Question about Rancilio Silvia Espresso Machine
The steamer on our raniciolo silva does not work: the top light does not go out and no steam comes out
  • 1,089 Answers
More than likley its your steam thremostat. Replace it and you should be good to go. Its on top of the boiler and the one that doesn't have the red dot on it.
Posted on Sep 11, 2010
My compact steamer does not let the steam out when I press the black release button help?
I examined mine. There is literally NO hole in the steam wand for the steam to exit. It's a wonder the thing didn't blow up. Take it back and be glad you still have your face.
Jan 01, 2015 | Top Vacuums
Stopped emitting steam
Mine started steaming from the top and a little plastic piece inside where the handle attaches to the wand cracked. I had to purchase an entire head and after one use it did the same thing again. It is a poorly made steamer with cheap plastic parts! Since it was out of warranty, I threw it in the dumpster!
Mar 24, 2014 | Oreck Steam-It All-Purpose Steam Wand
Conair Lysol hand held steamer
Does it tell you to add salt to the water?(I have a cheapo little steamer that requires salt to increase the conductivity of the water-it just creates steam by running AC voltage through the water in the tank)
May 25, 2013 | Heating & Cooling
I have a Krups coffee/espresso maker, with a milk steamer. It makes great coffee and espresso; however, the steamer is not working. It is not clogged; I cleaned the handle with a fine needle, and water...
There must be a blockage in that steam pipe, I think you need to dismantle the machine and remove all of the steamer parts off the boiler and look for the cause of the problem. Oftentimes it will be old hard milk that has been drawn up the pipe and gone hard from the heat. Once cleaned out prevention by blowing a large amount of extra steam through it after each use is the solution.
Apr 22, 2017 | Krups Gusto 880-42 Espresso Machine
Scuncii Steamer
It is probably clogged with rust or limescale - can happen with steam cleaners. Sadly there's no way around this but to try a limescale remover in distilled water such as Calgon limescale remover. Fill the kettle as normal and give it time to boil up. Then release the steam as you would normally. You may find that the kettle will spurt out deposits of gunk. Sounds like its definately clogged though.
Feb 19, 2009 | Scunci 52067 Handheld Steam Vacuum
No steam in scunci steamer will not work lights uop hear pressure and heats up
no steam in scunci steamer, it does gets warm but no steam at all. like if it was blocked
Aug 29, 2008 | Scunci 52001 Handheld Steam Vacuum
New Rancilio Silva - steamed milk not perfect
please relay on your experience realizing that you now have new steam pipe(with different holes in the end of it and different pressure)
you will need to get use to them and get maximum quality of that steam pipe.
my advice:
  1. every time hold your hand in the bottom of milk container, so that you will prevent overheating which often gives the result you mentioned.
  2. every time you use cold milk.
Jul 22, 2008 | Rancilio Silvia Espresso Machine
Steamer
Both tubes must be in the water. If you haven't used the machine for awhile, fill the water canister, turn the espresso maker on and also turn on the delivery switch (the top switch on the EC140). You'll hear the pump and in a second or two water will begin to exit the boiler nozzle. Immediately turn the delivery switch off. Wait for the "OK" light to come on. Press the "Steam" switch (the middle switch on the EC140, place an empty cup under the frother and turn the steam control knob on top in the counterclockwise direction. Steam will come from the frother. Be very careful to avoid contact with this steam.
Apr 23, 2008 | DeLonghi EC140 Espresso Machine
Heats up and produces steam but the release button does not open the flow of steam.
To remedy this, I did the following:
1) Removed screws from: a) Lower area of handle (1 screw), b) Top of steamer, under round rubber flap around fill hole (2 screws), c) Front of steamer where nozzles attach (2 screws)
2) Removed back of handle, top of steamer, front of steamer where nozzles attach
3) Once all parts are removed, you can see a brass button that is pushed by the trigger
4) Using a needle-nose pliers, grasp and rotate the button several times in both directions (you may hear it cranking against the interior spring). Do this until it turns fairly easily with the pliers.
5) Once this is done, you fill find that the brass button can be very slightly depressed with a bit of force. You may also need/want to unfold a large paper clip to push into the nozzle hole to help unsticking the brass button (not sure if that helped in my case, but it was something I tried along the way). When the brass button moves in and out (again, it won't move much), the steam release mechanism is unstuck!
6) Reassemble all parts (everything snaps back neatly into place).
This worked for my unit!
Nov 11, 2007 | Scunci 52067 Handheld Steam Vacuum
Rancilio Silvia Espresso Machine Logo
52 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
