How to replace a latch on the Whirlpool Duet Washing Machine
  • 248 Answers
Unplug unit!!
Remove outer boot clamp by prying off at bottom. Peel boot back on right side. Remove screws holding latch assembly.
Reach through area exposed by peeling back boot and pull out lock assembly. Unplug unit and install new one. Reinstall boot.
Posted on Aug 28, 2010
WFW9200SQ00 Whirlpool washing machine. Door strike doesn't go in the latch, seems a mechanical issue. There is a little white pin inside the latch on the way. Any ideas what can be wrong?
Does the door strike seem to be broken and is that what you see inside of the latch asm.? if no the strike is ok i suspect the latch itself has broken apart and your seeing a internal part of it through the opening where the strike fits into, in which case the latch/lock assambly would need to be replaced.
The part numbers are
DOOR LATCH ASM. 8183270
DOOR STRIKE W10217552
GENE
Oct 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Tip
Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/dU error code on...
The F/dU is shown on the display due to Door Unlock Error in the washing machine.
In this problem check the Door Lock in the washing machine. Either the door is getting blocked or not getting locked or the door latch assembly is got cracked.it needs to be checked and replaced.
This will help. Good Luck.
on Mar 11, 2010 | Washing Machines
Tip
Why Is WHIRLPOOL Duet & Duet HT washing machine showing F/dL error code on...
The F/dL is shown on the display due to Door Lock Error in the washing machine.
I have a whirlpool front washer and the door will not latch shut . What should I do?
Examine the latch on the door. is it broken? If so, then replace it. If not, replace the catch on the machine.
Jun 20, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a Whirlpool duet washing machine. We had a
Unplug the machine.
Remove the lower front panel.
Reach your arm up inside on the door latch side. Feel for a pull ring and pull it to release the door.
Feb 14, 2010 | Whirlpool Duet GHW9150P Front Load Washer
CODE DL Failure
door latch failure. If your crafty you can replace it yourself, there are several places online to buy parts. To get it out unplug the machine, Take the outer ring off the door gasket, roll the gasket back, and unscrew the two screws holding the door latch to the machine. Replace!
Nov 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet front washer will not come on!
SOUNDS LIKE YOU NEED TO CHECK POWER COMING INSIDE WASHER, AN IF SO REPLACE MAIN CONTROLER AN DOOR LATCH ASSY
May 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet front load washer won't start
The error codes it is showing don't even exist. Does the little round door latch plunger go in and out if you push it?If not, then replace the door latch. If so, you most likely have a bad machine control. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washing machine dooe handles
as you say the door sticks ,
so the handle is not the issue ,
your latch is ,
either it is not lubed or out of line .or has some plastic damage inside it,
it should only take a few ounces of pull ,
use your pinkie and only a small strain and its open.
any more and you have your issue .
its the latch.
unless its rubbing around the other plastic panel parts nothing should touch.
Oct 30, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
