Question about Staples Swingline® 36115 Staple Guns Tools 1, 000 /box, Light-Duty, 5/16
How do I remove a jam from the Swingline 520e stapler?
5 Suggested Answers
  • 40 Answers
SOURCE: instructions on unjamming swingline electric
First, are you using the recommended staples for this stapler? Many heavy duty electric staplers don't use "standard" desk staples. Second, try unplugging the stapler, unloading the staples, and if possible, reach a couple of fingers into the stapler and try manually pushing up on the staple head to see if you can get the driver blade to come down. Does it come down smoothly, or does it seem like there is something stuck in there? If you aren't sure about disassembling the unit (my usual method-but I'd recommend having the parts diagram handy), try using a flashlight to look at the underside of the staple head, where the staples come out - can you see anything stuck in there? If so, you might be able to use a small knife blade or small dental pick to get jammed staple pieces out.
Posted on Mar 14, 2009
  • 40 Answers
SOURCE: Nothing happens when you load paper to staple.
assuming it is plugged into a good power source and turned on (no offense intended, just getting the obvious out of the way - and I've fallen victim to the obvious myself before), look inside where you put the paper - is there a trigger mechanism? Most electric staplers have them (the paper hits the trigger and the stapler fires), and some allow you to set the sensitivity of the trigger. If yours allows you to adjust the sensitivity, try adjusting it. If it's not adjustable, the trigger probably needs to be replaced (under heavy use, they may need to be replaced every year or so).
SOURCE: Swingline 520e does not staple
The trick to clearing this is to rn the stapler WITHOUT the cartridge in. We removed several visible jams, but once we ran it with the cartridge out, a huge piece of staple came out, and then we were able to put the cartridge back in and use it. Woot!
Posted on Apr 23, 2010
SOURCE: my swingline electric stapler model 42130 is
Taking the stapler apart is a complex task if you can figure how to do that.To dismantle the stapler, slide back the top, remove two small screws on both sides, six on the bottom, four of the screws are under the sticker so you must peel off the sticker, you must also remove the sticker on top. There two tiny shinny screws at the bottom once you are inside. Now you have access to more screws you can take off to get to the staples place where the jam is. Watch cables where they are plugged to in case they come off. If you are are a mechanical technician or technically inclined you might be able to fix this yourself but you must be very patient.
Posted on Jul 28, 2010
How do I open the stapler
Hello, Go to this website for a manual to fix or on this website, call cust. support. Swingline Manuals Swingline
Oct 23, 2014 | Swingline 520E Electronic Stapler Black
How do I load staples in model 520e
Hello, Go to this website for a manual or call cust. support on this website. Swingline Manuals Swingline
Optima Model # 8787x. Appears to be jammed. How do I open up the stapler to remove cause of jam. I think if I could open it up I could fix it. If all fails can this be sent away to be fixed and...
You need to open the stapler from the back. Push the black piece at the back of the stapler in, then pull it up and out. Remove the jammed staples, and reinstall. Make sure you use the correct staple . It appears to be: SWINGLINE 35550 HIGH CAPACITY STAPLES, 3/8"
Apr 13, 2011 | Swingline Heavy Duty Stapler 30 160 Sheet...
Swingline 270 (69270) Staple ends are left mostly open Also, stapler makes a significant popping noise with each use
Swingline, now owned by ACCO, should have a service manual that would tell you how to clear jams - here's the url - http://www.acco.com/contactus.aspx#swingline. If not, you can also send them your question directly so they can help you resolve the issue.
Jan 27, 2011 | Office Equipment & Supplies
Swingline optima 45 electric stapler cartridge won't reset
call gbc 1-800-541-0094 it has a 5 year warranty. they will send a new one.
Mar 10, 2010 | Office Equipment & Supplies
Sep 16, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Stapler is not dispensing staples after new cartridge is inserted. Can you help?
Remove the staple cartridge, look into the cartrige area, are there any stray staples in this area, if so remove them, cycle the unit a couple of times without the cartrige in place, check the output end, any stray staples here? re assemble making sure you pull the first row ow staples even with the nozzle of the cartrige.
Hope this helps
Ed
Apr 30, 2009 | Office Equipment & Supplies
My Swingline model 520e jams every other time I staple.
There were a few staples left in the cartridge when the stapler stopped working. I went thru all the steps on bottom for stapler after changing the cartridge with two different cartridges. It makes the noise and puts marks in the paper, but no staples come out of it.
Mar 18, 2009 | Staples Swingline® 36115 Staple Guns Tools...
Staples Swingline® 36115 Staple Guns Tools 1, 000 /box, Light-Duty, 5/16 Logo
235 people viewed this question
Top Staples Tools & Hardware - Others Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jo Ann
Level 1 Expert
magna buff
Are you a Staples Tool and Hardware - Other Expert? Answer questions, earn points and help others
