Question about Bionaire Febreze Scentstories BSSP101-U Air Purifier
HOW DO I GET THE FEBREZE BY BIONAIRE SCENTSTORIES TO CHANGE SCENTSTHE DISK BY YANKEE CANDLE SAID REFER TO OWNERS MAUAL AND I DO NOT HAVE IT
Are Bionaire F150/150S/150W available?
Refer your inquiry directly to Bionaire.
Jul 21, 2014 | Bionaire Air Purifiers
Child's asthma
this stuff only really works with people that have pet and grass allergies. it will not help contact allergies like bed bugs, mites etc. the only way you can find out the full list of ingredient is to contact febreze, your son may be allergic to the activator in the spray. alot of people are more allergic to this than anything as it coats your lungs or contacts the skin check for red marks and itching and loss of appetite. also it is best to have a doctor find what he allergic to, there is a number of tests that can be done to find what it is then there is a way of you finding the right applicant that can help hope this help
Apr 02, 2014 | Febreze Home Care Industries F73520...
THE FAN ON MY UNIT DOES NOT WORK. IT STARTED WITH A POWER SURGE.
Marilyn - The power surge is the key to the problem. It probably fried the motor and/or the controls. Quite honestly, it would cost more to repair it (parts & labor), than buying a new one.
I'm sorry, but that's the way it works out some times.
Apr 13, 2011 | Bionaire Febreze Scentstories BSSP101-U...
It is used ...how do I know if it is working....model LR 45976
couldnt tell you if used and as to operation your owners manual can tell you how to use it and set it up for peak performance
Aug 24, 2010 | Bionaire Ulpa (UA0860U) Air Purifier
BIONAIRE CONSOLE AIR PURIFIER CH-3550 manual
hi phil,
you can go onto the bionaire website look up your product and then on that same page it should have manuals. now they have done some changes to the website but you should be able to pull one up. if you have any other questions please let me know
Nov 20, 2008 | Air Purifiers
Reset Filter Indicators on BAP 725
there should be a small pin hole somewhere on the top of the unit. Stick a pin in there hold for about 3 seconds and it should reset.
Sep 01, 2008 | Bionaire HEPA Air Purifier Air Purifier
Lost amnual
the lights are the ionizer light, the filter indicator light which is the light that will come on when the filters need to be changed, ionizer control button, the speed control and the power light.
Dec 04, 2007 | Bionaire BAP825-U Air Purifier
Dirty filter
Noggin's solution is correct.  My copy of the BAP825 manual says to poke a paper clip into "the hole marked RESET."  There is no hole marked 'reset' on the air cleaner.  Thanks, Noggin!
Apr 05, 2007 | Bionaire BAP825-U Air Purifier
Bionaire Hepa filter
The carbon filter should have the air passing through it first, before the hepa filter. The carbon filter removes the large particles which would otherwise block the hepa filter very quickly. Contact these guys if you need more help; http://www.bionaire.com/contactUs.aspx Hope this helps :)
Jan 01, 2007 | Bionaire LC0760 Air Purifier
Bionaire Febreze Scentstories BSSP101-U Air Purifier Logo
Top Bionaire Air Purifiers Experts
Bill Long
Jay Finke
Jay Finke
Tim Whalen
Are you a Bionaire Air Purifier Expert? Answer questions, earn points and help others
