Question about Acer Aspire 7110-2069 Notebook
Just a problem with the display - its very dark and invisible. I have checked all the settings including brightness etc. they all good and laptop functioning properly. Changing settings won't make any difference. Could you help me plz...... Laptop : Acer Aspire 5735Z Thanks Ranjit
    Brigadier General:
  • 10,406 Answers
Take the laptop into a dark room.
If the computer is on, and the screen is "normal" (icons & wallpaper & such) but still quite dim, then the "inverter" component of the LCD screen has failed.
It's about a $20 part to replace, but you should pay a qualified technician for one hour of "labour" to disassemble/replace/reassemble/test it.
Posted on Aug 28, 2010
My display is intermittent, bright to dark
go to the settings and turn the power saver OFF
Apr 16, 2015 | Dell Inspiron Computers & Internet
How do I lighten my screen
Dear Anonymous,
Please give as much information as possible. The problem may be caused by Hardware; Software; or both! Please describe the problem in detail. What kind of monitor - (screen) - do you have? Is it an old CRT - (Cathode Ray Tube) - or an LCD - (Liquid Crystal Display...?). There are usually buttons on the monitor for setting General display functions, including Brightness/ Contrast etc. Try swapping the monitor with a friend's one that you know works. If the good second one is as dark as...beyond adjustments on the monitor, then that would suggest that the problem lies with the computer video output...What kind of computer do you have? etc., etc.
Please help us to help you...Awaiting your response...
Oct 16, 2014 | Computers & Internet
On my laptop screan it gon a bit dak and i ned help 2 fix this
Hi , I think your laptop brightness settings had been changed. So try this to increase and reduce the brightness , contrast. Select start-> control panel -> appearance & personalization -> display . There you will have options like Adjust brightness , Adjust resolution etc., on the left side of your window. You may adjust in this way.
May 20, 2014 | Samsung HCM422W 42" Rear Projection...
Computer turns on and boots up , however, the screen is dark
Try going into the control panel and select power options see if there is way to adjust the display brightness or try holding down the "Fn" key and use F7 to increase the brightness
Feb 07, 2010 | Toshiba Satellite A75-S229 Notebook
I HAV A TOSHIBA A-135 LAPTOP, THE SCREEN WENT DARK, AND WOULD ONLY LIGHT UP ON BOOT UP ( FOR 2 MINUTES) AND THEN GO DARK. IT WOULD LIGHT UP OUT OF SLEEP MODE FOR THE SAME (2 MINUTES). I HAVE REPLACED THE...
There are steps to 'change' the visual effects of the "Display." 1. Right click on "Desktop", click Personalize, click, Display Settings. 2. Identify, Monitor used? 3. Down (arrow) select Monitors' graphics. 4. Adjust, (low>high) resolution. 5. Select, Colors (16 bit>32bit), etc. 6. Click, Advanced Settings, click Properties ("check device status"). 7. Update Drivers (only if, necessary?) 8. Click on "List All Modes" select valid (modes) for the monitor. Note: Always click on the 'Apply', and 'OK' buttons after application changes for the process to take effect. 9. Restart "Computer". *Next go, to: Screen Saver, in the Screen Saver Settings change 'Power' settings. *Next go, to: Start Menu, click on Product Name: (Toshiba), click 'Utilities' click, Toshiba Assist, click 'Optimize' click,"Display"; change power on display. *Next go, to Control Panel, in Mobile PC, click; "Adjust commonly used mobility settings" (changes the following); Display brightness, and Connect Display. “I hope this Fix it!”
Jan 18, 2010 | Toshiba Satellite A135-S2386 Notebook
Lenova laptop display problem
If the display back light iis dimmer then normal, then it is probably a faulty inverter board inside the laptop.
The inverter board is the board that powers the backlight lamp.
Check display brightness settings and power settings first, to ensure it is not a settings problem..
Feb 01, 2009 | Lenovo 3000 Y410 Laptop
Monitor too dark....
inverter board bad. this runs your lcd lamp(s) but is not in the screen.
Oct 02, 2008 | ViewSonic VA702b 17" LCD Monitor
Mac laptop displays minimum brightness
Check to see if there is a box right below that... Saying something along the lines of readjust to brightness of surroundings, etc!  Make sure box is unchecked for you, in regrds to your issue and then see if that helps!  I will look a little further into it for you!  Let me know if that helps though!
Feb 23, 2008 | Apple MacBook Pro Notebook
Screen went dark (almost completely)
check your power cord and make sure it's plugged in all the way, and if it is, check your brightness setting.
Usually it's the Fn key + an arrow key. Make sure the brightness is up all the way
Dec 12, 2007 | Dell Inspiron 6000 Notebook
Acer Aspire 7110-2069 Notebook Logo
91 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
