posted by Capt_Troll on May 06, 2008
I Have an Older Rainbow (i think it's a d4)
my Old roommate ran it once without water.
it Still works now (with water), but
it's Very noisey on start up
Also I Can't seem to remove the seperator (no instructions) but the nut at the end of it appears to free spin the motor when i try to turn it.
Can I Take this apart and Clean/lube it? and if so how? or is this thing on it's last legs?
Thanks
Best Solution
posted on Jun 12, 2008
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19674&thid=576894
Older Rainbow Noisy
Posted by Capt_Troll on May 06, 2008
it's Very noisy on start up
Also I Can't seem to remove the separator (no instructions) but the nut at the end of it appears to free spin the motor when i try to turn it.
Can I Take this apart and Clean/lube it? And if so how? Or is this thing on its last legs? Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Rainbow E Series Canister Wet/Dry Vacuum. The Rainbow D4 is an older Rainbow Vacuum and the part where the separator is part of the armature, the separator should be able to be removed and that might be one of the things making noise. As normal maintenance the separator should be removed and cleaned after every use and re-installed, then place a newspaper or towel under the motor unit and turn on the Rainbow and spin the moisture out of the motor unit. This should be done every time you use it. Other wise the Rainbow has 3 fans in the bottom of the motor and if they are weak they will make noise from the motor unit as well. Watch out… the repair of the Rainbow D4 may exceed the cost of a new motor of which will solve your problem of noise and separator --- compare the cost and the labor and make a decision. If you have further questions please feel free to contact your local vacuum cleaner dealer. . So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
The Rainbow / RexAir Factory phone number is listed below:
http://rainbowvacuum.com Customer Service
1-248-643-7222 Monday thru Friday from 9:00 am to 5:00 pm EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Older Rainbow Noisy
Go Ahead. Use Us.
Was this solution helpful? Show your Appreciation by rating it:
Suggest a new solution for this problem
Post a New problem for Rainbow E series Canister Wet/Dry
Email this problem
Email this problem
Can you Help with these Vacuums problems?
Rainbow E series Canister Wet/Dry Vacuum
Rainbow Shampooer
Rainbow Shampooer
Where do the two tubes go at... Answer This...
Rainbow E Series
Rainbow E Series
Hello...I read your answer to... Answer This...
Rainbow Rainmate
Rainbow Rainmate
I have a Rainbow Rainmate with... Answer This...
Repair Service
Find Vacuum Repairman Near You:
