Question about Boston Acoustics GT-24 Car Amp
The amplifier will turn on and give out put for limited time then it turns off and the red led comes on. ive rewired it twice now and the grounds are all good
Your over heating check and see if you can put in cooler spot also make sure u are getting good voltage through wires use a volt meter on pos and neg connectors at amp while radio is down and then when it is 3/4 volume should not drop more than.75 if is then go with bigger wires also if that does not work and amp is hot to touch check on installing fans
Posted on Aug 28, 2010
Theres a light on inside my amp, but the power light wont come on. ive rewired it several times and it still wont work, i really dont want to buy a new amp. what do i do?
First and foremost, check your fuse at the battery terminal. Then make sure you are getting your 12V from your remote turn on, and lastly make sure all of the connections are properly terminated.
Sep 19, 2010 | American Pro VS1404 Car Audio Amplifier
The red protect light is coming on
It is possible that your amp is going over the threshold limit of draining current to give out the protect signal. What could be done is to first checkout if your speakers are loading the amplifier, check the rating of the speakers and the impedance, must not be too low.below 2 ohms. Now check the source signal if this is bringing in any transcient signals to power out the outputs particularily high/low freq. So decrease off your bass and treble to mid position and test again. see if there is any improvement, if so there could be a filter problem with your set. Connect an external source and see if the amp powers better , in such case check for fault in cables, input lines and ground with in the set. Repeat this and check. Hope this helps you out. Good day
Jul 19, 2010 | Verge VGA285 Car Audio Amplifier
What is wrong with my 1000w sony xplod amp?
need repairs on the inside usually when u see that fuse melt something else probably melted on the inside. something is grounding out the amp on the inside . get it checked
Jun 05, 2010 | Car Audio & Video
Led light turns red and the turns off but the amp
In Car Amplifiers have 3 main power wires:
Live +12v (Fused wire direct from the + side of the cars battery)
Ground (Direct to car earthing point (anywhere cleaned of paint for good connection)(I tend to use boot lock)
Remote (This wire should be connected with the switched live wire coming from the back of the stereo, this is Only live when the cars ignition is on)(there should be 2 power wires coming from the stereo usually red live +12v and yellow switched live, depending on the cars original wiring, try moving the remote wire from where you have it, to the other live wire
Hope this is of some help
Aaron
Aug 08, 2009 | Nitro BMW-482 Car Audio Amplifier
I have a jl 500/1v2 and when i have the volume up for some time it teens to turn the amber color light on and turns off my amp and sub i turn down the volume for like 30 sec turn it back up and every thing...
its probably wires touchin or the ground not connected well with fat enough wire. i would try to rewire and do everything all over again because one wire or fuse is messing up i had t he same probelm. its the red light on the amp is ur amp shut off or ur warning light?
Jun 03, 2009 | Jl Audio E1200 Car Audio Amplifier
Works perfect but then turns off
Be sure to have a good ground. If that is not the problem it could be the speaker or sub are hooked up to pull a certain ohm off amp and the amp is not rated to run at that ohm it will cause the amp to go into protect mode. Check how many ohms your speakers and amp are rated. Rewire speakers to specs.
Dec 02, 2008 | Kenwood KAC-8401 Car Audio Amplifier
Sony amp 1000w
Check the wiring of the speakers (both inside the box and between the box and the amp). It sounds like one speaker is wired incorrectly at one connection point.
Sep 09, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Power and led on but yet no sound
red means protect, check speakers first then disconnect all power,try again in 20 min
Aug 22, 2007 | Visonik V900XD Car Audio Amplifier
Rt 202 led light red and no sound
With the system turned off, disconnect the speaker wires from the amplifier. Turn on the system. If the light stays red, then the amplifier has an internal problem. If the light turns green, then your problem is a blown speaker, or a speaker wiring issue.
Jun 03, 2007 | MTX RT202 Car Audio Amplifier
Problems with Infinity Amp 611A
are you running a large ground wire directly to the battery negative terminal?
Jun 03, 2007 | Infinity Reference 611a Car Audio...
Boston Acoustics GT-24 Car Amp Logo
52 people viewed this question
Top Boston Acoustics Car Audio & Video Experts
xxxxxx xxx
Are you a Boston Acoustics Car Audio and Video Expert? Answer questions, earn points and help others
