Question about Kenmore Elite HE4 Electric Dryer
Dryer shuts off after 5min (code E1) - Kenmore Elite HE4 Electric Dryer
  • 3,230 Answers
Well the error E1 message indicates that the thermistor is defective and needs to be replaced.
Try unplugging the unit for a few minutes got rid of the error, but lately the temperature just hasn't been hot enough so the clothes don't dry. You must need to replace the thermistor for full working of your dryer. you may please follow the below steps to know how to change the thermistor -
1. Locate the thermistor on the top right hand side of your dryer. This will be a small platelet with a chip and wires coming out of it. Use your screwdriver to remove the two screws holding the thermistor on the unit.
2. Unplug the wires from the thermistor.
3. Plug the wires into your new thermistor. Replace the thermistor on the dryer and the screws holding it in place.
4. Replace the back panel of the dryer and plug your dryer back into the wall outlet.
5. Push your dryer back up against the wall and turn it on again.
Good Luck!!
Thanks for using FixYa!!
Posted on Aug 28, 2010
Kenmore dryer error code e1
The E1 code on this dryer indicates that you have an "open" (defective) thermistor (temperature sensor). Replacing this part will likely fix your problem. What is the model number?
Nov 12, 2012 | Dryers
Kenmore ht3 dryer, the dryer runs for about a min. then shuts off. the code E1 comes up. i have clean the vent out from within the the dryer. is their a sensor that shuts it off or what.
The error code E1 indicates that the thermistors is open or having a very high resistance. Click on the link below for the detailed troubleshooting of the thermistor.
Whirlpool Duet and Kenmore Elite Dryers Thermistor Troubleshooting
Jul 19, 2011 | Dryers
A code E1 flashes the dryer shuts off and the clothes are still wet
The fault code E1 means the electronic control detected the thermistor is open. It's either the wire harness connecting the thermistor and electronic control is broken or the connection is loose or the thermistor is indeed open. Measure the resistance of the thermistor then refer to the temperature and resistance table for the normal thermistor resistance values.
Troubleshooting Error Code E1 on Kenmore Elite and Whirlpool Duet Dryers
Oct 25, 2010 | Kenmore HE5
Dryer runs for about 5min (has heat ) then stops, error code E1
usually that means you have a bad thermistor.
try setting it to low heat timed dry
how long does it run?
Aug 28, 2010 | Kenmore Dryers
Whirlpool eletronic electric dryer runs for about 1 min. shuts off E1 displayed
The E-1 code is: Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} E1 Keypad keytail not connected.
So that means you need to get in the dryer where yo can assess the back of the key pad and check the connector.
Jul 16, 2009 | Whirlpool Dryers
I constantly got E1 Error code on my Kenmore Elite H3 GAS dryer
E1 error code indicates an open thermistor or open thermistor circuit. A thermistor is a component that relays the temperature in the dryer to the control board. If the thermistor has failed, Error code E1 will be displayed.
You need to call a repair person to fix it.
Dec 18, 2008 | Kenmore Elite HE4 Electric Dryer
Whirlpool Duet dryer error code E1 keeps coming on after a few minutes of running shuts down dryer.
E1=Thermistor open
post your email and i will send you the steps to fix and check it too much to type here
Aug 05, 2008 | Dryers
Whirlpool Electric dryer E1
An E1 Code is a thermistor fault TEST #3a Thermistor Test
The machine control electronics monitors the
exhaust temperature using the thermistor, and
cycles the heater relay on and off to maintain
the desired temperature.
Begin with an empty dryer and a clean lint
screen.
1. Plug in dryer or reconnect power.
2. Set the following configuration:
➔ Door – must be firmly closed
➔ Press Control On
➔ Press End Of Cycle Signal (Louder)
➔ Press Start
3. If after 60 seconds, E1 or E2 flashes in the
display and the dryer shuts off, the thermistor
or wire harness is either shorted or open.
➔ Unplug dryer or disconnect power
➔ Check wire connections at the machine
control electronics and thermistor.
To access the Thermistor you will need to open the bottom front panel 2 screws the thermistor is on the exh duct (Center) check it there let me know if you need futher help
Dec 09, 2007 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Electric Dryer (5yrs old)
screen.
➔ Press Control On
➔ Press Start
Nov 10, 2007 | Whirlpool GEW9250 Electric Dryer
Kenmore Elite HE4 Electric Dryer Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
