Question about Roaring Spring Filler Paper 3 Hole Punch 8"x10 1 2" Bold Rule Margin
How to put the spring back on that helps to open and close the handles of the puncher
Door will not stay close
Not much data to go on here. The latch on the door has a spring that holds it down in the locked position. when you pull the handle the latch goes up and you pull the door open. You will have to take the door apart and see if the spring broke or the plastic tab that holds the end of the spring is broken.
Feb 25, 2015 | Maytag Appliances Over-the-Range Microwave...
YJ wrangler door wont close
Start out by checking the latch mechanism on the door. Use a screwdriver to "trip" the latch with the door open, then pull on the screwdriver against the latch gate. If it doesn't hold then you may have a bad latch (the springs in the latch can go bad over time). You can also try spraying penetrating oil (PB Blaster) into the latch and again using a screwdriver to trip the latch, then open with the handle, and repeat several times to work the oil into the mechanism and free it up (this trick also sometimes works with the springs on wiper arms that have lost tension). If the penetrating oil trick works, think about spraying dry lube or white lithium grease into the latch to help prevent it from happening again. If the door is misaligned, consider new hinge bushings, a misaligned door can cause damage to the door, and put tension on the door latch in a direction that puts pressure on the latch that it wasn't designed for.
Apr 15, 2017 | 1988 Jeep Wrangler
Trying to put the back crank windows back in my Chevy II Nova
If it's a C shaped spring, just put the spring on the handle and pound the handle onto the shaft. The shaft is tapered and will spread the spring open until it snaps into the slot on the shaft.
Sep 04, 2011 | Chevrolet Chevy Cars & Trucks
How do I install a new Handle/Latch assembly on the door of a Whirlpool LHW0050PQ 4 Wash Machine...have to remove present one as broken---pull handle door catch does not release---have to release putting a...
I had to replace part No 8182408 - the washing machine door handle. There is a plastic bar in the middle of the assembly that broke because the door was opened too hard.
There are two springs, the latch, and the plastic piece that brings it all together. The smaller spring is the key, call it the L spring. It is shaped like an L and goes around the ends of the latch. The other spring is the larger and straight and goes around the tops of the plastic piece. The straight spring goes in with the crossbar facing on the outside of the washer. The latch with the L spring fits in between the plastic crossbar with the U shaped end pressing against the latches inside bar. The antenna of the L spring needs to wrap around the plastic bar and fit inside the straight spring bar. This applies pressure on the latch to stay closed. When the handle is pulled, it releases the pressure and allows you to open the door. The Metal bar is used to hold all the pieces together and once you have the alignment right, put it back into the door with the straight spring antenna tucked in the spots on the door, as well as the metal bar ends. Screw in the two spots that holds the assembly in place and you will be set. The door should open and shut easily.
Apr 22, 2011 | Whirlpool Washing Machines
How do you load staples in a Bates gbc 3220st puncher/stapler?
On the right side of the machine are two levers, the one towards the rear is a release button. It releases the "magazine" that holds the staples. Turn it and the magazine will slide out, then put your standard staples in and close. It took a little manipulation of the lever before it released on mine, and I expected the magazine to pop out as if spring loaded and it did not. Try gently pulling on the magazine whiole turining the lever, and it should work!
Feb 15, 2011 | Office Equipment & Supplies
My dear wife took the lid handle off our breville gourmet wok. The pieces include a screw, a spring and 3 other parts. Im not sure if i put it together properly. Could you help out. Thanks
This is for assembling the Breville Wok lid. This has a built in vent that lets steam escape during cooking. There are 8 pieces not including the glass cover: bolt, metal vent, black O ring, tan round plastic piece, black lid piece (has open/close) on it, spring, clear plastic seal, lid handle.
Order of assembly as follows, starting on inside of glass cover.1. Bolt.2. Metal vent piece sits on top of bolt.3. Black O ring fits snuggly onto of vent piece.Insert what you have assembled against inside of glass cover, bolt poking through topside of glass.4. Add tan plastic piece with 3 prongs going facedown against the glass hole of cover.5. Larger black lid piece goes next. You will need to line up the openings on tan piece and this lid piece so that it sits semi-flush against glass. When complete this piece will turn in place to open/close vent (less than 1/4 turn before stopping).6. Add clear plastic seal to underside of handle.7. Place spring between handle and top of black lid piece and screw together until snug.
Test lid by turning lid piece. It should move back and forth according to the open/close print on top. If no luck, go to step 5 and try again. It is a little tricky, but does work when done correctly.
Feb 02, 2011 | Breville EW30 Gourmet Non Stick Electric...
I need a diagram for the trigger. I cant figure out how to put the spring back into the trigger. It popped out on me while I was workin on it and didnt notice how it was put in?
Look closely inside the handle where it lays. There may be a small plastic post there to hold it and/or the spring. Realize when the trigger is depressed (up against the handle) the spring is loaded and it pushes the trigger back down if you let go of it. Lay the spring in the general area and look for any scraping of the plastic which may show you exactly where it went.
Aug 13, 2010 | Craftsman Garden
The hood release handle is stuck out and won't spring back on my 99 ford escort. The hood is closed and latched. Any help would be appreciated
you probably have to open up the hood latch assembly and replace the sring. sounds like it broke. or maybe the cable. can you push it back in?
Feb 25, 2010 | 1997 Ford Explorer AWD
Roaring Spring Filler Paper 3 Hole Punch 8"x10 1 2" Bold Rule Margin Logo
44 people viewed this question
Top Roaring Spring Office Equipment & Supplies Experts
k24674
Are you a Roaring Spring Office Equipment and Supply Expert? Answer questions, earn points and help others
