Check the info from this website in regards to the door switch. You will also find more information how to troubleshoot your appliance.
The door switch is critical to the dryer's operation. If the switch is not working, the dryer will not run.
If the dryer has a door latch, make sure the latch is free of dirt or lint and properly adjusted before you make any switch tests or replacements. Sometimes a misaligned latch prevents the door from being closed tightly, preventing the switch from being activated.
The switch on the dryer may be accessible from the outside door, or you may have to remove the top of the dryer to access it. The switch is a simple assembly, with two lead wires running to it. Test the switch with a volt-ohm-milliammeter (VOM) set to the RX1 scale. Disconnect the switch leads and clip one probe of the VOM to each switch terminal. Press the switch closed with your finger. The VOM should read zero. If the needle jumps, the switch is faulty and should be replaced with a new one of the same type.
The switch is held to the dryer with setscrews; remove these screws and disconnect the leads to the switch. Install a new switch and connect the leads. Then position the switch and tighten the setscrews to hold it in place.
Click here to download the repair manual.
May i know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
It's noisyMost
noises from a washing machine occur during the spin cycle. If you hear
loud thumping during the spin, the load of clothes may have become
unbalanced. Stop the washer and redistribute the clothes, then re-start
it. Repeat these steps if necessary.
BEST OPTION I WOULD SUGGEST IS CONTACT
800-269-2609
8 am to midnight-ET
Seven days a week
Fisher and Paykel > DEGX1 Electric Dryer
just so we are on the same page....this is the top loading dryer.....the drum rotates, and is "supposed" to be open (slid back out of sight) when the lid lock button is pushed, to be able to then open the lid. Our lid simply opened, and the bottom of the drum was exposed....and had to manually be turned, to access the clothes.
I went to repairclinic.com....and my brand is not listed. Still in need of help. thanks
