Question about HP G60-230US Notebook
G60 will not boot. no BIOS screen nor Logo. The hard drive is new and there is a power light and the hard drive light comes on for a couple seconds after that just the power light and I can hear the fan.
  • 107 Answers
Have you check your RAM? Common cause of this problem are memory related problems. If you have 2 memory for your laptop try to isolate each and try to boot up 1 memory at a time.
Posted on Aug 28, 2010
Wont go past logo screen, disconnected from power then back on. turned off then on, still logo screen, now says 'preparing automatic repair' nothing happened and its been at least half an hour
Try booting into your bios...
Google how to boot to bios (Manufacturer / Model number)
e,g How do I boot to bios on Dell Precision T3500
Try a hard drive test from there. Sounds like a hard drive error.
'preparing automatic repair' should end and give you options to troubleshoot if it isn't getting that far test hard drive.
Jan 08, 2018 | Power Computers & Internet
When turn shows logo turns off
I would remove the power supply, battery, hard drive and RAM. Power up the laptop with just the power adapter and enter bios. If it goes to bios OK, select the default setting. Press F10 and let it try to re boot.
Remove the power supply and fit the RAM. Insert the power supply and try to boot. You should have error message on screen. Remove the power and insert the hard drive. Connect the power supply and attempt to boot.
That sequence should show the issue at the point that there is no display that is where the issue is,
Dec 13, 2013 | Dell Inspiron Computers & Internet
Old compaq presario 900 won't start. I see the Compag logo and then immediately black screen with blinking cursor. HDD is new Western Digital 250 GB, and tests ok with Seatools diagnostic. 1 GB memory...
Watch the screen as it boots up looking for the press F1 or DEL to access Setup. Your Presario may not be able to see the new HD in which case you will have to run second party software to access the HD. Get into the Setup BIOS and check for your new HD under hard drive detection if the BIOS can not find it, you will have to run other software to access the drive. If your BIOS gives you the option to start up the hard drive after a delay such as 1 or 2 seconds try that, as the BIOS on the hard drive and the BIOS on the motherboard may be clashing. Hope this Fixya up
Mar 20, 2011 | Computers & Internet
I was using it and turned it off and i came and turn it on and hp logo didnt appear on the screen it was only the lights and blank background please help me.is my sisters laptop and i took it without...
well. be sure the power is plugged in
then pull the battery out of the laptop
press the power button down
look at the little lights indicating power on .. battery charging and hard drive activity
if the power light comes on..
then the screen is the problem
if the hard drive comes on after say 10 seconds
it is definitely the screen
put the battery back in.. be sure it is in solid
put the power pack in the wall
if the battery charge light comes on
then the power is to the laptop and battery connections are good
so the laptop may have overheated...
wait five minutes
try to power it on again
if the fan does not power on...
it has a bad fan...
quietly set it where ya got it from then
Jan 21, 2011 | HP G60-235DX Notebook
My Gateway Gt 5220 will not turn on. Technicaly it does turn on ex: hard drive spin processor click couple time power brick and processor fan spins hard drive light flickers couples time and cd drive will...
sounds like your system is booting up and running due to the hold power shutdown procedure. you might try replacing the video card or adding one if your video is integrated.
Dec 23, 2010 | Gateway GT5220 PC Desktop
When I boot up the computer, the screen has the p5l-vm 1394 logo and at the bottom it says "press delete to run setup, and press tab to display BIOS post message I tried restarting a couple of times and...
The system is currently not able to boot from your hard drive.
press delete key, then on the first screen check to see if the system has found your hard drive. If not, power off and make sure all cables are plugged correctly and hard drive has a power lead attached and retry.
Mar 30, 2010 | ASUS P5L-VM 1394 Motherboard
I have a gateway laptop model MA7and it wont start up.
It is not a hard drive issue. If hard drive is a problem system wont boot till motherboard processor. Try to reinstall your OS. It will fix your issue.
May 14, 2009 | Gateway (M520HD80G) Hard Drive
Inspiron 530S Power Save Mode Loop
First you need to make sure that there are no other removable devices plug on the system, like usb, external hard drives, then if that will work try to go to the bios, press f2 when you see the dell logo, and go to the system setup, go to the boot device configuration and make sure that removable device is not the first boot device, if it is the first one choose hard disk and then second boot device ad cd rom/dvd rom and then disable the 3rd boot and the fourth boot device. Make sure to save the changes. And restart the system again. Once the computer is back and running try to go to support.dell.com and check the bios, download if there is a bios update for the system.
Oct 30, 2008 | Computers & Internet
Gateway MX6931 won't boot
Have you tried a new battery pack for your laptop? Try removing the battery pack and then running it.
I have seen this symptom on other brands of laptop.
It may require a new battery pack.
May 22, 2008 | Gateway Computers & Internet
No splash screen, no activity just lights (evo N610c) Plz help.
turn on your computer and do nothing,, when it seems the computer stop running key in fn+f4.
Dec 30, 2007 | Compaq Evo N610C Notebook
HP G60-230US Notebook Logo
440 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
