Question about Nikon Speedlight SB-80DX TTL Flash
I dropped mine and the diffuser flap and its black plastic hinge pooped off. They don't look to be broken so I just need someguidance on dismantling enough of the flash to reattach the diffuser. Now the flash won't switch on but I can hear the lens servo whirring as if trying to focus the lens back and forth.
  • 2 more comments
  • nathanoj Aug 29, 2010
    Thanks Mate - not the result I hoped for but no doubt realistic advice :-) One thing...I've now realised that the sound of the servo motor 'hunting' was due to weak batteries, not the lack of the diffuser flap. I bunged in a recharged set and the flash works fine, aprt form the lack of a diffuser.
  • nathanoj Sep 12, 2010
    Thanks for that link. I bought the manual. My, what a lot of small parts!!
    For now I have taped the diffuser on :-D
    Another d/load site...
    http://www.nodevice.com/manual/newmans/n...
  • Nikon Master
  • 19,396 Answers
Hi.
If you still need to take apart the Speedlight, the only service document available for download is here. It is not free, a small fee is asked for the purchase of the document.
Hope it helps.
Ginko.
Posted on Sep 10, 2010
  • 3,083 Answers
It's going to be difficult to find the service manual for this unit, and Nikon simply recommends that the flash be serviced by an authorized dealer, and is due to the tight, sturdy construction of it's body. I never took one of these apart, but I have taken others apart years ago, and there were hidden screws beneath metal or plastic covers, and it wasn't straight forward, if you didn't wish to damage some part of it. You're going to be hard pressed to find a person who knows about this, since they're few and far between and not likely to be perusing the net on their time off. What I would do is simply take the flash into a reputable camera repair shop and simply ask them how to take it apart- you might get lucky and get enough advice to fix it yourself. Sometimes, if some tech isn't busy, they'll be happy to even do it for you if it's simple enough.
Good luck, thanks for using FixYa, and hope this helps.
Posted on Aug 28, 2010
Catcher parts
Get model no. of mower. You can order flap on line or at mower repair shop. I have mine on back order now.
Jun 24, 2013 | Poulan Garden
How do you fix a dm4 Hinge that is broke where it connects to the screen
You can buy hinges on ebay at:
http://www.ebay.com
Just type your computer make and model in the search followed by lcd hinges.
If the hinges are broken where the lcd screen connects to the base of the laptop then you will have to remove the screws from the bottom of the laptop and remove the strip that is at the top of the keyboard to get to them.
If the hinges on the side of the lcd frame is broken then you will have to remove the plastic strip that is around the lcd screen. Remove the plastic or rubber bumpers on the plastic strip then you will see screws to remove to remove the plastic strip. Then you will see hinges and screws on the side of the lcd screen that you can remove. Once you have them removed you can lean the lcd lid forward so that it drops in your hand. Don't let it drop on the keyboard, just into your hand and not too far because there is a cable on the back of the lcd that you don't want to damage. The cable can be taken loose from from the lcd at the back near the top if you like. Sometimes there might be a piece of tape securing it. If the lcd screen does not come out then there are screws on the 4 corners that is securing it and the hinges.
May 13, 2012 | Computers & Internet
MF4350d gives a paper jam error when it has no paper in it.
I hired a technician who came to house and showed me where the paper jam was hidden... found technician on craigslist for $50 flat rate, came out on Saturday. He solved the paper jam problem in 20 minutes. One place to check for paper jam you cannot see until to look behind a hinged plastic flap above the cartridge area. Remove cartridge.Above the cartridge area is a width-wide plastic piece, about 1 to 1 1/2 inch wide from top to bottom, hindged along the top edge, moves but is attached along the two lower corners of the piece by small springs (one at each corner) to the housing of the machine. You cannot easily lift the plastic flap up to look behind it for paper jam until you remove the springs. I used forceps to remove them. Tweezers may work. Don't lose them! Once you remove the springs you can easily lift up the plastic flap (it is hinged) and look behind it into the crevices for any paper. That is where we found a small piece of paper. We needed a skinny forceps to reach into the crevice to get the paper out.
Feb 16, 2011 | Canon ImageCLASS MF4350d Laser All-in-One ...
Ice dispenser has black ugly gunk from which the ice drops. It is the rubber flapper that opens and shut that is dirty. Question. can the rubber flap be removed to wash?
It;'s possible, but not recommended. The pin that holds the door into place is metal, but the hinges are plastic and have been known to break pretty easily. They do make a replacement kit in case you break the hinges, but that job is usually best left to a professional.
Aug 19, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Spring on the ice dispenser arm is off the shaft pin.
on this type of model the hinges that the door chute is on is week check what part is broken it might be just something holding it open but if its hanging there need to check if the hinge on the dispensor housing itself is broken. if it is they sell a ice door kit for this model due to the weak plastic it sits on
Nov 06, 2009 | KitchenAid KSCS25FKSS Side by Side...
NINTENDO DS BROKEN "PLASTIC RING HINGE"
nono no dont my ds had the same problem it will work as long your extemely careful but if you drop and a hinge missing the top screen will break and it is unfixable i have tried
Mar 24, 2009 | Nintendo DS Lite Console
Whirlpool side by side ice maker
its possible that ice is jamed in the ice crusher compartment this happens to me as well the ice drops down to fast causing it to clog and then stays open until it all of a sudden you pick it up on the floor thanks from gilles
Mar 15, 2009 | Refrigerators
Peugeot 406 windscreen washer fuse were is it
yes 10A fuse under bonnet next to battery causing no wash cycle but wipers as normal. Probably due to frozen pump in cold weather. Just done mine.
Jan 11, 2009 | Peugeot Liberte Cars & Trucks
Broken Built-in Diffuser Plate
I can repair your flash for you if you want it fixed
Berrie Smith Camera Repair
bbmw@bellsouth.net
They is six parts to fix the broken piece.
Diffuser two posts and springs, one flip spring
Nov 06, 2007 | Nikon Speedlight SB-800 TTL Flash
Ice "door" on dispenser
cant bring up your model # but most of the time there is a plastic frame around the dispeser that pops or snaps in.. revealing the screws behind .. need something thin and do some gentel prying to see how it comes off
Sep 02, 2007 | KitchenAid Superba Architect KSCS25INSS...
Nikon Speedlight SB-80DX TTL Flash Logo
131 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
