Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
How do i reset the keypad, as i have newly acquired this home and donot have the codes. It looks like a sears key pad and the system is a chamberlain 1/2 horsepowr
    President:
  • 3,197 Answers
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in any 4 digit code you like and press enter.
Posted on Aug 28, 2010
How do i reset my garage door key pad from chamberlain?
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to the keypad and key in any 4 digit code you like and press enter.
Nov 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
I just bought a home with a Chamberlain garage door opener and a keypad. I don't know what the previous code was. How do I reset the keypad?
Nov 06, 2010 | Sears Craftsman LiftMaster Chamberlain...
Need to reset my garage door key pad.... I do not have the key code.... Chamberlain Model 976 LM Tried to reset the pass and in doing so.... totally messed it up and now I don't know what the code is...
Sep 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
How to reset garage door opener pad without old acess number
A Stanley garage door keypad is wall-mounted, battery-operated device that allows you to open your home's garage door electronically without having to manually lift the door or use a pull chain. The keypad uses a four-digit access code that you program after the keypad is initially installed. You can change the code, disable the keypad manually by entering a invalid code and reset the keypad if the device is not working properly. After you reset your Stanley garage door keypad, the device is ready to accept a new access code.
May 29, 2010 | Sears Craftsman LiftMaster Chamberlain...
I can't get my key pad for my garage door to open. can i reset my key pad to open my garage door???
You can reset the code but it sounds like it may have just failed. Make sure the battery is good and try more than one just in case. To reset the code:
Locate the smart/learn button on the rear of the motor unit near where all those white wires go. Press and immediately release this and then walk over to your keypad and key in your 4 digit code and press enter.
Mar 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
I had to unplug the system and when I plugged it back up the keycode pad no longer works i want to reset it
This isn't a normal occurrence. The keypad doesn't need to be reset because you unplugged something. You can try programming it anyway by locating the smart/learn button on the rear of the motor unit. Press and immediately release this button and then walk over to your keypad and key in your four digit code and press enter. Be sure to also check the battery inside the keypad.
Dec 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
THE KEYPAD NO LONGER ACCEPTS MY 4-DIGIT CODE. MUST HAVE HIT THE STAR KEY OR SOMETHING & ERASED IT. HOW CAN I RESET IT? THE INSTRUCTION ON THE PAD LET YOU CHANGE IT, BUT SAYS NOTHING ABOUT RESETTING...
If your battery is good and you have followed the instructions for changing it then your keypad is bad. The instructions for changing the code is the same as resetting it.
Oct 27, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster key pad opens door with a single number punch
You are using a universal keypad and usually the 0 button is "enter" look up directions for the brand keypad you are using
Jan 17, 2009 | Sears Craftsman LiftMaster Chamberlain...
How do I reset my chamberlain garage key pad, after the liftmaster repair guy erased the code? What do I push on the keypad, while holding the green liftmaster learn button? thanks
hope you have not held green button or your renotes will bew erased. Push green button for one second. Go to keypad. Enter 4 digit code and hit ENTER. Bulb on motor should blink. That's it.
Jan 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door key pad
For most openers you don't need the old code.
Just press the program button on the powerhead enter the code you want in the keypad and press enter (within 20 seconds).
Jul 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
76 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
