Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
I just moved. The TV worked fine. Now I can't get it to turn on.
  • Toshiba Master
  • 17,130 Answers
First try to reset the TV by holding on the menu and switching on. if not switch off and open.
Lets imagine that there is fault associated only with a damage during the transit. So lets us start with the power plug and the connection to the front end section of the TV.
Use a multimeter to check on the continuity of the power plug to the main board. If this seems Ok switch the mains and see if the supply comes to the main board.
The fault that needs to be checked is to look for some broken or damaged board. so look carefully if there is any crack on set ,if so bridge the lines using a soldering iron.
Now check if any connectors have come out of socket.if so tighten all the sockets in the boards.
Now the next point of check is to see if the power is coming to the board , then the secondary circuit of the SMPS to the microprocessor board. If the supply is coming inthere should be a display in the front panel.Try to replace the battery in the remote and switch on.
The fault can only be in any of these points as the set had worrked before the transit. so take you time and use the logic of seeing that the power reaches out to all boards.
Posted on Aug 28, 2010
  • 10,594 Answers
Is it Toshiba 42WLG66 tv or any other model?
Does power indicator lit on tv front when tv plug in wall socket?
Did you checked wall socket by plugging any thing else to make sure that it is powering?
Let me know above info to diagnose possible cause of problem.
Thanks.
RCA model# L46WD22YX11, TV works, Sound bar on screen moves but no sound. Any suggestions.
Sounds like ( pardon the pun!) one of the TVs chops on the circuit board are gone. Costly enough repair, how old is the T.V? Is it under warranty?
Jan 18, 2015 | RCA Televison & Video
RCA 36' tube tv won't turn on
possible that a fuse blew while transferring tv, most like to happen despite care in handling if tv was on for a while, kind of like moving a light bulb that is hot and suddenly filament breaks when you move the bulb slightly. Other than that I'd say it's a good time to get a new tv just in time too for the digital transition.
Feb 06, 2009 | RCA F36450 36" TV
Dell plasma 42 inch
fot the most part, you have solved your problem (pow bd), The main bd may also need to be replaced as well. The is a signal upon powering up the system. the pow bd communicates with the signal board. The signal bd, also is responsible for ALL of your additional I/O lines. Between the two of these, + a firmware update, i think the tv will be just fine.
Feb 03, 2009 | Dell W4201C 42 in. Plasma HDTV
Tv won't turn on
i can' turn on my sony tv . no lights are blinking. nothing. could something when it was moved.
Dec 30, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Insignia LCD 27" w/vertical lines for picture
Happens with mine also usually happens when you change channels alot all you need to do is shut tv off and turn it back on.
Mar 09, 2008 | Insignia LCDTV26 26 in. Television
Mitsubishi CS-35505
Had the same issue. Try hitting the input button on the remote. Then chose aux. 1 option. Worked for ours.
Dec 28, 2006 | Mitsubishi CS-35505 35" TV
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
32 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
