Question about Maytag EPICz Electric Dryer
The dryer won't turn on when we hit start. It just beeps like it needs something. Usually the "check lint screen" light pops on first but that doesn't even happen. We have unplugged it and plugged it back in but still doesn't work. Any ideas?
    President:
  • 3,074 Answers
Try bypassing the door switch
Posted on Aug 28, 2010
  • piercy92068 Aug 28, 2010
    It doesn't seem like it has anything to do with the door switch.
Error code CL on Kenmore Dryer
The "Check lint screen" light is just a reminder to check the and clean the lint screen before or after each load. There is not a sensor that will detect if it's clean or dirty, it's just a reminder. The "Check lint screen" should turn off as soon as the dryer is started. If it never turns off then the control board would need to be replaced in order for the check lint screen reminder to turn off, however the check ling screen reminder light staying on will not effect the operation of the dryer.
Here is the control board to order.
The part comes with a 365 day, any part, any reason return.
Nov 02, 2012 | Dryers
My dryer drum won't turn but the electrical panel is lighting up
it is most likely that the belt inside the back of the dryer is broken or loose.
unplug the dryer and remove the back cover of the dryer. it should look something like this:
although the is for a different make of dryer, it should be similar.
Mar 08, 2012 | Kenmore Elite HE3 Steam 8676 Dryer
My check lint filter light is on, lint filter has been cleaned. is the exhaust line possible clogged? I have a Epix Z series dryer, the lint filter was not cleaned and now the check lint fileter light is...
Hi
Thanks for using FixYa. To start with the first thing you should do is to remove the lint filter and clean the lint out of inside where the lint screen goes. After this unplug the unit for 5-10 minutes and then push & hold the start/pause button for 10-15 seconds and reconnect the unit. If still it won’t work then it’s the sensor that has gone bad and needs to be replaced. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 30, 2010 | Maytag EPICz 6.7 Cu. Ft. King-Size...
Maytag neptune dryer will not start
Ok here is what I would do. The first thing I want to do is check the door switch. If that switch is broken the dryer won't go BUT the lights would all be on and the duct fuse intact. If that turned out to be ok, I would remove the ducting60b599d.jpg in the rear and look for excessive lint and fluff in the vent hose and the vent pipe to outside. I would look next at the filter and inside the filter housing for fluff and lint. If I saw something I thought might be causing an air restriction I would then guess the duct fuse was blown. Does that make sense to you? I Would need to unplug the machine and move it to a work bench lift or tailgate. b5d8bb1.jpgIf the top pops i would pop that top Note( if the dryer is a slopehead I would start by removing the door and goalpost front d2679bf.jpgthen pop the top and remove the shroud and drum) I would look2849823.jpg for a loose blower wheel and fluff. I would check the duct fuse
Mar 31, 2010 | Maytag Neptune MDE5500AY Electric Dryer
What start
check thermal fuse it is located n the back or on the inside behind the lint screen its usually white plastic and is round or oblong you can check it by jumping it out .if that is the problen you need to clean out the lint trap and hose dont forget to clean the port outside the house,after the fuse is replaced otherwise it will overheat and pop the new fuse
Mar 20, 2010 | Amana DLE330RAW Electric Dryer
Check lint filter and touch up keep coming on-beeping
Clean out entire venting system. If you are using flexable hose type, replace with solid metal type or at least replace with new hose. You may have a clog my friend.
Nov 29, 2007 | Kenmore Elite HE4 Electric Dryer
Dryer won't work, Check Filter light is on
I had exactly the same problem with my newish LG dryer. I deduced that the dryer's computer essentially needed to be rebooted. I pulled the plug for a minute or so, then plugged it back in. It works perfectly now.
Mar 11, 2007 | LG DLE2514 Electric Dryer
Maytag EPICz Electric Dryer Logo
110 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
