Question about Sentry Fireproof Safe
How to change my combination to my sentry v252 safe
SOURCE: sentry safe V530
Send a notarized letter stating you are the owner of the safe with the serial number and a $8.00 money order to
Sentry Group
Attn: Dept 200,882 Linden Ave
Rochester N.Y. 14625-2784
Posted on Oct 23, 2007
  • 9 Answers
SOURCE: Forgot Digital Combination of Sentry Safe Model #SO500
https://www.sentrysafe.com/customerCare/retrieveCombination.aspx
They should be able to help. I would try calling first, to avoid paying the $12 to retrieve the combo, but with the serial number of the safe, they SHOULD be able to help you over the tele.
Posted on Feb 08, 2008
SOURCE: changing the combination
Log onto www.sentrysafe.com and the owners manual can be downloaded free.
Posted on Jun 01, 2008
SOURCE: know combination, but cannot open sentry safe 1250
Make sure you are working the dial properly for this type of safe. With the door lever fully counter clockwise, turn the dial clockwise a couple turns to start. It should turn quietly. Then turn the dial counterclockwise (LEFT) to the first number in the combination. Now turn the dial clockwise (RIGHT) a full turn passing the first number again, and additionally clockwise to the second number. Then turn the dial counter clockwise from the second number directly to the third number. Try to open with a sharp movement of the door lever clockwise. If this does not work the first time try adding or subtracting ONE to each number in the combination in case the mechanism is worn. If it still does not work it is time for a drill and a power saw to cut the thing open!
Posted on Mar 15, 2009
SOURCE: cannot open sentry safe, model 1230, have combo
cannot open sentry safe, model 1230, do not have combination
Posted on Mar 15, 2010
Where do you put the key
Lift the push button panel.
May 25, 2017 | Sentry Home Security
I have a sentry safe r4132 can the combination be change Thank you
I have a sentry safe R4132 can the combination be change .,SN. AN165498
Jul 03, 2008 | Sentry Fireproof Safe
I need the factory unlock code for a Sentry Safe v252
I believe you can only get this from Sentry themselves. If not a lock smith is your best bet.
Jun 05, 2016 | Home Security
I need to open a Sentry safe V252 and I don't have the combination?
get an oversized flat tip screwdriver and a hammer and slide the flart tip in the gap where it opens just above the combo and swing away it will break the lock loose and you will be able to open it
May 21, 2012 | Sentry Fireproof Safe
How do i change battery in v252 safe please
The plastic plate at the front of the V252 below the keypad has a small hole. Use a pen or paper clip to press into this hole and at the same time slide the plate to the right. This will reveal the battery container (4 x AA). The code will not be lost if you replace the batteries, and this can be done with the door shut
Jan 09, 2011 | Sentry Fireproof Safe
How to creeate a new combination for a sentry 1310 valueguard saf
Have a 1310 Sentry Valueguard safe and cannot remember the combination nor can i remember where i put the paper that i once wrote the combination down on....need help!
Aug 01, 2010 | Sentry FIRE-SAFE Combination Safe DS3431,...
Unable to open electronic safe
Locksmiths say this is how to install sentry safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Mar 06, 2010 | Sentry Fireproof Safe
I WANT TO CHANGE COMBINATION ON MY SENTRY FIREPROOF SAFE HOW?
I have a sentry safe csw 4747 Idont no tha combination
how do I do the safe a key and electronic key pad
Jan 11, 2010 | Sentry Fireproof Safe
Need to open a Sentry keyless combination safe
First, has the factory combination been changed? Sentry has the code for the factory combination that they can supply you.
If the factory combination has been changed to something else, then Sentry won't have it.
In that case you need to ask Sentry for a 'reset' code combination. There is (at least) one back door to your safe -- a reset code.
The reset code will not tell you what your combination is, it will simply reset the combination to the factory combination.
You can take it from there.
Now, this isn't as hard as it may sound. There is an actual department that handles this at Sentry because you aren't the only one that cannot open his safe.
They'll want some proof of ownership, some $$ for the service, the safe serial number, and probably a notarized form claiming that the safe is yours.
Get 'hold of Sentry on the web and the rest is just process.
BTW -- this is exactly what the locksmith would do.
Apr 10, 2009 | Sentry Fireproof Safe
Changing the combination
These sentry safes dial combinations are not built to be changed as they have no key change hole. Switching the order of the tumblers could be done by a trained locksmith. I would suggest buying the electronic sentry safes as these safes can be reprogramed.
Jan 04, 2009 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
625 people viewed this question
Top Sentry Home Security Experts
Hannah Johnson
Level 1 Expert
ray012965
Michael Galve
Michael Galve
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
