Question about Hoover Dryers
How to replace a belt in a hoover apollo supreme clothes dryer?
5 Suggested Answers
SOURCE: Hanging Hoover Apollo Deluxe dryer unit from the wall
you will need to get a wall mount bracket. I found a couple on ebay for about $30.
Posted on Dec 15, 2009
heatman101
  • 43501 Answers
SOURCE: Hi We have a Hoover Apollo
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 21, 2010
HansPP
  • 2510 Answers
SOURCE: How do I change the
Remove the top cover by removing the screws at the back of the machine and sliding the cover off forwards. Now you need to obtain access to the complete circumference of the drum to fit the belt. Depending on your machine you can either remove the front of the dryer, or release the rear bearing support so that you can slide the new belt over the drum and under the bearing retainer, which may entail removing the back cover as well. The belt then just slips over the motor pulley and you need to check on the belt tension, usually done by adjusting the motor or the tensioner.
Posted on Apr 28, 2011
  • 106 Answers
SOURCE: Can I place my hoover
I do not recommend this at all!!!
Posted on Jul 16, 2011
Hoover apollo deluxe dryer
Can you give a model number?
Jan 30, 2014 | Dryers
Hoover Clothes Dryer Apollo 100 D6176
Most electric dryer problems not heating are due to the heater coil circuit being broken. The wiring can be replaced by the coil kit being purchased from an appliance parts store. Need make and model numbers. Follow directions in package.
Oct 13, 2013 | Dryers
Hoover apollo dryer motor will not turn, needs a push to turn.
What is the model number? You need the start switch replaced on the motor.
Oct 14, 2012 | Dryers
Hoover apollo supreme 5.0kg. Heating but drum not turning/rotating. The push start button was a little stiff so i gave it some wd40 and not works really well. turning on and heating but drum still not...
Check the workingg of the motor seperately to confirm if the motor is good. If so the fault is confirmed to be with the main switch- program control.
So trace using a multimeter to see the open connection. Make sure that the power plug is taken out when a continuity test is taken.
Sep 06, 2011 | Dryers
How do I change the belts on a Hoover "Apollo Deluxe" clothes dryer approximately 1995 vintage
Apr 28, 2011 | Dryers
Hi We have a Hoover Apollo Supreme D6794 tumble dryer approx 18 years old. Has stopped working suddenly. We can turn the motor manually to start it but it then stops. What could be the problem? Is it...
heatman101
Sep 20, 2010 | Dryers
Sep 30, 2009 | Hoover Dryers
Hoover Apollo Delux not drying properly and takes ages. Outlet air is hot but my wife says it's not drying as well as it used to. The front filter is clean but is there an inlet filter that I'm overlooking...
T^o much lint in duct work, causing moisture and not allowing cloths to dry. Vacuum out duct work in dryer and from dryer to outside of home.
Jul 17, 2009 | Dryers
Hoover 410 Apollo clothes dryer throws 10amp fuse
Thank you,
My machine problem was resolved by changing the heater element to one from an old machine.
Jun 18, 2009 | Hoover HDC7FM Dryer
Dryers Logo
55 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
