Question about Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine
I am a student at Wake Tech Community College and started a refrigeration class last week. My group project is to fix up a Hoshizaki Ice Maker. It is all in parts and there is no information eccept name plate. How do I get manuals and diagrams to rebuild this project
  • Hoshizaki Master
  • 1,252 Answers
Http://www.hoshizakiamerica.com/
start here. Has all manuals, parts break downs, and bunches of all the good stuff.
Posted on Aug 29, 2010
I have a hoshizaki ice maker that is giving a three beep code and the compressor will not start. i have cleaned the float and have water to the machine
3 beeps means freeze cycle too long. usually it's a stuck float or a water valve leaking most all the time. A low refrigerant level, weak compressor, bad TXV, or a leaking hot gas valve are usually secondary issues but not very common. In rare cases, the evaporator plates can separate from the refrigeration tubes. look at evap plates at the bottom and top and see if they are bowed or odd shaped.
May 03, 2017 | Hoshizaki Freezers
Steady beeping on hoshizaki ice machine
You have a relay or starter going bad. It definitely needs servicing. I am assuming you have called tech. I would turn it off until you get it fixed even if it is still making ice. This may indicate something is seriously wrong or about ready to shut down.
Feb 12, 2013 | Hoshizaki Freezer Commercial Ice Machines...
I have a Hoshizaki KM900MRH ice maker. It will run fine for a couple days then shut off and beep 3 times within 3 seconds. I am told by tech support that it could be a float switch. Where is the float...
float switch is usually a white plastic unit with a black rubber boot on the bottom. you need to drain the water out of the sump before doing anything with the float.
Aug 01, 2011 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki KM-500MAH is making sliver/chip ice. I
just to let you know you need to use nickel safe ice machine cleaner. and i hate to tell you this but if you are seeing silver chips in your ice your evaporator is shot. even if it is under warranty they will not give a new plate just for the reason of not using nickel safe cleaner. hope this helps you. i have seen this many times as im a service tech. alot of restaurant owners use coffee cleaner and also destroy their plates
Jun 05, 2010 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki ice maker am-50bae . Made ice regularily--- filled ice bin half way...next day-- all ice melted away with no more new ice? next day shut off for 3 hours now o new ice.
make a few quick checks. If there are water filters on the system, be sure they are not restricked. Could be clogged. Next, check the bin stat. It usually is mounted in the ice bin. If it breaks or goes bad, it shuts down the machine. Start there and let me know if I can be of any further help.
May 19, 2010 | Hoshizaki Freezer Commercial Ice Machines...
My ice maker 10amps fuse burn out when turn on the machine
This may sound too simple. A fuse is a safety. It usually blows when the amps are higher than the fuse rating. Since yours blows immediately, I would look very closly for a pinched wire, a crossed wire, or a wire that has rubbed through. Once that is eliminated, start isolating components one at a time. Check their web site. It's pretty good. Also, their tech support line is pretty good. It's worth the wait. 1-800-233-1940.
Jan 22, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Waterpump of Ice Machine KM-500MAH-E
Always attempt to have Hoshizaki pumps rebuilt when possible. The parts are cheap compared to buying a new pump. Check ebay from time to time I have just started tearing units down and selling the used parts, that are still functional. Sold that pump for $75 last week
Nov 06, 2007 | Hoshizaki Commercial Freezer KM-500MAH
Hoshizaki Freezer Commercial Ice Machines - KM900MRH Commercial Ice Machine Logo
117 people viewed this question
Top Hoshizaki Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Hoshizaki Freezer Expert? Answer questions, earn points and help others
