Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
My washer deplayes LF and when that shows the machine unlocks and water in still in tub water does not fall down
    Brigadier General:
  • 8,619 Answers
Thanks for using FixYa. Error LF means long fill, which flashes when the water level won’t change for a period of time after the valves are turned on or the water has disengaged the basket but control does not detect a water level change. TO resolve this issue check if the water supply is turned on and the hose screens are not plugged or kinked. If the water is not entering the machine then check the water valve, also check the pressure hose connection to the machine/motor control. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 28, 2010
What does the LF code mean?
Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change.
  • Is water supply connected and turned on?
  • Are hose screens plugged?
  • Is water entering the tub? If so check pressure hose connection to machine/motor control.
  • See TEST #2 in manual
Jun 20, 2014 | Whirlpool WTW5600XW 3.6 cu. ft. Cabrio Top...
Whirlpool LF Error code
LF = Long Fill
Oct 19, 2012 | Whirlpool WTW6400SW Cabrio Washer
Im receiving the LF code what does this mean??
Check that the drain hose and water inlet hose are properly installed, and undo any kinks or clear any clogs if the display error reads "LF" indicating that the load is taking too long to fill, or "Ld" indicating that the washer is taking to long to drain. If the code reads "HC," the hot water hose is installed in the spot for the cold water hose and vice versa.
Also, check this information from Whirlpool DataBase: Display shows LF
Hope helps (remember to rate and comment this answer).
Sep 13, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
The washer is not finishing cycle shows the code LF
LF = Long Fill
Is water supply connection turned on.
Are hose screens plugged? ( these are inside the inlet on the machine where the hoses connect )
Is water entering the tub? If so, check the pressure hose connection to the machine/motor control. This is the main control unit. There is a service manual inside the machine. If you open the top of the unit with a screw driver in the front, the manual should be on the inside of the front panel.
Aug 17, 2011 | Kenmore Washing Machines
What does LF mean on the washer? When I start my load it pops up as LF and stops washing. What do I need to do or what is wrong?
LF (F30)
LF flashes when the control don't sense any water coming in like it is supposed to do. Things to check:
Hoses connected; water turned wide open.
Is water siphoning out due to having the drain hose too low? (30 inches above the floor)
Pressure hose from tub to control loose, pinched, hole, Sediment in tub? themobilian_1135.jpgthemobilian_1136.jpgBlow that tubing out and re-secure; retry with water OUT of tub so the pressure can properly build in that tubing. themobilian_1137.jpg
Bravos codes and service manual HERE
Jan 29, 2011 | Maytag Bravos 3.8 Cu. Ft. Washer
Washer starts then gets LF code
rwer
Hello and sorry to read about you LF issue
LF means long fill. Turn off the water and remove the hoses from the back of the machine, inspect the screens inside the washer water valve for debris. Stick the hoses into the washer tub and turn the water on, verify you have good water flow. If all of this checks ok then you either have a bad water valve or the control is sending power to the secondary diverter valve but not the primary hot/cold valve or vise versa.
I tried to help you.Please help me and rate/vote my response
Thanks and good luck
Dec 24, 2010 | Maytag Bravos MVWB400V Washer
I GET A LF CODE ON MY WASHER WHAT DOES IT MEAN
Good Luck!
Feb 24, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Cold h20 not going into tub, and LF light comes on when tub empty
Is the cold water valve on if so your water valve screen is probably clogged . disconnect your hoses from the machine and clean out the sediment. LF is long fill the rinse is usually cold water .that you do not have. good luck let me know what you find.
Jan 13, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washer Won't Fill
ok at first you got no water, by simply reversing the hoses now you get to much water?
LF Long Fill If the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed.
Press STOP/CANCEL to clear the display
was trying to find how the hoses are supposed to be, im thinkin the should kinda fall in the rigth position as to which side shoudlbe which. if you set to spinn only does the water now drain out ?if not then the hoses are definelty reversed now, which would put us back to the original issue
Apr 02, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Kenmore Oasis HE 2708..LF error code
LF = Long Fill
If the water is on and screens are clean there is a test you can do to check the log valve. There should be a repair manual inside the front panel of the machine. If yo use a screw driver in the front to open the top you should find it on the inside of the front panel. Good Luck
Dec 02, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
26 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
