Question about Proscan 26LB30QD 26 in. LCD HDTV
Going back to dvd mode without pressing anything.
Unplug from power by removing cord
leave unplugged for 5min
hold power switch on side for 1min
let go, plug in set and power on
this completes a full reset and will likely solve this issue
good luck
Posted on Nov 11, 2010
How do I auto set up for my zoooos controller
Auto Setup automatically searches for the right code for your DVD player. For the most popular DVD player models, Auto-Setup takes a few minutes or less, however, less-common models can take much longer or this method may not work at all.
  1. Find the Auto-Setup instruction page in the on-screen Setup Guide. Your DVD player must be on the Auto-Setup instructions for this method to work properly.
  1. Engage Auto-Setup mode: Hold down the Red button until the setup light turns off. Continue holding the Red button and press the Yellow button three times, then release both buttons. If you’ve done this correctly the light will turn back on and remain on until setup mode is exited. When the setup light remains on, the controller is in setup mode.
  1. Wait for a message from your DVD player. Even though you can’t see anything happening, the controller is actually loading and testing various codes. When the right code is found, your DVD player will tell you to press the Home button. If your player doesn’t respond within about 10 Minutes or the time on the estimate chart, press the Home button to exit this method, and use the Direct Entry method instead.
  1. When the DVD player instructs you to press the Home button, be sure to do so before the onscreen timer runs out. If you miss pressing the Home button before the timer runs out, go ahead and wait until a message from the DVD tells you what to do. If you have not yet pressed the Home button, the DVD will instruct you to press the Back button to back up to the code you missed.
Jan 09, 2010 | Fun Rise Zoooos DVD System
Pressing stop for more than 5 sec doesn't change 'progressive scan mode'
Please press and hold STOP button for more then 5 seconds to cancel Progressive Scan mode.
Oct 22, 2008 | Philips MDV560VR DVD Player/VCR
Turned progressive scan on, can i turn it off without being able
Try these methods for resetting the scan on your dvd."To reset the VIDEO OUTPUT, turn Off the player, turn back On, open the disc tray and press and hold the Stop button on the player for 10 seconds to reset the scan mode." The Reset procedure doesn't seem to work on all versions but you can sometimes get a usable B&W picture allowing you to get to the menu and change the settings by connecting the composite video input of your display to the Red Pr/Cr or Green Y component output jacks on the rear of the cabinet.
You can also go into the Menu and set it blind with the following key presses on the Remote:
1. With the unit Stopped, press Setup.
2. Press Enter.
3. Press the Down Arrow 3 times.
4. Press the Right Arrow Once.
5. Press Enter. Hope this helps you with your problem
Apr 14, 2009 | Cyberhome CH-DVD 300 DVD Player
Need a Code Number to work with my Dish
1 - Hold the clear tv buttom until all 4 light flash red
2- Press the red tv buttom
3- Press the amount of time needed on the up cursor ( around select buttom) until your tv shut down
4-When the tv goes off press the search buttom ( at the end on the right side )
5-Press record
Then u can use the red tv buttom to control ur tv and u can control the volume on satelitte mode without going back to tv mode , if u press too much time while searching the code and the tv wont light back , do the same thing but instead pressing the up cursor press the down one to go back on the code it will be faster .
This way of finder code make the remote search 1 by one , usually dvd and other things else than television dont work , but give it a try might work but probably will just power on and off not more than that but will work fine with ur tv
Jan 11, 2009 | Curtis DVD-7600 DVD Player/VCR
I erased my DVDRAM GSA-4084N software by accident. What can I do?
Honestly, you meesed up your Registry so you need to restore them back.
First step:
Reboot your laptop
and as soon as it starts press F8 (repeatedly) untill you are taken to DOS mode
once you reach the DOS mode
choose Last Known Good Configuration Option and hit enter
now check you drive that should be there
if still remains the bug
Then
2nd step:
Insert your Recovery disk (don't worry about not being displayed drive) in DVD/cd drive
then
Click on start>Run then type in "scf /scannnow" without quotes (and there is space between scf and /).
then hit enter
it should recover your all settings back.
if this does not help then
Last option:
Go to the HP website and download(free of cost) driver for you Laptop and Install back in.
now you are good to go.
by the way, i just would like you to inform that we need to create registry back up before we start playing with it because if anything happens then we can get all registry back in seconds.
Thank you.
Rate answers and post back if anything changes.
Jan 02, 2009 | Computers & Internet
SC-pt750 - screen says CT-Mode wont change
Try cold start.
Power off main set manually by press power button on main set.
Unplug power cord from main set.
Wait for about 5 sec.
[Without plug in power cord] Press and hold "Power" button without release it.
Plug in power cord (must have power) to main set by using another hand [while another hand still press on main set power button]
Keep holding until u see ------ on main set FL display.
Then release you hand which just now pressed on main set.
Power on main set again by manual press power button on main set.
Result should be OK (unlocked)
Dec 06, 2008 | Panasonic Home Theater System System
No remote for small Orion TV - Input mode?
did you figure it out? i am trying to get my orion tv1333 to go into aux mode without a remote. thanks.
Sep 16, 2008 | Orion STV2763 27" TV
SRD4900 Sylvania DVD/VCR Combo
Well first of all, why the hell would you press play when there was nothing in it???
Feb 01, 2008 | Durabrand DUR7 Portable DVD Player
Sudden split screen
Your dvd player is in progressive mode, and your tv isnt capable of playing progressive mode.  To fix this, look on your remote for a button called "Progressive", and press it.  If you dont have a button like that, then look through your service manual for anything that says progressive mode, and it should give instructions on how to set it back to interlace mode.  This is a very common problem I come across when servicing DVD players, as inadvertently pressing the wrong button the remote will cause this.
Sep 07, 2007 | Panasonic DMR-ES40VS DVD Recorder/VCR
Ilo DVDR05
To change from p-scan back to i-scan with no video picture, mu1 model: 1.turn dvd on with no disc, wait 10 sec. 2.press "setup" 3.press "down arrow"(selects audio/video) 4.press "enter" (selects audio/video menu) 5.press "down arrow" 4 times (selects scan mode) 6.press "right arrow" (selects scan menu) 7.press "up arrow" (selects interlace mode) 8.press "enter" (should see picture) Or find a tv with p-scan capability.
Nov 30, 2006 | iLO DVDR05 DVD Recorder
Proscan 26LB30QD 26 in. LCD HDTV Logo
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
