Question about Brother MFC 210C All-In-One InkJet Printer
MFC 210C "unable to print"
I have an MFC 210C "unable to print". It shows nine errors the last is A1. I have inspected the ribbon cable and it appears to be fine. Any ideas
I had the same problem i simply pressed the menu/set button then mono start then up button (serch/speed dial) 4 times, then 01 wait till it makes a beeeeeep sound then unplug it (none you will loose all setting and data on the printer
Posted on May 13, 2008
Brother MFC 210C printer unable to clean print head. How can I clean it manually? The inkjet cartridges are full but the printer does not print. Error message on display: unable to clean.
If your printer is like the 420CN Model, do not forget to disconnect the printer for resetting purposes and connect it again and it may clean properly and run fine. Good luck! hopes it work. It did for me. My printer is working fine and I like it. It does the work.
Aug 02, 2010 | Brother MFC 210C All-In-One InkJet Printer
I'm getting the error message Unable to print. check user guide on my brother mfc 210C all in one printer. I don't have my user guide. Please help. Tiare'
Unplug the printer from power cord.Press and hold the "menu" button, then plug the device.You'll see on the LCD screen a "machine error" code.If this code is 40,41,49 or 4F the print head is defective.If the error is 48 -defective print head cable or circuit board.If the error is 50 or 51 there is error in Purge unit and printer require service.If the error is 46 the waste ink tank is full.Follow this:
Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.This will reset the purge count value. Then restart the printer, hopefully without the annoying cannot clean message.
Nov 17, 2009 | Brother MFC 210C All-In-One InkJet Printer
Already purged mfc-210c but the same error
não entendo ingles não poderia mada mensagem em portugues
Jan 29, 2009 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C Machine error 41
Error 41 refers to the printheads which is a common problem with Brother machines. The printheads will need to be replaced. On some machines, Brother has extended the warranty to cover printheads because of the excessive failure rate. Contact Brother to see if you qualify and they may send you new printheads along with easy instructions to replace them. Also please rate this solution with a fixya rating. Thanks!
Dec 27, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210c prints some lines blurred, letters stacked - alignment ok.
i have the same problem. repeated cleanings seem to help, when i print large fonts they come out pretty clear, but the smaller the font, the worse the blurring. 600 DPI prints mismatching patterns, but 1200 DPI prints perfectly fine. so i have found that printing on "fine" quality instead of "fast" or "normal" quality improves print quality ALOT. it uses more ink, but i am in business and need to be able to read very fine print!
May 14, 2008 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C
I am unable to clean and ended up with these notice (unable to print see troubleshoot in user's guide book).pls send the solution to the e-mail address provided.
Apr 03, 2008 | Brother MFC 210C All-In-One InkJet Printer
Print and copy comes out blank paper
mac,
please press menu then start black copy (blue button) then fortimes arrow-up (tel.index). machine will switch to maintenance mode and all buttons will flash. press 8 then zero then severaltimes start black copy until error A1
will appear on the lcd. repeat pressing menu nine times and write down the error codes. Plz post them here again.
To leave the mode press stop then 9 then 9.
Dec 06, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother mfc-215c unable to clean?
I have the same problem my printer (a MFC-215C) is unable to clean and when I press Menu/set I do not have "Black print"? So what do I do now?????? HELP... Thanks Nathalie
Nov 09, 2007 | Brother MFC 420CN All-In-One InkJet...
MFC-210C displaying "Unable to Print"
press menu then start mono (b/w) then 4x arrow-up-button. What error code does the machine display?
Sep 24, 2007 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC-210C
hi this a fateful malfunction only a technician can fix this good luck
Apr 06, 2006 | Brother MFC 210C All-In-One InkJet Printer
Brother MFC 210C All-In-One InkJet Printer Logo
160 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
