Question about Sony Playstation 3 (PS3) Console
My playstation 3 doesn't display video,only audio works
    President:
  • 1,139 Answers
Try the following steps to solve your PS3 problem :
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition.
Hope this helps and thank you for using FixYa
Posted on Sep 11, 2010
Ps3 only displays in 1080i
I have similar problem , ps3 320gb + 5 years old sony bravia 1080p = everything OK
but when i connect ps3 to new samsung ue46d7000 1080p = doesn't work (only 1080i)
I am using same HDMI cable
Jun 19, 2012 | Sony Playstation 3 (PS3) Console
Tip
Playstation 3 has sound but not showing picture
It sounds like you have changed your display settings either to HDMI but are not connected with HDMI or you have set the progressive scan to ON and it's not supported by your TV. Try turning off the Playstation 3 and then hold the power button for about 5 seconds, until you hear a second set of beeps. This procedure will reset your display settings, then auto detect your connection, provided you have kept up with the updates. If you have kept up with the updates or aren't sure, you can use the same steps, but you will need to be connected via Composite Cable and not HDMI. If this doesn't work, you may need to send it in for reparis.
on Nov 25, 2013 | Sony Playstation 3 (PS3) Console
Playstation will not display my facebook
Sometimes Facebook doesn't work through the browser. Try deleting your cookies by pressing the tirangle button while you're in the browser, go to "tools," and then "delete cookies." If that doesn't fix it you'll have to use facebook some other way.
Mar 24, 2011 | Sony Playstation 3 (PS3) Console
When i connect to my television with a hdmi cable i get unsupported signal check input connection...
You need to put your a/c cables back in and put the tv on av in and then go to system settings and change the video audio to hdmi and then it will work.
Jan 10, 2011 | Sony Playstation 3 (PS3) Console
I hooked hdmi to tv. i went thru ps3 settings for video n audio n swithch audio to the red n white output. now i have sound thru surround sound but my video is flickering n i cant c so i can undo it
Make sure the Component AV Cable is connected to the AV Multi Out port on the back of the PLAYSTATION 3 system. Connect the other end of the Component AV Cable into the video and audio RCA jacks of the TV or display monitor.
2. While the PLAYSTATION 3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the system goes into standby mode again . (So the light cycle would go from: red light to --> green light --> then back to red light) This will ensure that you have held down the ON/OFF button long enough to reset the Video Output Settings.
3. Turn on the PLAYSTATION 3 system and once the system finishes powering up, the Video Output Settings will automatically be reset to the standard resolution (or detect the current display output settings of your TV/monitor).
Jul 01, 2010 | Sony Playstation 3 (PS3) Console
My playstation only has audio when a game or
if there is absolutly no video
if so
  • Have your ps3 in standby mode (red light).
  • Now, press and hold the power button in the front down. Your ps3 will beep twice. Let it go almost exactly after you heard the second beep.
  • Wait 10-15 seconds. A display will show up, and just answer yes to all
May 06, 2010 | Sony Playstation 3 (PS3) Console
Playstation will not connect to TV, audio or video
Put your PS3 in standby mode (hold the power button until the light turns red) then release, and hold the power button again for about 10 seconds, or until the light beeps a second time. When the PS3 restarts, it should display using whatever it finds first.
Nov 28, 2009 | Sony Playstation 3 (PS3) Console
No display on my Ps3
Two or more things, first make sure you have your audio vidio cables correct
Yellow= Video
Red= Audio right
White Audio left
Also make sure that the tv matches the input your cables are connected into. I would make sure the restart the PS3 to make sure the video is good (after checking the tv input)
Jul 20, 2009 | Sony Playstation 3 (PS3) Console
No display no audio
Hard re-set the unit by pressing and holding down the power button (front panel) from the off position for at least seconds. - it will beep 3 - 4 times
Dec 17, 2008 | Sony Playstation 3 (PS3) Console
Playstation 3
Did this happen after u recently did a system update?...
rule out a possible faulty video lead and a possible tv.
Aug 05, 2008 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
21 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
