Question about Dryers
Changing the belt on my admiral dryer
My dryer belt broke, I took it off the floor of the cabinet but now I don't know how to replace it.
    Novelist:
  • 177 Answers
Go to partselect.com and look up a belt for you admiral dryer.
At this site they may have a diagram for how the belt goes on the cylinder, idler wheel and motor.
Start here, more later as needed.
Posted on May 07, 2008
My belt is broken on my tumble dryer.took it apart and don't know how to put the new belt on
The belt goes around the drum, through the idler pulley onto the pulley on the motor. The idler fastens into several holes on the floor of the dryer.
Sep 29, 2011 | Dryers
Heat won't go on...don't know if it's an ignitor problem, or a coil problem
UNPLUG DRYER REMOVE TWO PHILLIPS SCREWS UNDER FILTER ON TOP LID ....
FLIP TOP TOWARDS WALL REMVOVE 5/16 SCREWS IN TOP CORNER OF CABINET AN LEAVE DOOR AND FRONT CONNECTED REMOVE DRUM BT RELIEV IDLER BELT TENSIONER INFRONT OF MOTOR AND SLIDE BELT AND DRUM OUT OF CABINET AND SET OUT OF WAY TURN DRYER IN TIMED DRYER NEAR 60 AND LAY ON FLOOR INFRONT OF DRYER ON FLOOR INFRONT OF DRYER INFRONT OF BURNER TUBE AND WATCH AND LISTEN IGNITOR SHOULD GLOW RED THEN A CLICK THEN IGNITOR SHOULD LIGHT GAS ..... IGNITOR DOSENT GLOW CHECK WHITE PLASTIC FUSE ... IF IGNITOR GLOWS AND NO CLICK THE REPLACE FLAME SWITCH ALUMINUM AND BLACK BOX ON LEFT SIDE OF BURNER TUBE ...IF CLICKS AND NO GAS REPLACE GAS COILS
Jan 26, 2011 | Estate TEDX640JQ Electric Dryer
The belt on my dryer broke. How do I replace it
open a cabinet:
http://www.partselect.com/dryer+new-whirlpool-open-cabinet+repair.htm
belt diagram:
http://www.applianceaid.com/images/belt-config.JPG
Hope this helps, you may want to clean out all the lint inside the dryer since it is open. Tim
Nov 27, 2010 | Whirlpool ET8CHEXSQ Dryer
My belp broke on the dryer. i purchased a new belt, i cannot figure how the belt tentioer is installed. it was laying on floor of dryer when i took it apart
Look at the tips and tricks under my profile...I have quite a few tips and pictures of how the belt routes around the tensioner... it will give you an idea of how it should look. Look for the tip that matches your make of dryer...
heatman101
Apr 15, 2010 | Dryers
The belt broke drum won't turn
Hello Friend, Replacing a dryer belt is very simple. Just remove front of dryer cabinet. unplug wires from dryer door switch. Just slide a new belt over the drum with the belt grooves facing to the inside. Underneath drum you will see a tention wheel next to motor. Install belt around tention wheel and around motor shaft pully. Re-install front dryer cabinet. Make sure to plug in the wires to the door switch and make sure that the drum is re-inserted back over the felt glide on inner cabinet front. Happy to help, Tim.
Jun 25, 2009 | Roper REX3614KW Electric Dryer
Admiral Dryer: 5 cycle 3 temperature electric
Unplug Dryer
Remove back (many screws)
Clean lint from interior & Vent Chute
check for breakage & parts on dryer floor
check for burn damage (wires burned off or char)
if no burn or char:
could be the "Dryer Coil" itself broke or
a "Snap Disc" usually mounted on the coil housing.
Very Serious!!!! Replace only!!!! Do not ever bypass!!!!
Stay clear of dryer for test start
Be ready to shut it down fast in case of problems
Always replace back & vent chute
Good luck,
Vinnie
Jun 17, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer belt
You can go to www.repairclinic.com/0079.asp#DiagramF and you will find the admiral brand belt diagram in a list of several brands. It will show several ways that the belt can be installed. I believe you will find what you need.
Nov 11, 2008 | Dryers
Kenmore dryer
It is very much easier to replace the belt from the front, than the back, the cabinet disassembles from the front, and the mechanism remians attached to the rear plate and cabinet floor.
  • pull lint filter out
  • remove 2 screws from under lint filter
  • with putty knife or other blunt blade, release clips at front corners of cabinet top
  • tilt up cabinet top
  • remove 1screw 1/3 way down each side of front of cabinet.
  • lift off cabinet front
  • drum, motor, tensioner, are all exposed
  • lift drum out forward
  • check rollers, drum felts, nylon glide bearings for wear
    (worn bearing surfaces are the most common cause of belt breakage and you dont want to do it again next month)
  • reinstall tensioner in slots in cabinet floor, reinstall tensioner spring between tensioner and cabinet floor
    (Once the cabinet is open the tensioner mounts are easily visible)
  • loop belt around drum at the wear marks of the prior belt
  • reinstall drum on unworn bearing rollers etc
  • loop belt around motor pulley
  • pull tensioner hard against spring to end of travel
  • loop belt around tensioner
  • relax tensioner
  • spin drum by hand to ensure belt isnt going to jump off
reinstall cabinet in reverse order
~15 MINUTES, but I do 3-4 per day
Oct 07, 2008 | Kenmore 62602 Electric Dryer
Kemore Dryer 11064602300 belt replacement
Go to repairclinic.com. Click on the "Repair Help" heading on the left-hand side of the screen. On the next page is a "Dryer Belt Diagrams" heading on the left hand side. Your dryer belt diagram will be either "H" or "K" listed under the Whirlpool section. Your Kenmore is manufactured by Whirlpool. I hope this helps you. Please post back if you need further assistance.
Jun 06, 2008 | Kenmore 62822 Electric Dryer
Dryers Logo
1,168 people viewed this question
Top Dryers Experts
