Question about Dryers
I think my dryer belt is broken. It is a stackable washer/dryer. How can I repair it?
  • 122 Answers
At the back of some laundry centers there is a small square panel where the motor is located. Remove panel to access the motor and belt tensioner. You will have to pull the unit out to do this.
Posted on Aug 28, 2010
Need to replace belt
Search Results
    How to repair a KENMORE double decker washer&dryer ...
    ? 4:59
    www.youtube.com/watch?v=Rc_ZGugYBTY
    May 31, 2014 - Uploaded by MrProductionist
    How to repair a broken dryer belt from a Double Decker Washer and Dryer. ... I have a Kenmore stackable Washer-Dryer, and the dryer belt is ...
Oct 21, 2015 | Frigidaire FFLE1011MW White Washer/Dryer...
No power to washer, dryer has bpower...
Might be a broken wire going down to the washer portion. I found that once on a stack dryer: Remove the control panel and look for a loose quick connect or broken wire.That was what was wrong with this un I think. Drop the splash pannel first then remove the screws to control and drop it out then check quick connects and wires is what I would do. -PawPaw
Dec 23, 2013 | Frigidaire Front Load Stackable Washer
Need belt for stackable frigidaire washer and dryer. Model is FEX831CS The washer jerked and threw a breaker. Now the dryer won't work and the washer lets water run in and the inside starts jerking hard
If you think that the washing machine belt is the cause of your troubles you can find it in the very bottom of the machine (behind the front panel)
Would need more info on the dryer problem, (Is it running with no heat or not running at all)
the washer drive belt is the only easy fix on this model.
Good Luck
Quentin
Aug 21, 2009 | Frigidaire FEX831CS Top Load Stacked...
Stackable dryer makes thumping noises -think its a broken belt
9 out of 10 times this is due to a bad roller. This is not something you can do yourself. A stack model is just too complicated.
Jun 09, 2009 | Kenmore 84052 Dryer
Dryer will not start, just humms
sounds like the drum belt maybe broken or worn out.
May 25, 2009 | Kenmore 98702 Stacked Washer/Dryer
Stackable washer/dryer
hi..
When your dryer drum isn’t turning anymore, it’s usually a broken belt. Tearing the dryer apart is usually straight-forward enough but stringing the new belt on the motor and idler pulley can be tricky. The Complete Encyclopedia of Dryer Belt Configurations shows the belt configurations for almost every dryer brand you can think of.
this will fix ur problem..
thank u rate me
May 25, 2009 | Kenmore 93702 Top Load Stacked Washer /...
Dryer comes on for a few minutes, makes horrible sound and goes off. now won't start at all. Frigidaire stackable
It could be the belt was partially broken, and as it came apart causing the dryer to no longer start,,, it made the noise your talking about. If the dryer still heats up, and you can hear the motor running,,, these would all be signs toward a broken belt.
Mar 13, 2009 | Frigidaire FEX831CS Top Load Stacked...
Maytag stackable dryer
STACKABLES ARE NOT KNOWN TO HANDLE TO HANDLE HEAVY LOADS.TRY PUTTING LESS IN THE DRYER.
Mar 07, 2009 | Maytag LSE7806A Top Load Stacked...
Ge spacemaker washer and dry stackable.
if you have a broken belt... remove the back. and the drum support. then you can remove the belt... and replace it with the new one...pull back the pulley and them loosen the belt... let me know
Sep 16, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
Dryers Logo
42 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
