Question about McCulloch Garden
I have a maccat 38cc chainsaw. It was given to me and won't run. I have it mostly disassembled and see that several fuel lines need replacing which I will do. Since I have it apart , is there any way I can test the magneto/coil gizmo to make sure it is putting out spark. If that is not working it is easy to install a new one while I have it apart.
dontbother10
  • 2220 Answers
SOURCE: need to peplace fuel line in gas tank.whats the easy way to do i
Watch the video, bar far the best method I have found.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
• The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
• If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
• The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly.
Posted on May 10, 2010
  • 4 Answers
SOURCE: Ryobi chainsaw magneto gap
The gap needs to be as narrow as possible without any actual rubbing of the rotor against the magneto. The spacing is not as critical as with spark plugs or points (remember them?) since unlike those gaps there is no spark jumping across this gap.
Generally, as long as the magnetic field is strong enough, the magneto will produce the necessary spark at the spark plug. The closer the magnets are to the coil, the stronger the magnetic field will be across the coil, and therefore the stronger and hotter the spark.
I have replaced magnetos and they are simple to install, and almost impossible to mess up if you do it this way. All you need is a piece of thin cardboard (not corrugated). I use a glossy business card without raised lettering (so it slides easily), or the like.
1) Rotate the flywheel so that the magnets are NOT positioned in front of the magneto, then loosen both screws of the magneto so it can move freely.
2) Insert the business card between the magneto and the flywheel such that the glossy side of the business card faces the rotor.
3) Then BEND the business card back over each side of the magneto (in other words away from the flywheel) so it stays fixed and can not move from side to side when you rotate the rotor.
4) Then while pinching the magneto and ends of the business card tight between your fingers, rotate the flywheel to position the magnets directly in line with the two sides of the magneto.
Note: The magnets will grab the magneto and try to move it. As long as the slippery side of the business card is facing the rotor and you haven't removed the screws, it should move fairly easily.
Since the magnets want to pull tight to the magneto, but the business card thickness is the same across the entire surface, this gives you an even spacing between both sides of the magneto and the rotor. Essentially, the magnets on the rotor do all the work for you. with regard to alignment. As long as the magnets (flat shiny polished square surfaces on the outer rim of the rotor) align directly with the two faces of the magneto, the alignment is automatic.
5) Once you have the magneto and rotor in perfect alignment, cinch down both screws in an alternating method, first just to where they start to grab, and then back and forth a few times until they are firmly tightened.
6) Now, unfold the flaps of the business card and let it move with the rotor instead. You should be able to rotate the rotor away from the magneto and the business card should slip out easily. It may stay where it was or it may slide out from the magneto - either way will work.
7) Once past the magnets, the business card should come out. You may have to move the rotor back and forth gently a few times to get it to come free. When you are done, the magneto should be in perfect alignment with the face of the rotor and the rotor should spin freely without any rubbing.
8) Confirm the above and then reassemble and go cut some trees.
Phil
Posted on Jun 01, 2010
Testimonial: "Thank-you very much, just as I suspected - had not come up with of an alternative to the feeler gauge so that was most helpful."
  • 4088 Answers
SOURCE: I can't start Spear and Jackson 38cc Chainsaw
Remove the spark plug and test for blue, snappy spark. If nothing, try a new plug set for 0.020" gap. If still nothing, remove the cover from the flywheel side to expose the ignition module. Remove the ignition switch wire from the module and try for spark again--if ok, check for a grounded ignition switch or the wire itself. If still nothing, replace the ignition module. Use a thin business card for a pole gap between the module and the flywheel magnets. Allow the module poles to contact the magnets, then tighten the screws. Rotate the flywheel to remove the card. If you got spark in the first test, then place some fuel mix in the plug hole and try to start. You should get several pops. If ok, then work on the fuel system. Check the fuel filter, air cleaner, and muffler for plugging. Check the fuel lines for decay or other damage. Make sure the carburetor fasteners are tight. If the machine is fairly old, you should check the condition of the lower chamber diaphragm in the carburetor--it may have become hard or cracked. Hope some of this helps!
Posted on Jul 01, 2010
  • 2239 Answers
SOURCE: PowerMac by McCulloch PM425AV-18 38cc.
Are you sure you have conected the pipes the correct way round, the fuel hose from the tank with the filter on the end goes to the main fuel inlet on the carb, nearest to the alloy pump cover, the other conection off the carb goes to the shorter conection on the back of the primer, the longer pipe on the primer goes back to the tank, just remember the primer pulls fuel from the carb, into the bulb, and back to the tank.
Posted on May 15, 2011
  • 2239 Answers
SOURCE: How do you hook-up new fuel lines on MacCat 2.3
OK, there are two conections on the back of the primer, the longer conection is the pressure side, so this has a hose back to the fuel tank, it will just push into the tank with nothing on the end, the shorter connection on the primer is the suction side, this pipe will go to the carb, the conection nearest to the metering cover of the carb, usually a chrome cover held with four screws, the other connection on the carb, nearest to the pump cover, usually alluminium held with a single screw, goes to the fuel tank with the fuel filter on the end, just remember the primer pulls fuel from the carb, into the bulb and back into the tank.
Posted on Jul 03, 2011
Testimonial: "Explained well. Thank You"
Need to know carb mixture
fuel mixture for 2 stroke' s is 20:1
100ml of oil in 5L of fuel
Mar 13, 2015 | Oregon McCulloch 12" Chain Saw Repl. Chain...
Won't idle and when trigger is fully engaged it bogs out?
This could be several things..fuel filter in tank clogged, hole in fuel line, clogged carb., hole in carb. diaphram or leaking crank shaft seal under flywheel or chain sprocket,,,engine block acts as fuel pump..hope this helps
Jul 25, 2012 | Craftsman 38cc 16 In. Gas Chain Saw
How do you hook-up new fuel lines on MacCat 2.3 38cc. Primer bulb 2 places, carb 2 places, tank 2 places Old lines deteriorated where do hoses hook-up
Jul 02, 2011 | McCulloch Garden
PowerMac by McCulloch PM425AV-18 38cc. I have replaced the line from the fuel mixture tank to the primer bulb & replaced the primer bulb. Now the chainsaw won't keep or looses the prime. Now...
May 15, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Have an xl 240, won't start. put fuel in carb and it runs, doesnt seem to get fuel from tank. How to fix this?
Check fuel line for obstruction first then you need to disassemble your carb a give a full cleaning maybe even rebuild it. Check out this link and watch the chainsaw video. smalleng.com
Nov 20, 2010 | Homelite 33cc 38cc 45cc Chainsaw Oil Pump...
Need to peplace fuel line in gas tank.whats the easy way to do i
May 10, 2010 | McCulloch Garden
I have a walbro WT349 on a mac cat 38cc. chainsaw
Leave the hoses a little long an try it. Logic says the uppermost carburetor connection goes to the priver bulb, but you and I both know logic does not always work.
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
McCulloch IPLs (600160) You provide the prefix and suffix.
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
HTH
Lou
Feb 07, 2010 | Garden
I have a poulan pro 38cc 16"chainsaw about 5 yrs. old. It ran fine until I let it sit too long and when I went to use it,discovered the fuel lines had disentegrated. Replaced the lines,drained the fuel and...
SOUNDS LIKE YOU FOLLOWED ALL THE CORRECT PROCEDURES. TRY TO GOOGLE SEARCH YOUR POULAN PRO MODEL #, I'VE HAD ALOT OF LUCK GETTING MANUALS AND DIAGRAMS FROM THERE. GOOD LUCK!!!
Jan 24, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Garden Logo
209 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
