/sizes). Also look for screws in the battery compartment, and any visible screws behind flaps/doors. Once all perimeter screws are removed, you should be able to remove the back face of the camera by prying it open from the bottom. Once opened, the pin holding the battery door should be able to be slid out, enabling removal of the old door. Then in reverse slide the pin into the new door, and reassemble the camera and its screws.
Posted on May 07, 2008
Camera won't turn on
1. Most likely is discharged or improperly inserted batteries. Make sure to use freshly charged AA batteries that are inserted with the correct polarity. The Inner 2 have the minus side up and the outer 2 batteries have the + side facing up.
2. Close the battery door fully because the battery cover pushes on a small sensor that has to be closed before the camera will turn on. The battery cover slides and clicks into place. If the battery cover sensor is bent or damaged then the camera would not turn on. The battery cover sensor is tiny, and out of the way and probably not obvious that is has one.
3. Insert the proper memory card and close the memory card cover securely. If it's left open or not seated fully the camera may not turn on. I
4. Also remove the memory card and re-seat it, then close the cover again in case it was not fully closed.
5. Remove the batteries and check that the battery terminals are clean and they appear to be intact. For example, corrosion from leaking batteries could cause a poor connection.
6. Was the camera dropped? If it was dropped that can bend the metal battery contacts, then when you put the batteries in it doesn't really contact the battery properly.
7. If it still won't turn on have an electronics guy check it over, or at the local college electronics teacher. I've fixed these before and the main DC circuits are not too complicated. These camera's can even be powered up using a regulated 6V DC power supply connected properly to the battery terminals, (just for testing) and in that case you don't need batteries to tell that the camera works or not. These draw about 300mA of current when ran from 5V to 6V DC.
I attached a JPG photo showing a similar Canon A60 running via a DC power supply and no batteries. This one was apart at the time to fix a stuck zoom lens, and when it's apart there is no where to put the batteries so I have to power it this way.
You do not have to take it apart or use this method. I just mentioned this so it's clear that all it needs to run is 5 -6V DC from properly charged and inserted batteries (or an external source). Don't try connecting anything if you are not familiar with electronics because connecting it up wrong can damage the camera. Try the suggestions mentioned early and it will probably work since these are pretty reliable cameras.
Jul 15, 2010 | Canon PowerShot A75 Digital Camera
Battery door replacement
Does this mean you have a replacement door already?
If so, you will need to figure out how the camera comes apart. This is not always easy to do. I suspect there will be screws or snaps hidden. Improper dis-assembly will cause damage to the case and/or finish.
I would contact Canon and ask if there are any repair shops near you that they could recommend.
Joe
Mar 08, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
My power shot A75 has a purple screen and does not take pictures where can I take my camera in Ottawa Ontario Canada to have it repaired
This is known problem of bad ccd imager chip in Canon A75 camera and ccd imager will be replaced to get correct live view image.
Canon offers free of cost repair for A75 camera for bad ccd imager problem, click Canon CCD Imager Advisory for details.
Oct 13, 2009 | Canon PowerShot S1 IS Digital Camera
How do I remove the battery door from my ixus 75? I need to replace it as it slides open and powers off the camera - the tiny catch near the hinge point has snapped off somehow. I can get a new door from...
hi..
1. Turn your device off and remove the battery cover and battery
2. Remove the end-cover by pushing the cover away
3. Pull the bumper tabs up to separate the bumper from the device and remove bumpers
4. Snap new bumpers firmly into place
5. Re-attach the end-cover, re-insert the battery and re-attach battery cover..
thank u
rate me!!!
Jul 13, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Battery door latch broke off body of Canan A590
The same thing happened to me this week. I called Canon Canada directly and asked to order the part (The battery compartment door). They gave me a phone number to call and I was able to order the replacement door for about $8.00 + $10-$12 shipping. Hope this helps!
Jul 10, 2009 | Canon PowerShot A590 IS Digital Camera
Ixus 500
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Aug 25, 2008 | Canon PowerShot S400 / IXUS 400 Digital...
There is a pin that holds the battery door down, it might be removable without taking the case apart, other wise split the case and remove the pin and put the new door.
http://www.darntoothysam.com/servlet/the-1176/Canon-PowerShot-A75-Digital/Detail
has a battery door for you if you need it.
Nov 16, 2007 | Canon PowerShot A75 Digital Camera
Power shot a75 does not turn on.
First, check that the battery terminals are clean and in contact with the batteries. Next, there are two door switches on the A75 that need to close to operate the camera. One is by the flash card door, the other by the battery door. A small piece of plastic on each door activates the switches when the doors are closed. Check to make sure that both of these are indeed being pushed in all the way when the doors are closed. Hope this helps at least one of you peeps. For other great diy fix-your-own camera secrets, be sure to visit:
Nov 08, 2007 | Canon PowerShot A75 Digital Camera
Canon A75 Broken Prongs in Memory Card Resevoir
Yes, memory card pin set are available for replacement. Unfortunately, camera needs to be disassembled to some point to replace it. The average cost may run around $75- $125 in US repair shops.
Mar 16, 2007 | Canon PowerShot A75 Digital Camera
Canon PowerShot S1 IS Digital Camera Logo
409 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
