Serivce manual for hoover commodore washing machine 5kg
SOURCE: Hoover washing machine (commodore 5.0 kg)
this is either a belt slip or a squeeling bearing ater seal, if it is not the belt then try doing a boil wash, this often resolves the problem. Regards Advisor
Posted on Aug 22, 2007
  • 38 Answers
SOURCE: hoover 5kg washing machine
sounds like a spring which keeps the tub centred is broken. Could also be a worn bearing. this needs specialised tools to get the problem fixed, especially to replace the bearing. contact a repair-person.
Posted on Jun 15, 2008
SOURCE: I need to download hoover washing machine manual HNWL7146-80
You can try going to http://www.managemyhome.com/ and looking up the model # there.
Posted on Mar 15, 2009
  • 25 Answers
SOURCE: I require a user manual for a Whirlpool AWG5122
if you go to the whirlpool web site under support you should be able to download one.
Posted on Apr 07, 2010
blueextc3221
  • 15935 Answers
SOURCE: Hoover commodore Washing Machine Overfilling
This advice is for a washer that fills and will not shut off, resulting in an overflow. Or, water is leaking from the washer while filling. The symptoms can apply to either a TOP LOADER or FRONT LOADER washer. This may be able to save you from an expensive service call by making these simple visual checks.
Water Does Not Shut Off and Overflows: The water level in a washer is controlled by the Pressure Switch. The switch is usually cylindrical in shape and has an electrical connection and an air hose attached. In many cases, the small air hose comes loose from the Pressure Switch fitting and/or falls off. This air hose is required to detect the air pressure from the wash tub as tub fills. With no air pressure, the switch will not function and the result will be a wash tub that fills continuously to the point of overflowing. The same would be true, if the air hose has any cracks, splits or holes in it.
Water Leaking While Filling: The other end of this hose runs to the air dome fitting on the side of the wash tub. If the lower end of the hose comes off, the water will begin to spill onto the floor under the washer, but the tub will not fill.
What to Look For: Check for the obvious. Make sure the air hose is still attached to the pressure switch and air dome. Then, inspect the entire length of the hose, paying particular attention to areas where chaffing may occur and at the points where the hose connects to the pressure switch and air dome. Vibrations from the washer can cause some wear if the hose is rubbing against anything, and the ends of the hose can stretch over time and not seal properly.
On most top loaders the Pressure Switch is located inside the operator console behind the knob that controls the water level. This knob is commonly referred to as the “Load Level”, “Load Size” or “Water Level”. On front loader washers the pressure switch location is usually located in the back of the washer behind the wash tub, or along the interior cabinet wall adjacent to the wash tub.
How to Correct: If the hose has slipped off, cut about ½” off the end of the hose and reattach to the pressure switch and/or air dome fitting. Take a small zip tie and place it around the hose at the point where it connects to the fitting. DO NOT over tighten as this can damage the air hose fitting. Just make the zip tie snug enough to keep the air hose from sliding off. If the hose has any cracks or holes, you can attempt to seal them by using electrical tape. Replacement tubing can be purchased at any hardware store.
NOTE: This is not an all inclusive fix, as the Pressure Switch can fail in some cases and cause similar symptoms. This is merely a preliminary check for a common occurrence that I have discovered. It can give symptoms of a major problem, resulting in a call for a repairman, only to turn out to be a simple fix that any Do-It-Yourselfer should be able to check and correct themselves. I hope this information is found to be helpful and saves many of you a future service call.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Dear sir, i need ur hoover wa550 washing mechine catlog for 5Kg capacity. best regatd; jomy
Sorry but this forum does not supply any type of manual or schematic diagram direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
Good luck,
John C
Mar 19, 2011 | Washing Machines
I have a Hoover 500mb, 5kg HD Top Loader washing machine. The problem I am having is the clothes always have lint and other stuff on them after being washed. I have tried taking the agitator off and seeing...
have you done a clean ,hoover have this built in you need to do every so often the filter could be clogged do a clean don't put anything in when your doing this ,how old is it
Jun 16, 2017 | Hoover Washing Machines
Need user manual for whirlpool AWG 5061/M --600RPM AA 5Kg
I NEED USER MANUAL BOOK FOR WHIRLPOOL FRONT LOAD W/ MACHINE MODELS NO AWG-5061/M AA 5KG 800 RPM please send it to me on fayaz_1966@yahoo.com I will be greatful to you Thanks
Nov 03, 2010 | Whirlpool AWG329 Front Load Washer/Dryer
How to change the belt on 5kg hoover washing
you have to re alliegn tha motor
Jul 12, 2009 | Washing Machines
Hoover 5kg washing machine
Jun 15, 2008 | Washing Machines
Jan 30, 2007 | Hoover Nextra HNT 2135 Top Load Washer
Washing Machines Logo
601 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
