Question about Refrigerators
Metal rod that ice dispenser flapper door rides on broke from plastic holder. How to fix.
  • 1 more comment
  • murland146 May 08, 2008
    Kenmore 106.56612500
  • murland146 May 09, 2008
    Problem is that plastic that holds the rod broke.
  • murland146 May 13, 2008
    Got an email asking me to rate this answer. Whats to rate? No body has helped me. Gave the model # as asked and have heard nothing. No answer, no rating.
    Genius:
  • 1,073 Answers
What is the model number
Posted on May 07, 2008
Ice dispenser door came off and inset plastic retainer gone and now way to repair as pin has nowhere to sit. gc3shexnq03
There is a kit that fix that problem it has a metal bracket that replaces the plastic one that broke
Nov 09, 2013 | Whirlpool Refrigerators
My Electrolux side-by-side refigerator automatically started dispensing ice cubes in the middle of the night and would not stop until I manually pulled the lever to the stop position. It did this on 2
I have a few ideas for things to try. On the bottom of the ice cube holder I believe there is a spring loaded metal rod that runs from the front of the freezer to a little indentation in the back of the freezer. Inside this indentation there is a small plastic piece that can move up and down to rotate the metal rod. Make sure this metal rod is free to rotate. Sometimes it gets stuck in one position. The position of the plastic piece inside the indent in the rear of the freezer is controlled by a solenoid which is controlled by the buttons on the front of the door for cube or crushed. Close all the doors and push the cube button. Open the freezer door and remove the entire ice cube tray. Reach to the back of the freezer and make sure the little plastic piece inside the indent will move up and down easily. You want it to be in its down position. Re-insert the ice cube tray. The metal rod should fit easily into the indent in the back of the fridge. Now close the door and see if you can get cubes. If this doesn't work I suspect the solenoid that moves the little plastic piece may need to be replaced. I hope this helps you out.
Aug 29, 2012 | Electrolux E23CS78HSS Side by Side...
I have model# FRS26R4AW5. The ice dispenser wil
Jan 09, 2010 | Electrolux Refrigerators
Ice Dispenser "Flapper" is loose--How does it reattach?
the plastic arms that move the flapper door open and closed are broken. I had this happen to me some months back. You will need to buy a repair kit from your local dealer. Explain what is broken and they can look up their part/kit number. You can't buy just the plastic door. Mine cost about $30 but was worth the price of getting my ice maker dispenser operating again. Very minor mechanics required to open this portion of the mechanism. Mostly some removal of screws and a spring or two. Good luck.
Apr 14, 2009 | Jenn-Air 21.6 cu. ft. Side-By-Side...
Ge, tfx26kpda ww, ice maker only dispences crushed ice
At least yours is making ice. Mine wount even make ice. While toubleshooting my prob, I notice a metal rod on the bottom of the ice tray. This rod opens and shuts a plastic "trap door" in the tray. The position of that door determines whether the ice is crushed or whole. If the trap door is open the ice falls through the dispenser freely. If the door this closed the ice is force thorugh metal teeth where it is crushed then dispensed. Open the freezer door and take the ice tray out. You should see a hole at the back of the freezer that the metal rod goes through. In that hole there is a plastic square that moves up and down. If the set your dispenser to crushed ice, leave the door open, push in the door switch at the bottom, and press the dispenser. The plastic square does nothing while the motor is turning. That allows the door to stay closed and forces the ice through the metal teeth. If you set the dispenser to whole ice and do the same thing the plastic square is suppose to lift up forcing the door open and letting the whole ice drop freely. The plastic square probably does nothing even if you set it to whole ice. That mean the trap door never opens focing the ice to always get crushed.
Unfortunately, I have no solution because mine works and I had no need to investigate further. I hopes this helps you figure out the problem though
Good Luck.
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Side my Side Refridg- Ice Dispenser Freezing Up
Check the pin that holds the flapper in place.
I'll bet the plastic is broke that holds spring and flap inplace
I have same problem
Aug 28, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Dispenser flapper door
the part number for the kit is 8201756 it replaces the plastic part that broke off inside the chute area with a stainless plate that can be put in with the double sided tape or with stainless sheet metal screws it is not that hard to install either way, there are instructions in the kit that will tell you how to install the kit
hope this helps since im doing this for Free
May 13, 2008 | Refrigerators
Whirlpool pin retainer is broken on ice dispenser
this is easy. there is a small area beside where the piece broke off. bend a small peice of metal coat hanger at a 90 degree angle, (this is so you can make your new hole on the correct line) heat the end with a lighter, burn a smallhole thru this area beside where the previous hole existed. now throw away the old pin that you were using and use a piece of coat hanger cut to the right length. on one end bend about one half inch to 90 degree angle, feed thru new hole and thru your spring and flap and thru to opposite side hole and lastly make small bend to keep wire from sliding out. ta da, fixed. problem solved for about two cents. i have successfully repaired many of these doors.
Oct 09, 2007 | Whirlpool ED2FHEXN Side by Side...
Always crushes ice
This was easy to solve after reading some posts which mention "a plastic flap" which is opened or partially closed by the metal rod running under the ice cube tray.
There is indeed a flap which is inside the front of the removable ice holder/dispenser. The flap should be able to open fully so ice can fall out. In mine it could only move 1/2 inch because the flap was laying on the wrong side of a small peg which guides it.
I was unable to free the flap to open completely by pressing on it, so I had to unscrewed six screws to take off the front plastic facing and the on the front plastic housing. Pushing on the metal rod immediately put the flap back into it's correct position. I then replaced the plastic front.
I can now have either whole cubes or crushed. Boy was that easy to fix!
A repairman recommended replacing the electronics ! !
I assume this misalignment might be caused by too much pressure when the ice cubes freeze solid or something? If it happens again, I know it's easy to fix.
Nov 06, 2006 | Kenmore 55692 / 55694 Side by Side...
Refrigerators Logo
115 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
