Question about Epson Stylus NX100 InkJet Printer
Change black ink and now prints with white lines through the words on every other line
    Brigadier General:
  • 10,406 Answers
It is CLOGGED print-heads that cause the ink to _not_ be sprayed onto the paper, resulting in "white" horizontal lines.
Run a "print-head-cleaning-cycle", using the Epson software installed when you installed the printer.
Posted on Aug 28, 2010
Words have a line in the middle
Go to the printer driver and run Printer Maintenance, choose the clean printer Nozzle option, this may have to be run a few times especially if the printer hasn't been used for a while
Jan 22, 2013 | Epson TX100 Series
White lines in my printing and sometimes smudges of black ink
Hi
First before you buy a new cartridge,try doing a 'printhead' cleaning on your machine.Sometimes the printheads need cleaning clogginl.
Mar 03, 2012 | Office Equipment & Supplies
My printer isn't printing porperly. There are white lines through the words in my document. What can I do?
Sounds like the ink jet cartridge(s), particularly the black one, is running out of ink.
Dec 31, 2010 | HP OfficeJet Pro K8600 Printer
Failure to print from computer in colour
I have a similiar issue that just started happening recently - the printer shows FULL inks but the PC thinks it has empty inks. I tried the * #, 123 reset hardware failures, but that didnt help. Printer run self diagnostics says all is fine....
I am using USB connections - and this has been fine for years, until now. Maybe a microsoft patch issue?
Jul 03, 2010 | HP Photosmart C6180 All-In-One InkJet...
Lexmark z705 printing blank envelopes soft ware ok
The problem that you are experiencing is caused by the way the text is formatted in most word processing documents. By default envelopes are printed not in black, but a dark gray. This confuses the printer and causes it to use the color cartridge to process gray instead of using the black cartridge.
You can fix this problem with one of two ways:
1. Click on "Start", "Control Panel" and click on "Printers and Faxes." Right click on the "Lexmark Printer" icon and select "Properties." Click on "Printing Preferences." Go to "Quality/Copies" tab and select the option "Print color images in black and white."
2. You can also change the color of you text to a true black in your word processor. This will require you to resort to the word processor's documentation and help files.
Both of these settings will cause your printer to use the black cartridge instead of the color. If either one of these solutions solves your problem, it means your color cartridge needs to be cleaned or replaced. If you feel that the color cartridge should not be out of ink, please follow the steps given below:
Clean Nozzle Procedure:
1. Go to the "Solution Center" and click on the "Maintenance" tab.
2. Select "Clean to fix horizontal strips."
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzles" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
“Wicking” Procedure:
1. Select "Install color/black cartridge" and remove the cartridge from the printer.
2. Get a damp paper towel.
3. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
4. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
5. Next dab the cartridge on the towel to make sure that the ink is flowing.
6. Snap the cartridge back into the printer.
7. On your computer, select "Old Cartridge installed."
8. Repeat the "Clean to fix horizontal strips" procedure listed above.
If this procedure does not help, please let us know so that we can continue with technical support.
Oct 01, 2009 | Lexmark Z705 Inkjet Printer
Just replaced my black ink but printed page comes out blank
Change your print preferences to black and white as a work-around until you get color.
Aug 10, 2009 | HP PhotoSmart 7660 InkJet Printer
White lines through anything I print
Try to clean the catridges and alligned the print head from the front panel menu of the printer.
Regards,  raj_p5983
Jan 20, 2009 | Epson Office Equipment & Supplies
#5 black ink cartridge skips through the middle occasionally
Replacing the print head
The print head may need replacing if, after all print head and ink tank troubleshooting has been performed:
  • The nozzle test appears broken or to have horizontal white streaks.
  • One or more of the colors is missing from the Nozzle Test.
  • The colors are incorrect on the Nozzle Test.
  • A print head error is indicated on the unit.
  • The printer powers off when the print head is installed.
I hope it helps!!!
Nov 29, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Epson Stylus NX100 InkJet Printer Logo
721 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
