Question about GE Zoneline AZ38H12DAD Split System Air Conditioner
I have a unit that haqs been in an apartment for 4 yrs. and now the front of the a/c is filling up with water, why?
    President:
  • 3,074 Answers
The drain line is clogged
Posted on Aug 28, 2010
My frigidare window unit is not draining water out the back. it is filling up in the front. this is the 2nd year we had it and it just started doing it. we have vacuumed the water out of the back and...
From what you described, the problem probably lies with the back of the unit not being tilted down enough. The general rule of thumb is 1/4" to 1/2" downward tilt. This allows the water to flow back to the drain hole and empty faster.That way it will not build up and over flow the front of the unit.
I hope this helps you and thanks for choosing FixYa.
Aug 10, 2011 | Carrier Heating & Cooling
P/No 3850DD 3006E MODEL LDF 681OST 23 7/8 X 33 7/8 609KW2HOO957 69LD 12 10 These are all the numbers on my dishwasher, approx 3-4 yrs old. suddenly started making a noise and stopped washing after...
1. Make certain the water supply valve is turned on. Check the inlet hose for any kinks or bends in the line that could prevent unit from filling properly. Check drain hose for proper installation. If water drains immediately, unit will display an IE Error Code.
2. Check the water supply valve and make certain that it is turned on and open fully or this code will display.
3. Check the inlet valve filter for buildup of mineral deposits. If the inlet valve filter is clogged it will restrict water flow is restricted into the dishwasher, resulting the IE Error. Clean filter with small brush to remove any accumulated mineral deposits that may have accumulated.
4. If inlet hose is kinked, water flow into the dishwasher, is restricted resulting the IE Error. Straighten any bends or kinks in the inlet hose. If the drain hose is not installed properly and the water drains out of unit, this could cause premature draining, which results in IE Error Code. In this case it will be necessary to reinstall the drain hose according the instructions in the installation guide.
5. If the water pressure is not 20 - 120 psi, water will not fill properly. This will result in IError Code. If water pressure is too low, it may be necessary to call for service.
6. During winter, parts of the dishwasher that are installed outside may freeze. Melt the frozen part by soaking a towel in warm water and wrapping it around the part. This should allow the dishwasher to operate.
7. If the unit is not leveled properly, the IE Error may occur. Use a level to check the sides and top of the unit. If the unit is not level, adjust the leveling feet in the front and back. Use the leveling kit packaged with the dishwasher. Check mounting brackets. If one is tightened more than the other, it will offset the cabinet.
* Note: To adjust leveling legs on the front, use a 1/4" square drive wrench. Turn clockwise as needed to adjust level. To adjust rear legs, use a standard Phillips head screw driver. On the left side rear, turn the screw counterclockwise to lower the leg and raise the rear. To adjust right side rear, turn the adjusting screw clockwise to lower the leg and raise the rear of dishwasher. Using a level while adjusting the legs will help aid in proper leveling.
Feb 14, 2011 | LG Dishwashers
Water dispencer does not stop when lever is
your control panel is sticking. it will get that way if you get your ice after you fill your drink. the way to fix this is to take it apart and clean it. the front panel comes off and there are 4 screws and then the whole unit can be removed.
Oct 20, 2009 | GE Refrigerators
Drips from center of front cover when filling at 3-4 inches
after carefully reading this, the leak is at the machines water valves, or from them to hose to tub.
Sep 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Condinsate Water Leaks Inside Trailer
Where is it dripping from inside the trailer? is a tray under the unit filling up? why does the line drip? where from? is it split? have you put a color dye in condensate to check flow what temp have you got inside your trailer when A/C off?
Jun 08, 2009 | Dometic Rooftop RV Air Conditioner
Water won't run into washer - clicking sound only front upper left like plastic gears running over each other
The fill valve is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 01, 2009 | Kenmore Washing Machines
Water fills machine but won't shutoff
ekrok, you are going to have to change the fill valve. If water is still filling when the unit is unplugged, that means the valve is stuck open. This is not a hard fix. You will have to remove the screws on the top in back. Should be three. If this is a GE you will have to remove the front header. Three screws in back of the front header. Now the top will slide off toward the back The valve is easy to get at. Get your part at a local appiance parts store or order it from repairclinic.com. Change it out and this will be a done deal, Catriver
Mar 07, 2009 | Whirlpool GHW9100L Front Load Washer
Drum doesn't move or spin
kenmore tumble action washer model#417.44152400,
Washer is approximately 3 years old. Will not drain or spin. When it tries to spin, clicking noise heard inside of unit. Would a clog insie the lines disable the spin cycle ?
Oct 18, 2008 | Kenmore 43142 Front Load Washer
Frontloader washes and rinses on cold all cycles but whites
drain hose maybe going down the waste pipe too far 4 inchs is about right,check it out,most machines take in extra water on a cold wash!!!close eire
Jan 31, 2007 | Frigidaire GLTF1670A Front Load Washer
GE Zoneline AZ38H12DAD Split System Air Conditioner Logo
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
