Question about Toro Garden
I have a toro recycler 20443 it was working fine today them it run out of gas while mowing,added new gas but did not started i prime few times and i know that the spark plug works i pulled out grounde it and saw good spark,help please
SOURCE: Toro Lawn Mower Won't Start
this is a very common problem with these toro mowers. the needle valve in the bowl of the carb. is plugged up with dirt or varnish from the fuel. just under the primer bulb there is the carb bowl. it has a nut under it that holds it on remove the bowl and make sure fuel flows constantly while the bowl is off. push up on the float to stop the gas flow. this could be messy and dangerous. careful with the gas. its flammable. best solution is to remove the carb and soak it overnight in a parts cleaner like gunk. caution small parts inside. this happins every year on mine no matter what i do. seems like the orifice is so small it clogs easily. good luck
Posted on Nov 15, 2008
SOURCE: Toro walk behind model 20025 Gas running through the carburetor
Carb. float must be stuck open. First if you have no fuel in the tank it must all be in the crankcase.Drain the oil and refill and also check the carb as the float has to be sticking open. Hope this will help you. Donnyb60
Posted on Mar 18, 2009
  • 10865 Answers
SOURCE: toro recycler will run until primed gas is consumed.
The problem is that the gas that sat in the carb all winter glazed it over and gummed it up. Begin by going to any auto parts store, like an aiutozone, and getting a bottle of carb. cleaner. Seafoam is one I use. Add it to your gas, one ounce per gallon of gas. Also, pick up a can of engine starting spray.
Remove the air filter and spray the engine starting spray into the air intake. Pull start the engine and give it additional squirts of engine starting spray until it runs smoothly.
Posted on May 30, 2009
  • 78 Answers
SOURCE: Toro Recycler with Techumseh enging will not start
Make sure it can breath. Check the airfilter element. If its oil soaked replace it. Sounds like this engine cannot breath. This engine is set ,there are not jets to replace. Champion Plugs are not the problem FIRE IS FIRE . Fresh Gas if it aint less than 30 days old it aint fresh. Todays designer fuel goes stale quickly.
Posted on Oct 29, 2009
mister_b_65
  • 74 Answers
SOURCE: toro mower recycler 22 inch will not start has
Is the plug actually sparking? To test this, first, unscrew the plug from the engine...then, with the wire attached to the plug, and with it laying on the deck, pull the engine over with the rope starter. If it doesn't spark, the plug needs to be replaced. The other possibility is that the kill switch is bad.
Posted on Dec 13, 2009
After priming starts, runs and stops
If you over fill the oil your mower will not start until you remove excess oil. This should be checked first, This is a much easier fix.
Jun 20, 2010 | Toro Garden
I have toro 6.5 super/recycler that stalls out after about 5-10 minutes after it starts up then it will not start for about 30 mins. i've changed the spark plug and cleaned the filter
Dont know if this is the same problem but it may help. I've recently bought a used Toro 6.5 recycler and have cut the lawn 3 times with it. This third time it began to stall out on me. If I hit the primer button several times it would start up but then die again. I thought I'd have to pull the carb and clean it, ut after looking at a few problem listings online I realized it was probably just some trash in the needle valve. I managed to get it running again by first pushing the primer pump 3-5 times, then pulling the cord to crank it, then while holding the contact bar in place with one hand to keep it running I reached down and pumped the prime button a few times before it cut out again- after one or two tries it apparently flushed the trash out and it ran fine again. Had the same problem later and fixed it the exact same way, then went on to finish the yard.
Sep 08, 2009 | Garden
Toro mower-shut off, won't re-start
check the coil by pulling the plug and lay it against the head put the plug wire on pull the handle if it sparks then its not the coil another thing you can try is spay carb clean or starting fluid in carb see if it starts if that starts it then the float in the carb is stuck if i can help further e-mail me @wadembly@aol.com
Jun 08, 2009 | Toro Lawn Mower With Toro Power Tools
Toro recycler will run until primed gas is consumed.
May 30, 2009 | Toro Lawn Mower With Toro Power Tools
Toro recycler will start until primed gas is consumed.
I had similar problem and cleaned the spark plug and that seemed to have worked, but I think that may be a temporary fix because the engine still seems to be running unevenly. I feel that it must be a larger problem with the carb. If anyone can help this novice to adjust the carb or clean both carb and filter, or offer other solutions I would appreciate your assistance.
May 20, 2009 | Toro Lawn Mower With Toro Power Tools
Toro TimeCutter z4200 will not start
First check to see if there is a fuel shutoff under the tank. On some models there is a fuel filter screen inside the tank where the fuel line connects to the tank. If niether of these work, R&R the carb.
Apr 08, 2009 | Toro Lawn Mower With Toro Power Tools
Mar 18, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
140 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
