Question about Ariston Technologies Ariston AWD12 Front Load Washer/Dryer
Hi and thank you for you possible help. After starting my front loader, Ariston AML125 s/n 504273457, (Which I am hoping is close to your Ariston Technologies Ariston AWD12 Front Load) washing machine, the ON-OFF/DOOR LOCK Led flashes rapidly at the same time as the "4h" Led. The wash powder was gone from the tray, but not the softeners, but the washing was still dry. You could hear the water like draining or taking water, all hoses were OK. No signs of water leaking and no smells of burnt solenoid type things, I've had the top off and back, the belt is OK and nothing looks out of place. Any help would be much appreciated. Regards Digger-HB
    Genius:
  • 1,417 Answers
what this indicate is that there is a blockage on the water lay(pipe or drainage ) water out flow.
what you need to do to fix up this problem from first of all put off all form of power supply connected to the washer then bale out the water from the drum and them trace the pipe(hose) that is the way out for water you will see or fine some dry that has block the drainage remove all dirt as the case may be then the problem is solve once you can remove the dirt that has block the drainage
around the pipe blockage then problem of the drainage will be solve .
thank you and thank for using fixya.
Posted on Aug 28, 2010
How to remove front of Ariston washing machine AVD 129 SK
take the top off,remove the soap bucket,take the screws off on the pc board/front cover. the top screws of the front pannel are usualy behind the display cover. the botom screws are behind the bottom plastic cover which you have to prey off with a screwdriver from the top side.
Mar 18, 2014 | Ariston Technologies Washing Machines
I have an ariston awd 121 front loader washer dryer. What kind of soap does it call for? Can it be the powder? Does it have to be liquid? Does it have to be a certain brand/type?
To my knowledge all front loading washers require low sudsing high efficiency (he) detergent and these only come in liquid. A powdered detergent could probably be used, but I'd try a 1/4 of the recommended amount for a normal load first. Also it is not recommended. Regular liquid detergent can also probably be used but i'd start with 1/2 the the amount for a normal load. If you don't use the recommended "he detergents" expect occasional oversudsing problems and possibly even early drain pump death. Hope this helps.
Here is the owner's manual for your machine:
http://www.managemylife.com/mmh/owner_manuals/25710/ARISTON-Laundry-Centers-L0520687
Jan 12, 2013 | Ariston Technologies Ariston AWD12 Front...
Hi,I got an Ariston Margherita 2000.It does work well,but the end of the cicle the water doesn`t dissapear from drum.I tried everything,but nothing happend. Many thanks. Zsolt
Hi Zsolt!
The problem can have more causes:
1. At the lower part of the machine is a kind of filter for the dirty water. It is possible it need to be cleaned, a lot of stuff can be stucked there. To get to the filter you have to remove the pannel from the front lower part.
2. The used water pump itself can be the problem, then it need to be replaced.
3. The command unit doesn't work properly so the pump for draining the used water does'n start.
It is quite simple to determine if this pump is starting or not, because it makes during running a tipical sound.
Hope it helped.
Regards,
Bogdan
Aug 21, 2011 | Ariston Technologies Washing Machines
Hi there, i have just moved into a flat and there is the ariston aml 125 washing and dryer and ihave no idea how to use it. all the soap powder sold in nz is top loader soap powder, is this ok to use in a...
Enter this URL into your web browser and you will be able to download the full manual.
http://safemanuals.com/314159.php?k=3c09a0dae46be7bd02298add3193e78a&ID=433640&q=HOTPOINT-ARISTON%20AML%20125
Jan 26, 2011 | Washing Machines
How do I unblock the filter and where is the filter located on my Ariston front loader
Remove the lower plastic panel at the front of washer.
The filter is located at the bottom front right.
Unscrew anti-clockwise to remove and clean.
Have some cloths handy as thetre will be some water that will come out.
Jan 05, 2011 | Ariston Technologies Ariston AWD12 Front...
Washing power/fabric conditioner holder needs removing to clean
This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 12, 2010 | Ariston Technologies AW129NA 16 Lbs Front...
I have a noisy ariston front loader washing machine and
From the front of the washer, spin the drum by hand, and if it feels rough, or is noisy, or rumbling, then the main drum bearings have failed..
If no noise, then problem is elsewhwere.
Hope this helps.
Jan 27, 2010 | Ariston Technologies AW149NA Washer
Hi I have an Ariston Aqualia front loader. It has
You could try mild solution of bleach to the drum, perhaps replace door boot seal..
Nov 04, 2009 | Vacuums
Door Stuck after wash completed
You will have remove top cover, and release door latch from inside the front, with a screw driver pushing against the latch to open door.
It does mean that you probably have a faulty door lock, or broken door handle.
Please rate my fixya solution.
Thanks
Jan 11, 2009 | Ariston Technologies Ariston AWD12 Front...
Ariston Front Loading Washing Machine error code F07
Error code F07 is indicating that the heater relay is stuck for one reason or another.
This could be a board problem, as this where the relay is located.
However, it would be worth checking that the heater is o/k before you do anything else., as this possibly could cause the relay to malfunction.
Plz rate my solution.
Thanks.
Jan 11, 2009 | Ariston Technologies AW125NA 13 lbs. Load...
Ariston Technologies Ariston AWD12 Front Load Washer/Dryer Logo
189 people viewed this question
Top Ariston Technologies Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Ariston Technologies Washing Machine Expert? Answer questions, earn points and help others
