Question about IBM ThinkPad i Series 1412i Notebook
IBM think pad type 2611-472 cmos battery replacement
SOURCE: IBM ThinkPad R50e
So wait, its asking for a BIOS/CMOS password? If so, one thing you can try to do is remove the CMOS battery. The battery is about the size of a nickel and can be found on the bottom of your laptop. You'll have to unscrew a few things to find it. Once you do, take extreme precaution when touching anything inside the computer. I would recommend getting an Anti-Static Wrist strap (sold at Best Buy). Once you locate the CMOS battery, take it out. Keep it out for about a minute and then put it back in and close everything back up. When you do this it usually resets the BIOS/CMOS password if there is one. Hope this helps!
Posted on Jun 24, 2008
noisegate
  • 56 Answers
SOURCE: ibm think pad t30
you need to be techy on this one. you need to open the laptop. before you do that, be sure to remove all source of power (ac adapter and battery). press and hold the power button to drain all excess power. check the motherboard and reseat the CMOS jumper. it looks like a tiny pin. after reseating the jumper, reconnecting power and turn on the laptop.
i hope this helps.
Posted on Sep 16, 2008
ginko
  • 19396 Answers
SOURCE: Requird Lan Driver of IBM Think PAD LAPTOP
Drivers for Vista are not available.
You can find all drivers for R50 clicking below:
IBM Thinkpad Driver Download models R50
Posted on Mar 03, 2009
bhagyavichar
  • 414 Answers
SOURCE: IBM R30's CMOS Battery Replaced but still trouble
probably itz either minor case of software corruption/improper ground/cpu fan..
or major case of faulty or defective main board/ram/addon/daughter cards..
..plz do check the following as in order:..
the Hardware part:..
1)a) in power-on mode, open/unplug the data/vga cable of the monitor from cabinet..see if raster or 'osd' is appearing on the monitor screen..if so monitor is ok..else replace the monitor and see..[not applicable in case of laptop]..
b) in case of laptop try to get output from external display unit/monitor using vga port..if there's proper display in there..the problem is probably with either the 'lcd' or 'ccfl' or 'inverter circuit'..
2) if u hv a graphics card, replace with a standby or onboard and see..[not applicable in case of laptop]..
3) unplug mains supply..pick open/remove the cmos battery..check (above +3v)..resit..
4) see if the ram(s) is loose/faulty..open clean/remove carbon & or oxide formed on the teeth with an eraser n resit it..or replace with a standby n see..
5) a) see if ur hdd is noisy or emitting any 'ticking' noise (like 'tuk tuk' or 'kirr kirr')..
b) or if the system is not supporting either the newly installed device or itz software/driver /firmware
if so, u need either a fresh os installation or ur hdd is likely to b replaced..
6) remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistance n many more..resulting an increase in heat..
7) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market)between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
8) on main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(espabove1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector..the crystal clock generator (if cpu isn't heating up)..
9) [in case of desktop] the smps itself may b defective/faulty..check the outputs of smps viz. 0v (black~ground); +12v(yellow); +5v (red, green~ps-on, violet~pg& grey~sb); -12v (blue);-5v(white); +3.3v(orange)..the 'oscillator and error amplifier ic',or pwm switching regulator circuit..look for defective protector-transformer/resistance (esp 4.7k)/mosfet..
check the battery n adapter [main power], in case of laptops..
plz give higher priority to step 8 & 9..
the Software part:..
1) hv a licensed and UPDATED antivirus installed (i prefer avg/kaspersky,remember, without updation a full version antivirus is useless)..
2) download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
3) download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'remove all the unnecessary startup items from here..(if u can't find what to remove, post me/us in ur comment with all the items listed in each n every tabs herein)..
4) remove all unnecessary software from add/remove programs..
5) download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
6) disable the following:..
a) 'Automatically Restart' right click on my computer->properties->advanced->startup n recovery->(un check on the) Automatically Restart;
b) 'Error Reporting' right click on my computer->properties->advanced->error reporting->disable error reporting->(uncheck on the) 'but notifyme when critical error occur'..
7) Increase the size of Virtual Memory, Initial: 1440; Maximum: 2880
if u r not a professional, always better to seek advise from ur system admin/vendor....
Posted on Nov 23, 2009
contratek
  • 83 Answers
SOURCE: How do I replace the CMOS battery in IBM A31 laptop?
here is the link to the hardware maintenance manual .. Go to page 75 and this will give you step by step instructions
http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-39796
Posted on Feb 12, 2010
Where do I find cmos on think pad to replace it
CMOS is soldered to the motherboard, and therefore is considered not replaceable. Are you confusing CMOS with system memory? Google make, model, and replace memory for suggestions.
Mar 05, 2015 | IBM ThinkPad 310ED Laptop AC Adapter...
How do i fix my ibm think pad with 161-163 error on start up What's your problem?
you need a new clock battery (on the motherboard), then reset time and date and after a few turn ons it should be fine
Oct 19, 2012 | Computers & Internet
Hi drifty169
Looks like you need to change your CMOS battery
Here are the following code descriptions:
Please take time to rate me
Bud
Note: for some pointers on how to replace the battery go to this webpage:
http://www.instructables.com/id/Replace-the-BIOS-battery-on-an-IBM-Thinkpad-600X-C/
161CMOS configuration lost (battery has died)162CMOS checksum error, CRC error, or adapter ID mismatch163CMOS error; Clock is not updating
Oct 19, 2012 | IBM ThinkPad 600X Notebook
Replace bios battery- IBM think pad 2656
Hi ainival800
You will have to remove the keyboard, the CMOS (Bios) batter is there, it will plug into the motherboard.
Remove the battery from the laptop, then remove the screws from the back of the computer that is holding the keyboard.Remove the plastic part that holds the touchpad/and click keys...the CMOS battery will be there.
Please rate me
Bud
Sep 30, 2012 | Computers & Internet
Ibm think pad 2611 1452 cmos battery how to replace
There are multiple panels on the underside of your laptop. You can start by removing those and seeing if you can locate the battery there. If it is not under those panels than try removing the keyboard. If you still can not locate the battery from these then you will need to completely disassemble you laptop chassis to locate the battery.
I wouldn't suggest disassembling the entire chassis as reassembly can be difficult.
Nov 21, 2011 | IBM ThinkPad Computers & Internet
I am getting an error code of 00161 and 00163 on my ibm think pad 2635
Error code 161 means your CMOS battery is dead and 163 is that system date and time are not set (which make sense as the CMOS battery is dead).
You need to replaced your CMOS motherboard battery to resolved this issue.
May 19, 2010 | IBM ThinkPad 380ED
Where is the cmos battery located on the think pad model 2628
http://www-307.ibm.com/pc/support/site.wss/MIGR-50626.html
Click above link to see the video how to remove battery in your think pad.
please let me know if you have any further questions or concerns.
Thanks..
May 03, 2010 | IBM ThinkPad A21m 2628 Notebook
PASSWORD COMOS IBM THINK PAD R50
Hi, If you are talking about the Boot, HDD, Bios password, then the only one way to recover it is to implement a chip on the systemboard to shorcut the protection or to contact Lenovo for a systemboard replacement. Unfortunalty, no other ways other round. Thanks and have a nice day J-
Nov 05, 2009 | IBM ThinkPad T23 Notebook
To solve problem on my IBM \Think Pad T2 2 PC
Error 00174 is a configuration related indicating the bios/cmos settings are incorrect. This usually occurs when the cmos battery is in need of replacement.
Get that battery replaced.
Dec 19, 2007 | IBM ThinkPad T22 2647 Notebook
IBM ThinkPad i Series 1412i Notebook Logo
414 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
