Question about Electrolux EW30ES65GS 30" Slide-in Electric Range with 5 Radiant Elements, 4.2 cu. ft. Self-Cleaning... Range
Just bought the new touch top electric stove and can't seem to get the control panel to light on top to light or unlock
  • 248 Answers
Call Electrolux if it's new. It's got at least a 1 year warranty.
Posted on Aug 28, 2010
My stove top does not respond to the touch
Good Morning Kenneth Kozoway, thank you for your inquiry!
I see that you have explained the stove top on your Electrolux range is not responding to touch and the oven controls are working properly. From what you have described it sounds like a possible issue with your control panel or sensor. I would suggest performing a reset on your range and you can do that by disconnecting the power from it for ten minutes. If that does not help correct the issue I would recommend having a professional technician come and perform a proper diagnosis for repair. Hope this is helpful. -Matt
Dec 25, 2014 | Electrolux 30" Self-Cleaning Slide-In...
I have a stoves farmstyle 1100 df cream range cooker. I am having problems with the timer and have bought a new one but I need to know how to remove the top to fit it. The cooker serial number is 050564146
Hi.
To replace the timer control you need to remove the front fascia panel and the hotplate at top.
Before starting disconnect power and move the range forward.
To remove front panel you need to undo the 4 screws at the sides and to remove the knobs, then remove front panel.
To remove the hot plate you need to remove 4 screws at the back. There are also 4 screws at each side of the hot plate. You may need to remove the side panels to reach those screws. There is also an additional screw located behind the control.
Here a service manual for the range Farmstyle 1100E, which is similar to 1100DF. The disassembling instructions for top and front are at pages 62 to 64 of PDF (sections 4 to 6). Control board and touch pad are at page 67-68 (sections C and D of disassembling).
Service manual: Stoves Farmstyle 1100 1st.pub
Regards.
Ginko
Oct 07, 2011 | Stoves 1000DFDLm Gas Kitchen Range
Stove works, oven does not
in repairing Kenmores there is a relay well 2 small black an square in the head unit of stove one for stove the other is for oven anyway they go out alot a setback to the kenmore digital controls take upper panel off where controls are look at the green board an you can see them some green some red or blue to tell if one is bad be careful an turn the stove on u will hear the relay click then try oven if you do not hear a click its bad do not i repeat do not touch it while its on
Aug 31, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Just bought a house, no manuals
After a pot spillover, the cleanup process triggered my stove top to "control lock"
I removed the pot and once the stove top cooled I pressed and held the "control lock" button.
It began to blink, I released it and then the light went off and the stove top operated normally.
You might not have to wait for the stove top to cool. I don't know.
Aug 24, 2008 | GE Profile JP930 Electric Cooktop
Jenn Air slide in range JES9750AAB - Touch Pad
put on tree belt . having the same problems replaced ERC $200.00 now they are telling me touch pad touch pad is $240.00 .the stove cost $1300.00. $1740.00 how much more will i have to put in this stove
Aug 02, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Frigidaire elete smooth top range
IT SHOULD BE AVAILABLE. SOMETIMES THE TOUCH MEMBRANE SWITCH IS A SEPARATE PART FROM THE CONTROL, AND SOMETIMES THE CONTROL IS COMBINED WITH THE TOUCH MEMBRANE SWITCH. THE MEMBRANE SWITCH COULD BE AS MUCH AS $200.00 AND THE ENTIRE CONTROL AS MUCH AS $350.00.
Dec 25, 2007 | Frigidaire FEF336BC Electric Kitchen Range
The touch pad panel on stove is blank
on the ge range, you need an ERC its the main control for the oven. yes its costly. comes in a kit with a new wire harness
Nov 16, 2007 | GE Profile JGSP48 Gas Kitchen Range
Electrolux EW30ES65GS 30" Slide-in Electric Range with 5 Radiant Elements, 4.2 cu. ft. Self-Cleaning... Range Logo
216 people viewed this question
Top Electrolux Kitchen Ranges Experts
Craig Butler
Craig Butler
Robert Plante
Andrew Taylor
Andrew Taylor
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
