Question about Maxtor Hard Drive
I have an old (1995) maxtor disk model 71626AP out of my old computer. I think I want to install it as a slave in my windows/XP desktop computer. Other than removing the jumper at J20, is there anything else I need to do? Will windows recognize the "new" drive and find the necessary driver? Anything else I need to know? Thanks - TOY
  • 131 Answers
Windows will recognize it. Just be sure the other drive is jumpered as master/primary and the old drive is jumpered as slave/secondary and that they connect to the same IDE cable.
Posted on Aug 28, 2010
Think Point!!!!!!!!!!!!!!!!! All these solutions sound nice. The problem is that even in "Safe Mode with Networking" I cant access anything on the computer that includes the start menu. So I cant install...
One way:
* remove the disk-drive from your computer
* install a different disk-drive (any old, 4GB or larger, disk-drive will work)
* install Windows onto that disk
* install anti-virus software onto that disk
* reconnect the previous disk-drive as a "slave" disk-drive
* launch the anti-virus software, targetting that "slave" disk-drive
* shutdown
* disconnect the different disk-drive
* boot from the original disk-drive, now that it is virus-free
Oct 19, 2010 | Computers & Internet
Obtained a used Maxtor 6Y200P0 (DiamondMax Plus9) hard drive which should have 200GB (as advertised), but only 34GB is available. Reformatted the drive, but still only has 34GB. Verified it is not a...
Hi:
You didn't say what kind of computer you are installing this drive in, or what operating system, but I can tell by your problem that you are trying to install it with a Windows xp, service pack 1 or older system disk. Often, the older windows disk will not let you see the entire contents of a large disk, and especially a problem if a smaller Hard drive is still present in the system.
A good solution to fix this problem is this:
Temporarily unplug your Seagate hard drive. Download the Maxtor installation software from their website, and then run the installation program. Once you got that, then power down the computer, and do your master slave set up again, and hopefully you will have better results
Nov 18, 2009 | Maxtor DiamondMax Plus 9 200 GB Hard Drive
Take Three: I have an older Maxtor Hard DriveTake Two: I have an older Maxtor Hard Drive (Model 90645D3). I need to transfer some files from it (Win98SE) to new hard drive (WinXP Pro). I asked earlier and...
Jumper off will set the drive to slave. If you can connect both drives to the same ribbon cable with the master on the end & the slave to the second connector. Look at your bios as win is booting up to see if shows the drive as slave, you will not be able to copy windows as a operating system off of the drive, but should be able to copy files.
Good luck on your endevors.
Lee
Nov 12, 2009 | Maxtor Hard Drive
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
My maxtor drive doesn't work as a slave drive. It is recognized by bios but not by windows XP
Maybe your hardisk is not compatible with xp, was it an old hardisk? Try it with other computer if it detect.
Thanks
Nov 22, 2008 | Computers & Internet
Pin settings
There are four Jumper settings on a Maxtor:
(got it from http://www.techspot.com/vb/all/windows/t-32378-Windows-XP-Home--No-boot-device-help.html)
posted by by mr.smit:
"The 2nd row, is for DS(Master): only 1 drive in PC, or the drive that you want to boot up from.
The 3rd row, is CS Enabled: Cable select, the computer desides wich harddisk is master and wich one is slave
The 4th is cap limit: windows cannot run on harddisks that are to big, like 300gb, so putting jumper on cap limit (capacity limit) makes it smaller for windows to use it.
The 5th row has no use, or i don't know what it does, either of that 2."
I would like to add about the DS (Slave) setting. It is used if there is another drive present on the system which you want to boot from. It will become a spare Hard Disk.
Here is a picture of a maxtor drive indicating where to find model number and jumper settings.
http://xboxdrives.x-pec.com/images/maxtor-drive-model.jpg
Nov 19, 2007 | Maxtor Hard Drive
My computer problem
What is the jumper setting on the New Cd ROM? Did you use this re-install method?: http://www-307.ibm.com/pc/support/site.wss/document.do?lndocid=MIGR-4UFUYK
Jun 03, 2007 | IBM NetVista M42 PC Desktop
Can't format or create partition......
It maybe that your motherboard bios cannot support 250GB and needs an update, but caution applies here. The other problem maybe that you need to use the hardrive on the 'CS' (Cable select setting). Lastly if you already have a pc running, use this drive as the slave the go to the Maxtor website to make use of the diagnostic/formatting and partition tools.
Feb 27, 2007 | Maxtor MaXLine Plus II 250 GB Hard Drive
you can try an FDISK form a windows boot disk, but you may need to read up a little on how to use it. or maxtor has a program available on their web sit called powermax that can try to find & repair possible problems. powermax may be the best & easiest way to go. good luck.
Maxtor Hard Drive Logo
240 people viewed this question
Top Maxtor Computers & Internet Experts
Arora Singh
Arora Singh
Computer Links
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
