Question about Pioneer VSX-84TXSi 7.1 Channels Receiver
I have VSX84TXSi reciever and all I get from the audio is a high pitched squeal with real faint sound in the background at high audio level could one of the setup buttons have been pressed by accident or is my reciever broke.
  • 1 more comment
  • claywilson Aug 28, 2010
    I have two satallite recievers one DVD plugged in and same squeal on all and makes no difference which one I unplug and nothing has changed for plugs and inputs Daughter was watching TV at the time and she says the reciever clicked then started to squeal
    All connections good doesn't matter which one is disconnected still squeals 2 satallite recievers and on DVD hooked up nothing changed for two years ,Daughter was watching TV at the time said reciever made a click and squeal started
  • claywilson Aug 29, 2010
    no thanks for the help, i took reciever to local tech and he said straight up that the power supply was the problem and it would be a sixty dollar fix , he said Pioneer is famous for this problem . thanks again for the advice
  • 10,594 Answers
Do you get same high pitched noise in all inputs of receiver?
What are audio sources that are hooked with this receiver?
Make sure all wires/ cables are plugged correctly and tight.
Unplug one audio source cables at a time to see as it might be cause of problem, if no difference, replug and check next audio source.
Let me know above info to diagnose possible cause of problem.
Thanks.
Posted on Aug 28, 2010
  • 3 more comments
  • Shahid Electronics
    Shahid Electronics Aug 28, 2010
    OK, Did you plugged any mic in system? as squeal sound produce with feedback of speakers output in mic and this makes cycle of sound wave for squeal.
    Other possibility is some thing wrong sound processor of receiver that is hardware problem and visual check by local tech is required to fix it.
    Thanks.
    Thanks for the help but nothing was changed or plugged in ,it just made a click and started to squeal. sounds like a trip to the tech.Is this reciever worth fixing or upgrade it? thanks again
    If repair estimate is under $80 or so then worth to get repair, please ask an estimate that will help you decide any thing.
    Thanks.
    Shahid Electronics Aug 29, 2010
    any thing wrong with given info or you need further help?
    That is fine, hope receiver will get fixed and back in business soon.
    Please accept the solution to close question thread.
    Thanks.
Vizio sv470xvt1a No picture or sound
Since it has a high pitched squeal I'd lean towards the power board, if your able take some voltage measurements of the various rails
Mar 11, 2018 | Vizio Televison & Video
Blower fan makes a high pitch squeal.Replaced fan but squeal is still there.
'high pitched squeal' sounds like the serpentine belt on the water pump, not the heater fan.
Dec 17, 2015 | 2011 Hyundai Tucson
High pitch grinding noise coming from motor when starting idling or driving
Seven ways to pinpoint that high-pitched, whining noise
www.losaltosonline.com/special-sections2/sections/on-the-road/45742-
Oct 2, 2013 - I recently had new fan belts installed after hearing a high-pitched, ... Do you hear the noise when the engine is running and the vehicle ... Just replaced water pump (and timing belt) yesterday and squeal ... When driving it make a noise but change out and caught speed the noise is coming from driver side.Missing: 1999 ‎plymouth ‎breeze
What is causing that irritating noise? ' DSMtuners
Troubleshooting Strange Sounds Coming from Your ...
www.dummies.com/.../troubleshooting-strange-sounds-coming-from-yo...
You hear a high-pitched squeal that stops when you shut off your engine: Readjust or replace the belt. These belts should have about half an inch of play and ...Missing: 1999 ‎plymouth ‎breeze
Nov 25, 2015 | 1999 Plymouth Breeze
No sound just a squeal
Audio output IC fault. Replace it. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts.
Mar 31, 2014 | Vizio Televison & Video
AIWA CX NAJ70 music at normal level but singing is faint in the background
That doesn't seem like a problem with the system/ But make sure any eq settings are all at 0 and your mids arent all the way down or much lower than your high and lows. But if thats not it then it has to do with your music, try a different song. a different cd all together
Feb 04, 2012 | Aiwa Audio Players & Recorders
Need to tune and peak my midland 1000 cb
sounds like a problem to me . I have one that was in fair shape that had the same symptoms , I pounded the crop out of it with a hammer and now it doesn't recieve anything . You can't find a service manual for it ,unless midland will sell you one but don't hold your breath . Remember a 26 oz. hammer works good but not the radio.
Apr 07, 2009 | Midland 1001Z 40-Channels Base CB Radio
RCA HD52W59 makes a high pitch internal squeal sound
coil LL0037 resolder then with a glue gun glue top of coil and down.OR replace coil.
Feb 17, 2009 | RCA HD52W59 HDTV Projection Television
NO PIC HIGH PITCH SQUEAL COMING FORM BACK BOTTEM PART OF TV?
Squealing sound means you have something shorted in high voltage area around FBT on Power/deflection board.UED has replacement boards & Misc Parts for these sets if in stock call them1- 800-648-6657
Dec 20, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
High pitch sound in background
A high pitch sound while connected in the house is either a problem with the reciever or you are picking up interference from somewhere. However, the high pitched noise when using the unit in a car (especially through an aux. connection), is caused by the alternator of the car. This can be eliminated by connecting a filter in-line with the aux wire (much like filters are installed on the radio power line). The filter is essentially a low pass filter that filters out noise above a certain frequency. You may have to get creative and modify your aux. input cable (i.e. - splice it into the aux cable) in order for this to work, or you can just turn the volume down a bit - it should be less noticeable at lower volumes.
Nov 26, 2007 | Delphi Roady2 SA10085 XM Radio Receiver...
Pioneer VSX-84TXSi 7.1 Channels Receiver Logo
44 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
