Question about Kenmore 42822 Front Load Washer
I get a Fo6 code problem and can't get it to wash. KENMORE H3 model
  • oeil_de_fauc Aug 30, 2010
    Thanks. I did change the MCU and it seam to have done the job.
  • Kenmore Master
  • 8,220 Answers
Get the bottom service panel off and check the tech sheet for what an F-6 error is.I get a Fo6 code problem and can't get it to wash. - b578ec7.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 28, 2010
  • 4 more comments
  • oeil_de_fauc Aug 29, 2010
    The F06 code indicate a MCU or motor problem.
  • Dan Webster
    Dan Webster Aug 29, 2010
    The white box on the left is the MCU(motor control unit
  • Dan Webster
    a better lookDuet service manual
  • Dan Webster
    Dan Webster Aug 30, 2010
    Did you fix it?
    Yes I did and thank you everyone.
  • Dan Webster
    Preciate the 1 thumbs up it will encourage me to continue and try to do better.
Kenmore elite washer h3 has a f5 code flashing. what does it mean?
The F5 error code indicates a water temperature problem. The control board circuit is not recognizing a resistance change in the water temperature sensor.
You most likely have a loose connection at the tub sensor , or a bad heater.
Richard Roth
The FixYa Team
Aug 17, 2011 | Kenmore Washing Machines
F and H codes
You'll need to access the drain pump assy & remove any obstructions from within the drain pump. Your pump has a trap that you can unscrew (be mindful of the water) for access.
May 18, 2009 | Kenmore Elite 45986 Front Load Washer
F02 error on my kenmore elite H3
FO2 is the code for long drain. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a bunch of towels, a good big plastic bag or a wet vac to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Apr 01, 2009 | Washing Machines
Kenmore Elite H3 ~ Error Code F 02
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Mar 23, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite H3 control buttons - some work some don't
The diagnostic function will not help you if your user interface board (UIB) is acting up because to put into diagnostic you have to select drain spin, then the no spin option, and hit the prewash button 4 times.
It sounds like your UIB is the problem.
Jan 01, 2009 | Kenmore 42822 Front Load Washer
Kenmore elite h3
I have an H3 washing machine and the rubber bellow lip that seals the front door from leaking has torn causing water to leak out. Can this bellow be repaired or easily removed and replaced without calling a service repairman.
Nov 25, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 42822 Front Load Washer Logo
175 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
